April 12, 2023 at 5:21 am
How to generate the fluid 221 elements? Can we run modal analysis for structure+fluid case with fluid modeled as point mass? I have also modeled a 3d fluid part. Can we define contact between fluid and container walls interface? I read in mechanical help guide where it is mentioned that only bonded with MPC formulation can be used for fluid-structure contact. Will the contact affect reults or shared topology is to be considered between fluid structure interface?
