Rahul Kumbhar
If you turn off defeature, then there could be very small features(not important for FEA) which mesher will try to mesh and may fail as the minimum size is larger than those features.
Also there can be situation where defeature tolerance is large such that it is defeaturing important features from mesh, which may also cause meshing issue.
