GLUO
Hi Antonie,
3D projects are harder to be solved than 2D projects with the same mesh count. However, the error message "3dtds terminated abnormally" is not neccessarily related to out of memory or mesh issues. Could you first try solving with all mesh operation disabled, and use the following initial mesh settings if your AEDT is in 2022R2 version or below?
Thanks,
GL
