If you have a pressure load, you need the time history of that pressure to compute the final velocity.
It will be simpler if you assign an impact velocity to use as the Initial Condition velocity of a cap that is just touching the sheet. Then the mass of the cap and its initial velocity completely defines the energy in the system at t=0 for the sheet problem.
