Alberto
I've reinstall, now the problem of crash is solved (i think) but the model crash due to non negative volume. here my trn file transcript. Do you think i have to lower the timestep? i'm using diffusion method with coefficient = 3 (maximum)
Build Time: May 28 2021 13:53:52 EDT
Executable Path: C:/PROGRA~1/ANSYSI~1/v212/fluent/ntbin/win64/fluent.exe
ID    Hostname         Core  O.S.         PID    Vendor
n4    DESKTOP-C8FD4F6  5/80  Windows-x64  14108  Intel(R) Xeon(R) Gold 6230
n3    DESKTOP-C8FD4F6  4/80  Windows-x64  23480  Intel(R) Xeon(R) Gold 6230
n2    DESKTOP-C8FD4F6  3/80  Windows-x64  15352  Intel(R) Xeon(R) Gold 6230
n1    DESKTOP-C8FD4F6  2/80  Windows-x64  14232  Intel(R) Xeon(R) Gold 6230
n0*   DESKTOP-C8FD4F6  1/80  Windows-x64  17316  Intel(R) Xeon(R) Gold 6230
host  DESKTOP-C8FD4F6        Windows-x64  3176   Intel(R) Xeon(R) Gold 6230
MPI Option Selected: intel
Selected system interconnect: default
Cortex Process ID: 20468
License Server Path: 1055@192.168.64.92
(cx-gui-do cx-set-list-tree-selections "NavigationPane*List_Tree1" (list "Solution|Run Calculation"))
(cx-gui-do cx-activate-item "NavigationPane*List_Tree1")
(cx-gui-do cx-set-list-tree-selections "NavigationPane*List_Tree1" (list "Solution|Calculation Activities"))
(cx-gui-do cx-activate-item "Run Calculation*Table1*Table9(Solution Advancement)*Table1*PushButton1(Calculate)")
Writing Settings file "C:\Users\Alberto\Desktop\falling_seed\seed_one_files\dp0\FFF\Fluent\FFF.set"...
    writing rp variables ... Done.
    writing domain variables ... Done.
    writing fluid (type fluid) (mixture) ... Done.
    writing interior-fluid (type interior) (mixture) ... Done.
    writing walls (type wall) (mixture) ... Done.
    writing seed (type wall) (mixture) ... Done.
    writing dynamic zone fluid ... Done
    writing dynamic zone seed ... Done
    writing dynamic zone interior-fluid ... Done
    writing zones map name-id ... Done.
Fast-loading "C:\PROGRA~1\ANSYSI~1\v212\fluent\fluent21.2.0\\addons\afd\lib\hdfio.bin"
Done.
Writing to DESKTOP-C8FD4F6:"C:\Users\Alberto\Desktop\falling_seed\seed_one_files\dp0\FFF\Fluent\FFF-1-00000.cas.h5" in NODE0 mode and compression level 1 ...
  Writing mesh ...
      139800 cells,     1 zone  ...
      298818 faces,     3 zones ...
       33833 nodes,     1 zone  ...
  Done.
Done.
Writing to DESKTOP-C8FD4F6:"C:\Users\Alberto\Desktop\falling_seed\seed_one_files\dp0\FFF\Fluent\FFF-1-00000.dat.h5" in NODE0 mode and compression level 1 ...
  Writing results.
Done.
Writing to DESKTOP-C8FD4F6:"C:\Users\Alberto\Desktop\falling_seed\seed_one_files\dp0\FFF\Fluent\FFF-Setup-Output.cas.h5" in NODE0 mode and compression level 1 ...
  Writing mesh ...
  Done.
Done.
Updating solution at time levels N and N-1.
 done.
Updating mesh at time level N... done.
  iter  continuity  x-velocity  y-velocity  z-velocity           k       omega     time/iter
     1  1.0000e+00  1.5394e-03  9.2497e-04  3.2958e-02  2.5839e-04  1.2843e+02  0:00:38   19
     2  1.0000e+00  1.0300e-02  9.6514e-03  3.1551e-02  2.8132e-04  5.9805e-01  0:00:43   18
     3  1.0000e+00  3.5683e-03  3.2347e-03  9.7273e-03  1.0939e-04  3.0929e-01  0:00:39   17
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 72 cells
     4  7.1627e-01  3.6252e-03  3.2389e-03  1.2984e-02  3.8179e-05  1.1170e-01  0:00:36   16
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 766 cells
     5  3.5641e-01  3.6778e-03  3.2471e-03  9.7443e-03  1.3667e-05  4.9692e-02  0:00:33   15
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1095 cells
     6  2.3952e-01  3.3818e-03  2.9535e-03  6.2383e-03  5.4956e-06  2.9290e-02  0:00:30   14
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1228 cells
     7  2.6042e-01  2.8038e-03  2.4592e-03  4.1362e-03  2.4816e-06  1.9059e-02  0:00:28   13
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1305 cells
     8  2.7782e-01  2.0806e-03  1.8673e-03  2.6871e-03  1.2321e-06  1.3265e-02  0:00:23   12
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1358 cells
     9  2.3487e-01  1.6792e-03  1.5371e-03  2.0153e-03  6.6088e-07  9.8420e-03  0:00:21   11
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1406 cells
    10  1.6773e-01  1.3507e-03  1.2445e-03  1.5990e-03  3.7781e-07  8.0851e-03  0:00:19   10
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1435 cells
    11  1.1101e-01  1.1002e-03  1.0142e-03  1.2781e-03  2.2999e-07  6.9081e-03  0:00:18    9
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1448 cells
    12  7.4687e-02  9.3017e-04  8.4935e-04  1.0524e-03  1.4990e-07  6.0414e-03  0:00:14    8
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1461 cells
    13  5.4305e-02  8.2594e-04  7.4357e-04  9.0613e-04  1.0449e-07  5.4012e-03  0:00:13    7
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1481 cells
    14  4.2460e-02  7.4220e-04  6.6124e-04  7.9079e-04  7.7275e-08  4.9258e-03  0:00:11    6
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1496 cells
    15  3.3651e-02  6.7879e-04  6.0255e-04  7.0941e-04  5.9726e-08  4.5727e-03  0:00:09    5
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1503 cells
    16  2.6478e-02  6.3267e-04  5.6399e-04  6.5592e-04  4.7105e-08  4.3177e-03  0:00:07    4
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1509 cells
    17  2.0915e-02  5.9846e-04  5.3622e-04  6.2032e-04  3.8459e-08  4.1307e-03  0:00:05    3
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1515 cells
    18  1.6810e-02  5.7117e-04  5.1831e-04  5.9522e-04  3.2318e-08  3.9930e-03  0:00:04    2
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1520 cells
    19  1.3883e-02  5.5106e-04  5.0453e-04  5.7616e-04  2.8135e-08  3.8931e-03  0:00:02    1
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1523 cells
    20  1.1798e-02  5.3722e-04  4.9389e-04  5.6120e-04  2.5620e-08  3.8229e-03  0:00:00    0
Flow time = 0.0005s, time step = 1
3999 more time steps
 done.
