Federico Alzamora Previtali
Hello Fathima,
there might be other reasons than the input values for turbulence that are causing your solution to approach these limits.
For example, a bad mesh quality could potentially cause this. You can create iso-clips of your solution to locate where these high turbulent-viscosity values occur in your domain and inspect if the mesh is appropriate in the region.
