April 24, 2023 at 10:39 am
I recommend you to use follow the best practices video on how to simulate heat transfer of fluid through the pipe and also attached the user guide link on how to simulate the heat transfer in mixing elbow. This procedure will make your simulation run faster and convergence easier for the 500m length tube. If it still takes time please reduce and alter the under relaxation factor and check it will lead to faster convergence. Or you can use symmetry about y axis and give periodic condition and model half of the geometry .
(47) Heat Transfer in a Tube with U-Bend — Simulation Example - YouTube
Chapter 5: Fluid Flow and Heat Transfer in a Mixing Elbow (ansys.com)
Thanks
Chaitanya Natraj
