Praneeth
The following are the next recommendations -
  1. Can you please check if you are able to see any example simulations normally or not? You can also try to create any random geometry by using the commands in the draw tab. Please share a screenshot if possible.
  2. Did you modify the model in the simpleware? If possible check the stl model in any other online tool to see if it is displayed correctly.
Best regards,
Praneeth.
