April 19, 2023 at 1:20 pm
Hello Deyu,
Thank you for your answere. Here is a screenshot of the coil that I want to use as a Shortcircuit in my simulation (For now with one winding to compare against the case of no terminal at all)
The solutions of the primary inductance and the field inside the surrounded toroid differes heavily in both cases which is why I cannot use the terminal to assign more windings to the shortcut since the solutions are not comparable.
Please tell me if it is possible to insert short circuit coils in EddyCurrent simulation and if so, how to do it. Thank you in advance!
