Ashish Khemka
Hi Venkata,
You are getting the response as per the input multilinear isotropic hardening model. Was the data for the multilinear model obtained from compression testing?
The approach should be to get the stress-strain curve from compression testing and then input the same (may be hyperelastic response function) to get similar output results from simulation.
Ashish Khemka
