Hi Guilin Sun,
I am simulating an optical fiber edge coupled to an silicon inverse taper in EME. I want to get the increase in the coupling loss as a function of the distance of the fiber to the taper. I think that the mode divergence must be considered. How can I set the cell between the fiber and the taper to consider the increase in the mode size?
Thank you,
