Did you set a non-confomal interface between the rotating part and the stationary part? If you're in CFD Post check you're seeing the correct velocity - relative & absolute mix ups can cause the above. I also suggest moving to 2023R1 (R19.3 is from 6 years ago) and post processing in Fluent.