    20  1.1798e-02  5.3722e-04  4.9389e-04  5.6120e-04  2.5620e-08  3.8229e-03  0:00:34   20
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1517 cells
    21  1.0246e-02  2.4675e-03  2.4064e-03  2.4517e-03  3.0641e-04  6.9201e-02  0:00:33   19
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1476 cells
    22  1.1668e-02  8.5329e-04  8.0786e-04  8.6931e-04  7.3897e-05  1.7517e-02  0:00:32   18
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1452 cells
    23  1.1647e-02  4.4248e-04  4.0350e-04  4.6468e-04  1.7656e-05  7.2321e-03  0:00:28   17
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1432 cells
    24  1.1356e-02  3.3545e-04  3.0039e-04  3.4723e-04  4.5229e-06  4.3549e-03  0:00:27   16
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1419 cells
    25  1.1001e-02  2.7400e-04  2.4682e-04  2.7919e-04  1.3250e-06  3.3592e-03  0:00:26   15
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1411 cells
    26  1.0697e-02  2.2959e-04  2.0822e-04  2.3409e-04  4.7826e-07  2.9453e-03  0:00:25   14
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1402 cells
    27  1.0391e-02  2.1136e-04  1.9168e-04  2.1748e-04  2.2364e-07  2.7383e-03  0:00:21   13
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1392 cells
    28  1.0115e-02  2.0443e-04  1.8578e-04  2.1282e-04  1.3213e-07  2.6105e-03  0:00:21   12
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1387 cells
    29  9.8508e-03  2.0877e-04  1.9008e-04  2.1775e-04  9.2324e-08  2.5253e-03  0:00:20   11
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1386 cells
    30  9.5898e-03  2.1921e-04  1.9963e-04  2.2893e-04  7.1814e-08  2.4652e-03  0:00:18   10
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1384 cells
    31  9.3302e-03  2.3261e-04  2.1214e-04  2.4278e-04  6.0077e-08  2.4185e-03  0:00:15    9
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1382 cells
    32  9.0723e-03  2.4728e-04  2.2536e-04  2.5800e-04  5.1961e-08  2.3790e-03  0:00:14    8
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1383 cells
    33  8.8183e-03  2.6178e-04  2.3788e-04  2.7286e-04  4.5732e-08  2.3462e-03  0:00:12    7
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1381 cells
    34  8.5698e-03  2.7559e-04  2.4970e-04  2.8671e-04  4.1418e-08  2.3193e-03  0:00:11    6
    35  8.3286e-03  2.8757e-04  2.5926e-04  2.9891e-04  3.7488e-08  2.2965e-03  0:00:08    5
    36  8.0953e-03  2.9772e-04  2.6721e-04  3.0956e-04  3.4309e-08  2.2774e-03  0:00:07    4
    37  7.8704e-03  3.0676e-04  2.7421e-04  3.1908e-04  3.1862e-08  2.2610e-03  0:00:05    3
    38  7.6542e-03  3.1458e-04  2.8018e-04  3.2695e-04  3.0002e-08  2.2464e-03  0:00:04    2
    39  7.4470e-03  3.2013e-04  2.8464e-04  3.3248e-04  2.7920e-08  2.2323e-03  0:00:02    1
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1380 cells
    40  7.2483e-03  3.2435e-04  2.8820e-04  3.3670e-04  2.6104e-08  2.2210e-03  0:00:00    0
Flow time = 0.001s, time step = 2
3998 more time steps
 done.
    40  7.2483e-03  3.2435e-04  2.8820e-04  3.3670e-04  2.6104e-08  2.2210e-03  0:00:35   20
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1314 cells
    41  7.1056e-03  1.9999e-03  1.9471e-03  4.8915e-03  3.9244e-04  5.6901e-02  0:00:34   19
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1271 cells
    42  8.1135e-03  7.9265e-04  7.4149e-04  1.5379e-03  8.7552e-05  1.4163e-02  0:00:29   18
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1242 cells
    43  8.1759e-03  4.8964e-04  4.3840e-04  6.9272e-04  1.9591e-05  4.6063e-03  0:00:29   17
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1220 cells
    44  8.0154e-03  4.7084e-04  4.1917e-04  5.2960e-04  4.5858e-06  2.2498e-03  0:00:28   16
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1207 cells
    45  7.7958e-03  4.4177e-04  3.9691e-04  4.6690e-04  1.1824e-06  1.5362e-03  0:00:27   15
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1202 cells
    46  7.5872e-03  4.1486e-04  3.7717e-04  4.3392e-04  3.6599e-07  1.2662e-03  0:00:26   14
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1193 cells
    47  7.3960e-03  3.9025e-04  3.5729e-04  4.0777e-04  1.5075e-07  1.1358e-03  0:00:24   13
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1185 cells
    48  7.2183e-03  3.6726e-04  3.3723e-04  3.8361e-04  8.5942e-08  1.0539e-03  0:00:20   12
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1183 cells
    49  7.0504e-03  3.4644e-04  3.1887e-04  3.6197e-04  5.9994e-08  9.9476e-04  0:00:19   11
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1181 cells
    50  6.8946e-03  3.1343e-04  2.8906e-04  3.2724e-04  4.6995e-08  9.5108e-04  0:00:18   10
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1178 cells
    51  6.7403e-03  3.1088e-04  2.8596e-04  3.2509e-04  4.0209e-08  9.1339e-04  0:00:17    9
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1177 cells
    52  6.5901e-03  2.9671e-04  2.7265e-04  3.0999e-04  3.4978e-08  8.8165e-04  0:00:13    8
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1176 cells
    53  6.4501e-03  2.7314e-04  2.5078e-04  2.8469e-04  3.0639e-08  8.5694e-04  0:00:12    7
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1171 cells
    54  6.3073e-03  2.7338e-04  2.5030e-04  2.8491e-04  2.8316e-08  8.3346e-04  0:00:11    6
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1170 cells
    55  6.1690e-03  2.6352e-04  2.4138e-04  2.7463e-04  2.5861e-08  8.1280e-04  0:00:09    5
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1168 cells
    56  6.0404e-03  2.4421e-04  2.2441e-04  2.5439e-04  2.3476e-08  7.9696e-04  0:00:07    4
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1166 cells
    57  5.9080e-03  2.4547e-04  2.2553e-04  2.5602e-04  2.2377e-08  7.8011e-04  0:00:05    3
    58  5.7859e-03  2.2803e-04  2.0995e-04  2.3777e-04  2.0681e-08  7.6527e-04  0:00:04    2
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1165 cells
    59  5.6598e-03  2.3031e-04  2.1150e-04  2.4062e-04  1.8796e-08  7.5352e-04  0:00:02    1
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1164 cells
    60  5.5439e-03  2.1449e-04  1.9745e-04  2.2385e-04  1.8305e-08  7.4134e-04  0:00:00    0
Flow time = 0.0015s, time step = 3
3997 more time steps
 done.
