Reno Genest
The interface layer should not have any effect on the stiffness matrix. You are not adding any material to the laminate when using an interface layer. If you have plies of prepreg in a laminate, delamination occurs between the plies at the resin. The resin is already there and taken into account in the laminate.
Reno.
