javat33489
Thank you sir.
I did everything from the beginning. And I tried to start with one fall, but I applied acceleration, so that later I could scale it up by several falls.
It turned out like this, it works:
ANIMATION:
_________________________________________
Why is there a gap? Is it because of the pinball?
By the way, pinball affects stress, why?
Then I wanted to make a few accents, but I did not succeed. First I tried to return the part after being dropped by the displacement - it doesn't work. Then I tried to pull back the part using acceleration as you recommended earlier - that doesn't work either.
Can you tell me how to make a multiple drop?