    60  5.5439e-03  2.1449e-04  1.9745e-04  2.2385e-04  1.8305e-08  7.4134e-04  0:00:34   20
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1048 cells
    61  5.3752e-03  2.6850e-03  2.6305e-03  7.1013e-03  3.9329e-04  4.8751e-02  0:00:37   19
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 990 cells
    62  5.2691e-03  1.1215e-03  1.0628e-03  2.3898e-03  8.6664e-05  1.2259e-02  0:00:32   18
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 952 cells
    63  5.1838e-03  6.5477e-04  5.9652e-04  1.0076e-03  1.9279e-05  3.8895e-03  0:00:31   17
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 929 cells
    64  4.9987e-03  5.9478e-04  5.3289e-04  6.8030e-04  4.5056e-06  1.8012e-03  0:00:30   16
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 915 cells
    65  4.8348e-03  4.8170e-04  4.3435e-04  5.0686e-04  1.1664e-06  1.1912e-03  0:00:25   15
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 903 cells
    66  4.7104e-03  4.2486e-04  3.8509e-04  4.4133e-04  3.6648e-07  9.6514e-04  0:00:24   14
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 896 cells
    67  4.6054e-03  3.7560e-04  3.4219e-04  3.8937e-04  1.5558e-07  8.5631e-04  0:00:23   13
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 894 cells
    68  4.5111e-03  3.3428e-04  3.0535e-04  3.4565e-04  9.0563e-08  7.9059e-04  0:00:20   12
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 893 cells
    69  4.4237e-03  2.9901e-04  2.7422e-04  3.0898e-04  6.4076e-08  7.4370e-04  0:00:19   11
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 890 cells
    70  4.3415e-03  2.6954e-04  2.4812e-04  2.7860e-04  5.1021e-08  7.0748e-04  0:00:18   10
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 888 cells
    71  4.2635e-03  2.4530e-04  2.2641e-04  2.5385e-04  4.3171e-08  6.7753e-04  0:00:15    9
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 887 cells
    72  4.1889e-03  2.2505e-04  2.0820e-04  2.3299e-04  3.7915e-08  6.5230e-04  0:00:14    8
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 886 cells
    73  4.1170e-03  2.0795e-04  1.9288e-04  2.1530e-04  3.4011e-08  6.2995e-04  0:00:11    7
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 884 cells
    74  4.0476e-03  1.9346e-04  1.7992e-04  2.0031e-04  3.1021e-08  6.1020e-04  0:00:10    6
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 883 cells
    75  3.9805e-03  1.8106e-04  1.6889e-04  1.8746e-04  2.8522e-08  5.9197e-04  0:00:09    5
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 882 cells
    76  3.9154e-03  1.7033e-04  1.5934e-04  1.7631e-04  2.6454e-08  5.7550e-04  0:00:06    4
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 881 cells
    77  3.8523e-03  1.6106e-04  1.5113e-04  1.6676e-04  2.4534e-08  5.6004e-04  0:00:05    3
    78  3.7910e-03  1.5291e-04  1.4388e-04  1.5840e-04  2.2858e-08  5.4604e-04  0:00:03    2
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 877 cells
    79  3.7315e-03  1.4575e-04  1.3744e-04  1.5106e-04  2.1315e-08  5.3288e-04  0:00:02    1
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 875 cells
    80  3.6737e-03  1.3944e-04  1.3173e-04  1.4470e-04  2.0073e-08  5.2098e-04  0:00:00    0
Flow time = 0.002s, time step = 4
3996 more time steps
 done.
