It seems this is a common warning message for certain finite element mesh. You will find some results from google by searching "bad termination of one of your application processes."
It might indicate that process is not needed or some jon schedule issue.
You may try to slightly modify the mesh settings, such as round up the "min edge length", or use a consgraint local mesh.
