Hi Lukas, yes, you can use this setup as short circuit in Eddy Current solver. It's basically short the coil winding with the 15Ohm load resistor together.
With short circuit in the winding from above picture, the field will be different from solid copper object without coil terminal. Are expecting other behavior?
