Dave Looman
Your approach is OK.  The spring will stiffness will update based on the time specified by the TIME command, even in a static analysis.  The reason you didn't get expected results is because you didn't constrain the end of the combi14 elements.  Commands like nsel,s,loc,y,0.2 and d,all,all are required.
