NickFL
You are using CFD Post. Did you export the 3D values or only the surface values? If you run a cutplane through the domain do the results show up there? Or is it just the outline. This will help identify what was transferred to the post-processor.
Is there are reason you cannot post-process the results you want in fluent?
