April 17, 2023 at 10:08 am
Hi Paula Alonso,
The force loads can be to the keypoints, using the command 'FK'.
You can also use 'KLIST' or 'FKLIST' to see the Keypoints or the Loads added to the Keypoints respectively.
So for line 2 of the mentioned code, try Fk, KP1, FX,10 or select the keypoint by KSEL and then FK, ALL, FX,10.
Please find the references as follows-
K (ansys.com)
FK (ansys.com)
FKLIST (ansys.com)
Hope this helps!
Thanks,
Sahil
https://forum.ansys.com/forums/topic/how-to-access-the-ansys-online-help/
https://forum.ansys.com/forums/topic/guidelines-for-posting-on-ansys-learning-forum/#latest
