André Henrique
I disabled the Check Mesh Quality option and managed to generate the mesh (otherwise it would not be possible to generate it due to the errors described above), but the mesh appears to be of poor quality. I'm just using body sizing and MultiZone. Please, check right below what I have got.
*As you can see in the image below, there is also a larger solid surrounding the others in this case (it's a PML).
