Alberto
I was explain myself badly, mesh deforms, but near the solid boundaries anything strange like too deformed tetrahedral . I was able to run this simulation two weeks ago, so i dont think it is a mesh problem or model issue.
In the .trn file also, this error occurs at each processor (i've run with 15 cores):
Updating solution at time levels N and N-1.
 done.
Updating mesh at time level N... done.
  iter  continuity  x-velocity  y-velocity  z-velocity           k       omega     time/iter
   760  9.9713e-04  1.5911e-05  1.3513e-05  1.8015e-05  2.0660e-06  1.0548e-04  0:00:45   20
   761  6.8108e-03  9.3173e-05  7.0772e-05  1.3309e-04  5.3867e-04  3.5784e-03  0:00:45   19
   762  3.6281e-03  4.8553e-05  4.0775e-05  5.7765e-05  1.2741e-04  1.6395e-03  0:00:42   18
   763  2.0489e-03  3.0135e-05  2.5671e-05  3.6498e-05  3.0753e-05  5.1376e-04  0:00:38   17
   764  1.3749e-03  2.2572e-05  1.9371e-05  2.6834e-05  7.6857e-06  2.0990e-04  0:00:38   16
   765  1.0560e-03  1.8779e-05  1.6088e-05  2.1766e-05  2.0604e-06  1.0932e-04  0:00:35   15
   766  8.5239e-04  1.6339e-05  1.3986e-05  1.8640e-05  6.4454e-07  7.1077e-05  0:00:32   14
!  766 solution is converged
  step  flow-time   flow-time        drag
   186  1.4880e-01  1.4880e-01  5.6377e-04
Flow time = 0.1487999999999995s, time step = 186
3814 more time steps
 done.
set_part_dest_tree: cell not found on myid = 7
=   BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES
=   RANK 0 PID 23216 RUNNING AT DESKTOP-C8FD4F6
=   EXIT STATUS: -1 (ffffffff)
=   RANK 1 PID 9040 RUNNING AT DESKTOP-C8FD4F6
=   RANK 2 PID 26648 RUNNING AT DESKTOP-C8FD4F6
=   RANK 3 PID 22940 RUNNING AT DESKTOP-C8FD4F6
=   RANK 4 PID 28556 RUNNING AT DESKTOP-C8FD4F6
=   RANK 5 PID 19352 RUNNING AT DESKTOP-C8FD4F6
=   RANK 6 PID 20752 RUNNING AT DESKTOP-C8FD4F6
=   RANK 7 PID 2416 RUNNING AT DESKTOP-C8FD4F6
=   RANK 8 PID 26880 RUNNING AT DESKTOP-C8FD4F6
=   EXIT STATUS: -1073740940 (c0000374)
=   RANK 9 PID 6276 RUNNING AT DESKTOP-C8FD4F6
=   RANK 10 PID 27744 RUNNING AT DESKTOP-C8FD4F6
=   RANK 11 PID 16984 RUNNING AT DESKTOP-C8FD4F6
=   RANK 12 PID 1988 RUNNING AT DESKTOP-C8FD4F6
=   RANK 13 PID 16848 RUNNING AT DESKTOP-C8FD4F6
=   RANK 14 PID 24444 RUNNING AT DESKTOP-C8FD4F6
===============Message from the Cortex Process================================
Fatal error in one of the compute processes.
Error: Cortex received a fatal signal (SEGMENTATION VIOLATION).
Error Object: ()
Error: There is no active application.
Error Object: (rp-var-value 'pdf/filename)
