I look at that data and I think a 6th order polynomial is a bit of an overkill. How many data points did you use to fit the data? Have you tried to simplfiy it? It won't speed up the computation much, but it can't hurt. Also, is there a reason you are not using the built-in polynomial fit in the materials tab?
