April 12, 2023 at 11:02 pm
Hello again.Thank you for the answer.When i say different configuration,i mean different cases of layouts .For example …case 1:parallel moorings for a structure…case 2:perpendicular moorings for the same structure .Or different number of moorings for the same offshore structure.What parameter should i use in this case? …Is it possible to plot graphs of all(for example 3-4 different cases) cases at one diagramm?
Thank you again!
