Hi Miguel,
Thank you for reaching out and your patience is much appreciated.
Ansys Q3D is the best tool for this scenario. It can calculate the resistance and inductance of the coil. Here is the link to Ansys Innovation course on using Q3D - Intro to Ansys Q3D | Ansys Innovation Course.
But if you want to compare the results of HFSS and Maxwell simulation then you need to make sure that the simulation model is set up identically for getting similar results. Kindly share snapshots of your HFSS model and setup. It is observed that the difference between inductance calculations is reduced as compared to your previous post. Please let us know what modifications are done to serve you better.
The Maxwell part of the query will be addressed by the concerned person shortly.
Best regards,
Praneeth.
