Guilin Sun
This is a section of waveguide in air, which is a cavity. What source you are using? how many sources?  In your experiment how do you exite it? how do you mean the transmission?  When a source is inside a cavity, the transmission or refleciton will not be accurate as the reflection will modify the source power.
