Hi Lukas, are both tickets the same transformer design? Is the goal calculating the inductance on the primary winding?
If yes, there are two primary coils, do those have excitation?
From the other post, you are drawing a separate close loop for the short circuits, are you adding short circuit on the primary winding for this post? What does the real test setup look like?