    80  3.6737e-03  1.3944e-04  1.3173e-04  1.4470e-04  2.0073e-08  5.2098e-04  0:00:33   20
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 722 cells
    81  3.6275e-03  5.7943e-03  5.6961e-03  1.1552e-02  3.9396e-04  4.3967e-02  0:00:37   19
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 667 cells
    82  4.8618e-03  1.9111e-03  1.8540e-03  3.5771e-03  8.6265e-05  1.0898e-02  0:00:31   18
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 636 cells
    83  5.0737e-03  7.1437e-04  6.7904e-04  1.1600e-03  1.9163e-05  3.3124e-03  0:00:31   17
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 618 cells
    84  5.0193e-03  4.0882e-04  3.8655e-04  5.2193e-04  4.4898e-06  1.4422e-03  0:00:29   16
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 605 cells
    85  4.9089e-03  3.2853e-04  3.1279e-04  3.5961e-04  1.1707e-06  9.2359e-04  0:00:25   15
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 600 cells
    86  4.7969e-03  2.8829e-04  2.7639e-04  3.0523e-04  3.7136e-07  7.4937e-04  0:00:24   14
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 599 cells
    87  4.6927e-03  2.5863e-04  2.4902e-04  2.7242e-04  1.5992e-07  6.7264e-04  0:00:21   13
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 596 cells
    88  4.5946e-03  2.3558e-04  2.2721e-04  2.4723e-04  9.3063e-08  6.2789e-04  0:00:20   12
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 593 cells
    89  4.5009e-03  2.1781e-04  2.1010e-04  2.2784e-04  6.4740e-08  5.9751e-04  0:00:19   11
    90  4.4108e-03  2.0402e-04  1.9674e-04  2.1278e-04  5.1780e-08  5.7294e-04  0:00:16   10
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 592 cells
    91  4.3233e-03  1.9311e-04  1.8631e-04  2.0068e-04  4.3334e-08  5.5184e-04  0:00:15    9
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 590 cells
    92  4.2383e-03  1.8436e-04  1.7811e-04  1.9115e-04  3.6963e-08  5.3438e-04  0:00:14    8
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 589 cells
    93  4.1553e-03  1.7705e-04  1.7141e-04  1.8336e-04  3.3679e-08  5.1771e-04  0:00:11    7
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 586 cells
    94  4.0744e-03  1.7081e-04  1.6582e-04  1.7676e-04  3.0291e-08  5.0179e-04  0:00:10    6
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 584 cells
    95  3.9954e-03  1.6530e-04  1.6089e-04  1.7092e-04  2.6908e-08  4.8792e-04  0:00:09    5
    96  3.9182e-03  1.6028e-04  1.5639e-04  1.6569e-04  2.5554e-08  4.7403e-04  0:00:06    4
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 583 cells
    97  3.8430e-03  1.5574e-04  1.5225e-04  1.6108e-04  2.3622e-08  4.6050e-04  0:00:05    3
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 582 cells
    98  3.7695e-03  1.5158e-04  1.4836e-04  1.5696e-04  2.1460e-08  4.4879e-04  0:00:03    2
    99  3.6979e-03  1.4766e-04  1.4464e-04  1.5314e-04  2.1113e-08  4.3679e-04  0:00:02    1
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 581 cells
   100  3.6282e-03  1.4398e-04  1.4113e-04  1.4950e-04  1.9804e-08  4.2478e-04  0:00:00    0
Flow time = 0.0025s, time step = 5
3995 more time steps
 done.
>> Dividing domain into 5 partitions using Metis.
   Time = 0.222 seconds.
   Done.
>> 5 Stored Partitions:
   Collective Partition Statistics:        Minimum   Maximum   Total
   Cell count                              70854     70876     354309
   Mean cell count deviation               -0.0%     0.0%
   Partition boundary cell count           1832      3024      11541
   Partition boundary cell count ratio     2.6%      4.3%      3.3%
   Face count                              146129    147869    727836
   Mean face count deviation               -0.5%     0.7%
   Partition boundary face count           2063      3373      6404
   Partition boundary face count ratio     1.4%      2.3%      0.9%
   Cell weights                            7e+05     7e+05     4e+06
   Mean cell weight deviation              -0.0%     0.0%
   Partition neighbor count                4         4
   Partition Method                        Metis
   Stored Partition Count                  5
Done.
   Smoothing partition boundaries...
done.
   100  3.6282e-03  1.4398e-04  1.4113e-04  1.4950e-04  1.9804e-08  4.2478e-04  0:00:34   20
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 488 cells
   101  3.7213e-03  4.0668e-03  3.9201e-03  1.5643e-02  3.9482e-04  4.0493e-02  0:00:34   19
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 448 cells
   102  4.6129e-03  1.1915e-03  1.1387e-03  4.2909e-03  8.6139e-05  9.8682e-03  0:00:29   18
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 429 cells
   103  4.7651e-03  4.2016e-04  3.9924e-04  1.2124e-03  1.9142e-05  2.8904e-03  0:00:25   17
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 420 cells
   104  4.7117e-03  2.5111e-04  2.4164e-04  4.2246e-04  4.4946e-06  1.1928e-03  0:00:22   16
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 415 cells
   105  4.6099e-03  2.1867e-04  2.1318e-04  2.5149e-04  1.1757e-06  7.3644e-04  0:00:20   15
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 414 cells
   106  4.5041e-03  2.0398e-04  2.0024e-04  2.1741e-04  3.7488e-07  5.8916e-04  0:00:20   14
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 413 cells
   107  4.4016e-03  1.9326e-04  1.9028e-04  2.0385e-04  1.6088e-07  5.2623e-04  0:00:18   13
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 412 cells
   108  4.3032e-03  1.8497e-04  1.8246e-04  1.9440e-04  9.3839e-08  4.8943e-04  0:00:15   12
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 411 cells
   109  4.2086e-03  1.7832e-04  1.7607e-04  1.8706e-04  6.6219e-08  4.6229e-04  0:00:14   11
   110  4.1175e-03  1.7262e-04  1.7067e-04  1.8082e-04  5.2050e-08  4.3957e-04  0:00:12   10
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 409 cells
   111  4.0296e-03  1.6746e-04  1.6577e-04  1.7534e-04  4.3367e-08  4.1950e-04  0:00:10    9
   112  3.9447e-03  1.6278e-04  1.6127e-04  1.7027e-04  3.7555e-08  4.0152e-04  0:00:11    8
   113  3.8626e-03  1.5839e-04  1.5707e-04  1.6564e-04  3.3250e-08  3.8520e-04  0:00:09    7
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 408 cells
   114  3.7831e-03  1.5432e-04  1.5297e-04  1.6123e-04  2.9670e-08  3.6994e-04  0:00:07    6
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 407 cells
   115  3.7061e-03  1.5046e-04  1.4902e-04  1.5705e-04  2.6838e-08  3.5618e-04  0:00:06    5
   116  3.6315e-03  1.4681e-04  1.4526e-04  1.5308e-04  2.4437e-08  3.4360e-04  0:00:05    4
   117  3.5594e-03  1.4330e-04  1.4166e-04  1.4936e-04  2.2244e-08  3.3202e-04  0:00:04    3
   118  3.4896e-03  1.3987e-04  1.3820e-04  1.4575e-04  2.0505e-08  3.2145e-04  0:00:02    2
   119  3.4222e-03  1.3657e-04  1.3485e-04  1.4220e-04  1.8881e-08  3.1164e-04  0:00:01    1
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 406 cells
   120  3.3570e-03  1.3339e-04  1.3163e-04  1.3884e-04  1.7429e-08  3.0257e-04  0:00:00    0
Flow time = 0.003s, time step = 6
3994 more time steps
 done.
