Looks reasonable. I'd check the tube side HTC, but that's for the OP to do: text books have their uses.
The only question then is the tube side temperature. Question to both, can you assume a linear relationship with position? Ie does the temperature increase linearly between passes, and is the temperature variation over a single pass permissible?
