Mahmoud Mosaad
Thanks for your answer but I did try using a sampling point but it gives me the stiffness matrix of the composite without considering the effect of the interface layer that I inserted.
You can see if you add an ineterface layer, it will not be shown in the modeling ply of the sampling point.
I hope if you can help me with another solution!!
Thanks for your time and consideration!
