Have you looked in the Contour plots? Under Velocity you'll find axial & tangential velocity. In Mesh you'll find Axial and Radial positions. These are relative to the local cell zone axis (set in the Cell Zone panel(s)). You may want a Custom Field Function. You can then report these using the surface reports and/or plot the contours.
