Guilin Sun
If you can use sufficient number of cells to well resolve the sllipical holes, you can try. Anyway, since you only simulate one perioid at each side of the cavity, it may work well. However, FDTD will needs to simulate the whole device. So you may try and see which one is more efficient with reasonable accuracy.