   120  3.3570e-03  1.3339e-04  1.3163e-04  1.3884e-04  1.7429e-08  3.0257e-04  0:00:23   20
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 332 cells
   121  3.5092e-03  2.4134e-03  2.3255e-03  1.5813e-02  3.9580e-04  3.7707e-02  0:00:21   19
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 309 cells
   122  3.4129e-03  7.2594e-04  6.9376e-04  4.2005e-03  8.6152e-05  9.0503e-03  0:00:23   18
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 288 cells
   123  3.4016e-03  3.0547e-04  2.9077e-04  1.1733e-03  1.9167e-05  2.5428e-03  0:00:21   17
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 274 cells
   124  3.3612e-03  2.1577e-04  2.0855e-04  3.9850e-04  4.5146e-06  9.6780e-04  0:00:19   16
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 270 cells
   125  3.3007e-03  1.8711e-04  1.8265e-04  2.2440e-04  1.1883e-06  5.5129e-04  0:00:17   15
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 268 cells
   126  3.2396e-03  1.6960e-04  1.6655e-04  1.8799e-04  3.8226e-07  4.2355e-04  0:00:16   14
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 266 cells
   127  3.1825e-03  1.5711e-04  1.5460e-04  1.7203e-04  1.6460e-07  3.7276e-04  0:00:14   13
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 264 cells
   128  3.1288e-03  1.4776e-04  1.4547e-04  1.6034e-04  9.5216e-08  3.4674e-04  0:00:15   12
   129  3.0777e-03  1.4044e-04  1.3825e-04  1.5099e-04  6.6250e-08  3.2882e-04  0:00:13   11
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 263 cells
   130  3.0286e-03  1.3455e-04  1.3235e-04  1.4343e-04  5.1632e-08  3.1569e-04  0:00:12   10
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 262 cells
   131  2.9813e-03  1.2963e-04  1.2741e-04  1.3725e-04  4.2878e-08  3.0387e-04  0:00:10    9
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 261 cells
   132  2.9357e-03  1.2537e-04  1.2321e-04  1.3210e-04  3.6798e-08  2.9422e-04  0:00:09    8
   133  2.8916e-03  1.2163e-04  1.1956e-04  1.2770e-04  3.2375e-08  2.8469e-04  0:00:08    7
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 260 cells
   134  2.8491e-03  1.1829e-04  1.1633e-04  1.2386e-04  2.9053e-08  2.7680e-04  0:00:06    6
   135  2.8081e-03  1.1528e-04  1.1346e-04  1.2048e-04  2.6312e-08  2.6864e-04  0:00:06    5
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 258 cells
   136  2.7686e-03  1.1252e-04  1.1083e-04  1.1746e-04  2.4059e-08  2.6166e-04  0:00:05    4
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 257 cells
   137  2.7306e-03  1.0998e-04  1.0842e-04  1.1472e-04  2.2447e-08  2.5419e-04  0:00:03    3
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 256 cells
   138  2.6940e-03  1.0763e-04  1.0618e-04  1.1220e-04  2.0705e-08  2.4780e-04  0:00:02    2
   139  2.6589e-03  1.0544e-04  1.0409e-04  1.0987e-04  1.8953e-08  2.4066e-04  0:00:01    1
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 255 cells
   140  2.6252e-03  1.0344e-04  1.0217e-04  1.0775e-04  1.7633e-08  2.3476e-04  0:00:00    0
Flow time = 0.0035s, time step = 7
3993 more time steps
 done.
   140  2.6252e-03  1.0344e-04  1.0217e-04  1.0775e-04  1.7633e-08  2.3476e-04  0:00:26   20
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 214 cells
   141  2.8288e-03  3.6231e-03  3.5021e-03  1.3539e-02  3.9671e-04  3.5334e-02  0:00:27   19
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 197 cells
   142  3.2665e-03  1.0481e-03  1.0088e-03  3.6279e-03  8.6240e-05  8.3602e-03  0:00:24   18
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 190 cells
   143  3.3481e-03  3.8470e-04  3.7127e-04  1.0327e-03  1.9212e-05  2.2641e-03  0:00:22   17
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 180 cells
   144  3.3247e-03  2.3545e-04  2.3025e-04  3.7262e-04  4.5354e-06  8.0654e-04  0:00:23   16
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 178 cells
   145  3.2603e-03  2.0118e-04  1.9778e-04  2.2996e-04  1.1963e-06  4.3217e-04  0:00:20   15
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 176 cells
   146  3.1890e-03  1.8537e-04  1.8230e-04  2.0112e-04  3.8450e-07  3.2299e-04  0:00:18   14
   147  3.1228e-03  1.7449e-04  1.7163e-04  1.8711e-04  1.6480e-07  2.8330e-04  0:00:16   13
   148  3.0616e-03  1.6656e-04  1.6385e-04  1.7712e-04  9.4744e-08  2.6398e-04  0:00:14   12
   149  3.0040e-03  1.6057e-04  1.5809e-04  1.6969e-04  6.5509e-08  2.5164e-04  0:00:13   11
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 175 cells
   150  2.9491e-03  1.5585e-04  1.5358e-04  1.6402e-04  5.1111e-08  2.4229e-04  0:00:13   10
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 174 cells
   151  2.8966e-03  1.5196e-04  1.4987e-04  1.5953e-04  4.2378e-08  2.3439e-04  0:00:11    9
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 173 cells
   152  2.8464e-03  1.4859e-04  1.4664e-04  1.5579e-04  3.6197e-08  2.2733e-04  0:00:10    8
   153  2.7982e-03  1.4558e-04  1.4373e-04  1.5250e-04  3.1557e-08  2.2086e-04  0:00:08    7
   154  2.7520e-03  1.4278e-04  1.4107e-04  1.4951e-04  2.7734e-08  2.1476e-04  0:00:07    6
   155  2.7078e-03  1.4016e-04  1.3861e-04  1.4675e-04  2.4601e-08  2.0897e-04  0:00:06    5
   156  2.6653e-03  1.3771e-04  1.3630e-04  1.4419e-04  2.2084e-08  2.0347e-04  0:00:05    4
   157  2.6244e-03  1.3535e-04  1.3408e-04  1.4173e-04  2.0006e-08  1.9821e-04  0:00:04    3
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 171 cells
   158  2.5849e-03  1.3305e-04  1.3193e-04  1.3934e-04  1.8256e-08  1.9315e-04  0:00:02    2
   159  2.5468e-03  1.3079e-04  1.2981e-04  1.3700e-04  1.6794e-08  1.8827e-04  0:00:01    1
   160  2.5099e-03  1.2863e-04  1.2776e-04  1.3471e-04  1.5647e-08  1.8357e-04  0:00:00    0
Flow time = 0.004s, time step = 8
3992 more time steps
 done.
