SRP
To model crosslinking, you will need to define the chemical reactions that occur when your two fluids mix. You can define the reactions, which allows you to specify the stoichiometry and kinetics of each reaction.
If you have ionic crosslinking, you will need to define the species transport properties of your ions.
Thank you.
