Mae Kristine Labendia
Hi Nikhil Narale
Sorry for lot of questions. I always get losed since this my first ever analysis experience. Why did my simulation contour have all same color? I had the result, from inlet temperature of 573K  and inlet velocity is 5m/s flows through 10m pipe and result temperature outlet is 571.4K but the color of my simulation are all red in contours though my solution is converged. Is it reasonable or does something wrong with my input. Pipe with water vapor and assuming drysoil sorrounds pipe. Kindly see attached. Thank you always for your help.