   160  2.5099e-03  1.2863e-04  1.2776e-04  1.3471e-04  1.5647e-08  1.8357e-04  0:00:22   20
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 144 cells
   161  2.7172e-03  1.9624e-03  1.8703e-03  1.0534e-02  3.9750e-04  3.3264e-02  0:00:25   19
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 128 cells
   162  2.7223e-03  6.8900e-04  6.5493e-04  3.1201e-03  8.6338e-05  7.7949e-03  0:00:22   18
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 123 cells
   163  2.6524e-03  3.3268e-04  3.2048e-04  9.5569e-04  1.9257e-05  2.0588e-03  0:00:20   17
   164  2.5857e-03  2.5865e-04  2.5322e-04  3.9443e-04  4.5562e-06  6.9849e-04  0:00:18   16
   165  2.5093e-03  2.3498e-04  2.3111e-04  2.6619e-04  1.2039e-06  3.5383e-04  0:00:17   15
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 121 cells
   166  2.4347e-03  2.1972e-04  2.1640e-04  2.3517e-04  3.8688e-07  2.5556e-04  0:00:18   14
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 120 cells
   167  2.3689e-03  2.0781e-04  2.0488e-04  2.1991e-04  1.6543e-07  2.2074e-04  0:00:16   13
   168  2.3100e-03  1.9814e-04  1.9559e-04  2.0851e-04  9.4814e-08  2.0387e-04  0:00:14   12
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 118 cells
   169  2.2559e-03  1.9008e-04  1.8789e-04  1.9931e-04  6.5253e-08  1.9299e-04  0:00:13   11
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 117 cells
   170  2.2053e-03  1.8315e-04  1.8128e-04  1.9165e-04  5.0410e-08  1.8462e-04  0:00:11   10
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 115 cells
   171  2.1576e-03  1.7705e-04  1.7544e-04  1.8502e-04  4.1619e-08  1.7759e-04  0:00:12    9
   172  2.1127e-03  1.7158e-04  1.7015e-04  1.7912e-04  3.5571e-08  1.7142e-04  0:00:10    8
   173  2.0703e-03  1.6660e-04  1.6529e-04  1.7381e-04  3.0946e-08  1.6582e-04  0:00:08    7
   174  2.0304e-03  1.6200e-04  1.6081e-04  1.6894e-04  2.7002e-08  1.6067e-04  0:00:07    6
   175  1.9927e-03  1.5770e-04  1.5662e-04  1.6442e-04  2.3805e-08  1.5596e-04  0:00:06    5
   176  1.9572e-03  1.5361e-04  1.5266e-04  1.6019e-04  2.1217e-08  1.5170e-04  0:00:05    4
   177  1.9237e-03  1.4970e-04  1.4885e-04  1.5620e-04  1.9113e-08  1.4777e-04  0:00:04    3
   178  1.8922e-03  1.4597e-04  1.4522e-04  1.5240e-04  1.7402e-08  1.4410e-04  0:00:02    2
   179  1.8626e-03  1.4241e-04  1.4177e-04  1.4876e-04  1.5868e-08  1.4059e-04  0:00:01    1
   180  1.8350e-03  1.3901e-04  1.3846e-04  1.4528e-04  1.4500e-08  1.3720e-04  0:00:00    0
Flow time = 0.004500000000000001s, time step = 9
3991 more time steps
 done.
   180  1.8350e-03  1.3901e-04  1.3846e-04  1.4528e-04  1.4500e-08  1.3720e-04  0:00:26   20
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 100 cells
   181  2.0639e-03  3.9635e-03  3.8713e-03  1.7879e-02  3.9812e-04  3.1447e-02  0:00:23   19
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 91 cells
   182  1.7726e-03  1.4607e-03  1.4222e-03  5.9272e-03  8.6438e-05  7.3387e-03  0:00:21   18
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 88 cells
   183  1.6077e-03  6.0706e-04  5.8977e-04  1.8074e-03  1.9304e-05  1.8962e-03  0:00:23   17
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 86 cells
   184  1.5348e-03  3.9228e-04  3.8274e-04  6.6840e-04  4.5756e-06  6.1150e-04  0:00:20   16
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 83 cells
   185  1.4700e-03  3.2278e-04  3.1490e-04  3.8319e-04  1.2116e-06  2.8895e-04  0:00:18   15
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 80 cells
   186  1.4139e-03  2.8194e-04  2.7514e-04  3.0713e-04  3.8992e-07  1.9929e-04  0:00:16   14
   187  1.3696e-03  2.5167e-04  2.4583e-04  2.7124e-04  1.6665e-07  1.6932e-04  0:00:15   13
   188  1.3335e-03  2.2833e-04  2.2314e-04  2.4549e-04  9.5284e-08  1.5613e-04  0:00:16   12
   189  1.3022e-03  2.0986e-04  2.0521e-04  2.2513e-04  6.5165e-08  1.4838e-04  0:00:14   11
   190  1.2741e-03  1.9495e-04  1.9077e-04  2.0858e-04  4.9998e-08  1.4276e-04  0:00:12   10
   191  1.2485e-03  1.8258e-04  1.7885e-04  1.9486e-04  4.0854e-08  1.3813e-04  0:00:12    9
   192  1.2249e-03  1.7206e-04  1.6874e-04  1.8329e-04  3.4370e-08  1.3402e-04  0:00:10    8
   193  1.2032e-03  1.6292e-04  1.5996e-04  1.7328e-04  2.9511e-08  1.3031e-04  0:00:09    7
   194  1.1831e-03  1.5484e-04  1.5223e-04  1.6452e-04  2.5732e-08  1.2694e-04  0:00:07    6
   195  1.1647e-03  1.4762e-04  1.4530e-04  1.5674e-04  2.2694e-08  1.2384e-04  0:00:06    5
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 78 cells
   196  1.1477e-03  1.4109e-04  1.3906e-04  1.4972e-04  2.0318e-08  1.2098e-04  0:00:05    4
   197  1.1322e-03  1.3518e-04  1.3338e-04  1.4338e-04  1.8524e-08  1.1831e-04  0:00:04    3
   198  1.1181e-03  1.2975e-04  1.2819e-04  1.3755e-04  1.6712e-08  1.1572e-04  0:00:02    2
   199  1.1052e-03  1.2477e-04  1.2340e-04  1.3217e-04  1.4930e-08  1.1331e-04  0:00:01    1
   200  1.0935e-03  1.2017e-04  1.1894e-04  1.2720e-04  1.3322e-08  1.1106e-04  0:00:00    0
Flow time = 0.005000000000000001s, time step = 10
3990 more time steps
 done.
