Lukas Hildebrand
Dear Navya,
thank you for your reply. I try to clarify and add additional Screenshots:
You can see one conductor which (I assume) works like a shortcirquit without the terminal because its a closed conductive object. There is no terminal necessary for the SC to work. However if I itroduce the terminal (visible on the other screenshots) the results differ and are not correct anymore. I wanted to start like this and compare the results before adding more windings and a stranded form but already the simplest terminal with 0V excitation changes the solution.
Hope this clarification helped. If not please feel free to ask further questions.
Greetings,
Lukas
