If you have a high fraction of bubbles use degassing with some caution: read how it works.
Also, for PBM, check which option you want to use. Some collect all the diameters into one phase. Otherwise, yes, you may need extra phases for each diameter. For outlet backflow I'd probably pick the largest diameter bubble phase as it shouldn't penetrate too far into the domain.