   200  1.0935e-03  1.2017e-04  1.1894e-04  1.2720e-04  1.3322e-08  1.1106e-04  0:00:23   20
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 71 cells
   201  1.4057e-03  6.9893e-03  6.7858e-03  3.4997e-02  3.9855e-04  2.9897e-02  0:00:21   19
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 67 cells
   202  1.2787e-03  2.6430e-03  2.5590e-03  1.2316e-02  8.6526e-05  7.0101e-03  0:00:23   18
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 64 cells
   203  1.1687e-03  9.6695e-04  9.3193e-04  3.5950e-03  1.9345e-05  1.7835e-03  0:00:21   17
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 63 cells
   204  1.1202e-03  5.3016e-04  5.1249e-04  1.1662e-03  4.5925e-06  5.5688e-04  0:00:19   16
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 61 cells
   205  1.0745e-03  4.0937e-04  3.9677e-04  5.4578e-04  1.2175e-06  2.5163e-04  0:00:17   15
   206  1.0353e-03  3.4655e-04  3.3647e-04  3.8376e-04  3.9179e-07  1.6818e-04  0:00:16   14
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 60 cells
   207  1.0057e-03  3.0133e-04  2.9323e-04  3.2293e-04  1.6687e-07  1.4101e-04  0:00:14   13
   208  9.8235e-04  2.6681e-04  2.6012e-04  2.8454e-04  9.4775e-08  1.2939e-04  0:00:13   12
!  208 solution is converged
Flow time = 0.005500000000000001s, time step = 11
3989 more time steps
 done.
   208  9.8235e-04  2.6681e-04  2.6012e-04  2.8454e-04  9.4775e-08  1.2939e-04  0:00:21   20
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 58 cells
   209  1.3222e-03  9.0554e-03  8.7845e-03  5.6668e-02  3.9873e-04  2.8606e-02  0:00:24   19
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 55 cells
   210  1.7842e-03  2.4817e-03  2.3979e-03  1.4378e-02  8.6566e-05  6.8500e-03  0:00:22   18
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 54 cells
   211  1.8239e-03  8.0370e-04  7.7499e-04  3.5616e-03  1.9365e-05  1.7275e-03  0:00:20   17
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 53 cells
   212  1.8046e-03  4.6579e-04  4.5297e-04  1.0819e-03  4.5971e-06  5.3247e-04  0:00:18   16
   213  1.7591e-03  3.8429e-04  3.7582e-04  4.9827e-04  1.2153e-06  2.3609e-04  0:00:17   15
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 52 cells
   214  1.7086e-03  3.4224e-04  3.3578e-04  3.7470e-04  3.8765e-07  1.5561e-04  0:00:15   14
   215  1.6631e-03  3.1210e-04  3.0685e-04  3.3596e-04  1.6273e-07  1.2956e-04  0:00:16   13
   216  1.6224e-03  2.8936e-04  2.8508e-04  3.0980e-04  9.1164e-08  1.1830e-04  0:00:15   12
   217  1.5848e-03  2.7230e-04  2.6860e-04  2.8961e-04  6.1180e-08  1.1163e-04  0:00:13   11
   218  1.5495e-03  2.5906e-04  2.5579e-04  2.7376e-04  4.6129e-08  1.0674e-04  0:00:11   10
   219  1.5158e-03  2.4852e-04  2.4572e-04  2.6115e-04  3.7037e-08  1.0275e-04  0:00:10    9
   220  1.4834e-03  2.3998e-04  2.3752e-04  2.5088e-04  3.0834e-08  9.9322e-05  0:00:09    8
   221  1.4522e-03  2.3282e-04  2.3060e-04  2.4241e-04  2.6172e-08  9.6275e-05  0:00:07    7
   222  1.4219e-03  2.2672e-04  2.2473e-04  2.3529e-04  2.2498e-08  9.3433e-05  0:00:08    6
   223  1.3925e-03  2.2133e-04  2.1954e-04  2.2920e-04  1.9549e-08  9.0727e-05  0:00:06    5
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 51 cells
   224  1.3639e-03  2.1654e-04  2.1494e-04  2.2391e-04  1.7130e-08  8.8132e-05  0:00:05    4
   225  1.3361e-03  2.1208e-04  2.1075e-04  2.1915e-04  1.5116e-08  8.5648e-05  0:00:03    3
   226  1.3090e-03  2.0794e-04  2.0683e-04  2.1485e-04  1.3463e-08  8.3273e-05  0:00:03    2
   227  1.2826e-03  2.0407e-04  2.0318e-04  2.1088e-04  1.2025e-08  8.1010e-05  0:00:01    1
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 50 cells
   228  1.2569e-03  2.0038e-04  1.9965e-04  2.0716e-04  1.0774e-08  7.8916e-05  0:00:00    0
Flow time = 0.006000000000000002s, time step = 12
3988 more time steps
 done.
