Mae Kristine Labendia
Hi Nikhil Narale
I do like to ask question, as I set my boundary conditions, it seems that what I inputted in the free stream temperature is also the outlet temperature of pipe.
What I would like to discover is the outlet temperature of above mentioned conditions. Assuming inlet temperature of 300deg celcius 500m below ground. with assumed pressure of 28Mpa what should be the best way to discover the outlet temperature of my case.
Appreciate your help and to anyone who may have an idea really appreciate.
Thank you so much
