Lukas Hildebrand
Yes, because it is just one winding, which would lead to solid copper again. I dont understand how ansys regards the number of windings of the terminal.
Also I tried to use this technique to determine the current in the short cirquit (see my other post: https://forum.ansys.com/forums/topic/different-results-if-using-coil-terminal-in-shortcut/ ) but the setup behaved differently with the terminal of 1 conductor than without it.
I hope you understand my problem now and eagerly await your answer.
