April 19, 2023 at 7:50 am
Hi Praneeth,
The main goal is to simulate the planar transformer (open circuit in secondary) in Q3D and export it in Circuit design in order to know the Impedance (|Z|) and the phase (knowing current and voltage accross the transformer)
In Q3D, I have 2 Nets, Primary and Secondary. I assign Excitation in my primary (Source and Sink) and simulate (10 Hz to 100 MHz).
For the Inductance, I change my permeability material to a constant and it works. BUT, for the capacitance, the results seems low. The difference between my model and experiment is high. I don't know if I need to assign a floating net to the secondary as my experiment, I only measure |Z| of the primary with my secondary Open ?
Thx,
