Sorry, I mean to copy the Hydrodynamic Response results from the solver file directory to another folder that you use to save Aqwa result files. The solver file directory path can be found in the Details panel of the "Solution" branch in the Outline tree. Copy all the files in the solver file directory, which contains all the modeling and results information of your current analysis. Once you change the mooring configuration and solve the project again, those files will be replaced.
