Guilin Sun
Are you using a log scale in the graph?
you can increase the simulation time by 10 folder of the origial value.
You may also use integer number of meshes in the periodic directions with the override mesh settings.
Due to the periodic interaction, the simulation can be long. This is why when you add a small loss to the material it terminates faster.
