Sam Ho
I've lowered the mesh defeaturing tolerance and it works now. So apparently I have to lower it and not turn it off.
Do you mind if I ask why this is the case? (Is it because if the defeaturing is set to zero, then my model is too complex to mesh and if set to default, the tolerance is too large hence resulting in errors?)
All in all, Thank you very much for answering my questions! You were very helpful and I hope you have a great day.
