Hello Feiyu Shi,
The command CZMESH is usually used for this application to add a Cohesive Zone Material Model in the system.
More on this can be found in the following references -
4.11. Cohesive Zone Material (CZM) Model (ansys.com)
CZMESH (ansys.com)
More details on the element can be found as follows-
INTER202 (ansys.com)
13.202. INTER202 - 2D 4-Node Cohesive (ansys.com)
Here are some of the examples which use INTER202, which might serve as a good reference in resolving the issue.
Case Description- VM248 (ansys.com)
Input Listing- VM248 Input Listing (ansys.com)
Example from technology showcase-
Chapter 36: VCCT-Based Crack-Growth Simulation of a Composite Laminated T-Joint (ansys.com)
Hope this helps!
Thanks,
Sahil
https://forum.ansys.com/forums/topic/how-to-access-the-ansys-online-help/
https://forum.ansys.com/forums/topic/guidelines-for-posting-on-ansys-learning-forum/#latest
