HDLI
Hello Hesham,
      If the magnet has partial demagnetization, it means demagnetization just happens in some area of the magnet. We may not use 1) to manually modify matetial properties.
      I think the model will add current of before demagnetization and demagnetization phase in the efficiency map model’s excitation, and then make sure the simulation would take the results in last cycle of the map’s exciation for the efficiency map calculation.
      Excitation will be like, that could be modifed for your purpose.
      If(time<1/freq_e, sin(2*pi*freq_e*time),if(time<2/freq_e,3*sin(2*pi*freq_e*time),I_pk*sin(2*pi**freq_e*time)))
       0~1/freq_e:  current = sin(2*pi*freq_e*time)
       1/freq_e~2/freq_e :  3 times of current, your demagnetization current
       after 2/freq_e:   current for effciency map
       Demagnetization example is in ALH https://jam8.sapjam.com/groups/NA4AXmq6h4aU43Ap36G0uU/content?folder_id=TT5bLYQWQ3Ri6dtPW5h3m9
Howard