   228  1.2569e-03  2.0038e-04  1.9965e-04  2.0716e-04  1.0774e-08  7.8916e-05  0:00:24   20
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 46 cells
   229  1.7753e-03  2.8031e-03  2.7581e-03  5.6505e-02  3.9884e-04  2.7692e-02  0:00:26   19
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 39 cells
   230  1.8083e-03  6.5105e-04  6.2867e-04  1.0524e-02  8.6635e-05  6.8444e-03  0:00:23   18
   231  1.6681e-03  2.9554e-04  2.8230e-04  2.5823e-03  1.9409e-05  1.7112e-03  0:00:21   17
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 37 cells
   232  1.5987e-03  2.2385e-04  2.1613e-04  7.2687e-04  4.6198e-06  5.0840e-04  0:00:19   16
   233  1.5408e-03  1.9982e-04  1.9464e-04  2.7945e-04  1.2268e-06  2.0733e-04  0:00:17   15
   234  1.4877e-03  1.8509e-04  1.8128e-04  2.0251e-04  3.9432e-07  1.2578e-04  0:00:18   14
   235  1.4448e-03  1.7427e-04  1.7130e-04  1.8592e-04  1.6706e-07  1.0012e-04  0:00:16   13
   236  1.4093e-03  1.6584e-04  1.6345e-04  1.7608e-04  9.4105e-08  8.9700e-05  0:00:14   12
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 36 cells
   237  1.3781e-03  1.5903e-04  1.5710e-04  1.6825e-04  6.3366e-08  8.3950e-05  0:00:13   11
   238  1.3499e-03  1.5337e-04  1.5177e-04  1.6167e-04  4.8129e-08  7.9950e-05  0:00:11   10
   239  1.3237e-03  1.4851e-04  1.4712e-04  1.5607e-04  3.8696e-08  7.6773e-05  0:00:10    9
   240  1.2991e-03  1.4422e-04  1.4302e-04  1.5122e-04  3.1903e-08  7.4130e-05  0:00:09    8
   241  1.2757e-03  1.4035e-04  1.3928e-04  1.4689e-04  2.6856e-08  7.1959e-05  0:00:07    7
   242  1.2533e-03  1.3679e-04  1.3583e-04  1.4299e-04  2.2950e-08  7.0154e-05  0:00:08    6
   243  1.2317e-03  1.3347e-04  1.3264e-04  1.3941e-04  1.9838e-08  6.8626e-05  0:00:06    5
   244  1.2107e-03  1.3034e-04  1.2966e-04  1.3613e-04  1.7332e-08  6.7307e-05  0:00:05    4
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 35 cells
   245  1.1904e-03  1.2735e-04  1.2682e-04  1.3304e-04  1.5327e-08  6.6134e-05  0:00:03    3
   246  1.1707e-03  1.2448e-04  1.2407e-04  1.3009e-04  1.3538e-08  6.5040e-05  0:00:03    2
   247  1.1515e-03  1.2176e-04  1.2142e-04  1.2729e-04  1.1958e-08  6.4012e-05  0:00:01    1
   248  1.1329e-03  1.1919e-04  1.1889e-04  1.2459e-04  1.0646e-08  6.3115e-05  0:00:00    0
Flow time = 0.006500000000000002s, time step = 13
3987 more time steps
 done.
   248  1.1329e-03  1.1919e-04  1.1889e-04  1.2459e-04  1.0646e-08  6.3115e-05  0:00:24   20
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 31 cells
   249  1.9637e-03  2.8665e-03  2.7469e-03  3.3314e-02  3.9885e-04  2.7024e-02  0:00:26   19
   250  1.8630e-03  7.0427e-04  6.6858e-04  7.0074e-03  8.6701e-05  6.7245e-03  0:00:23   18
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 30 cells
   251  1.6891e-03  2.7951e-04  2.6321e-04  1.7901e-03  1.9446e-05  1.6899e-03  0:00:21   17
   252  1.6019e-03  1.8367e-04  1.7457e-04  5.2251e-04  4.6340e-06  4.9509e-04  0:00:19   16
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 29 cells
   253  1.5360e-03  1.5306e-04  1.4695e-04  2.1538e-04  1.2315e-06  1.9321e-04  0:00:17   15
   254  1.4782e-03  1.3563e-04  1.3107e-04  1.5171e-04  3.9578e-07  1.1167e-04  0:00:16   14
   255  1.4373e-03  1.2315e-04  1.1950e-04  1.3356e-04  1.6746e-07  8.6694e-05  0:00:14   13
   256  1.4100e-03  1.1360e-04  1.1055e-04  1.2263e-04  9.4065e-08  7.7187e-05  0:00:13   12
   257  1.3902e-03  1.0607e-04  1.0347e-04  1.1416e-04  6.2979e-08  7.2345e-05  0:00:14   11
   258  1.3747e-03  9.9980e-05  9.7773e-05  1.0728e-04  4.7202e-08  6.9150e-05  0:00:12   10
   259  1.3624e-03  9.4921e-05  9.3039e-05  1.0159e-04  3.7568e-08  6.6677e-05  0:00:10    9
   260  1.3520e-03  9.0647e-05  8.9041e-05  9.6801e-05  3.0915e-08  6.4610e-05  0:00:09    8
   261  1.3431e-03  8.6988e-05  8.5619e-05  9.2731e-05  2.5966e-08  6.2816e-05  0:00:08    7
   262  1.3354e-03  8.3825e-05  8.2653e-05  8.9211e-05  2.2114e-08  6.1217e-05  0:00:07    6
   263  1.3285e-03  8.1054e-05  8.0032e-05  8.6148e-05  1.9027e-08  5.9757e-05  0:00:05    5
   264  1.3224e-03  7.8591e-05  7.7714e-05  8.3418e-05  1.6503e-08  5.8398e-05  0:00:04    4
   265  1.3168e-03  7.6404e-05  7.5657e-05  8.0995e-05  1.4408e-08  5.7108e-05  0:00:03    3
   266  1.3117e-03  7.4442e-05  7.3825e-05  7.8827e-05  1.2650e-08  5.5862e-05  0:00:02    2
   267  1.3070e-03  7.2657e-05  7.2184e-05  7.6872e-05  1.1160e-08  5.4635e-05  0:00:01    1
   268  1.3028e-03  7.1050e-05  7.0702e-05  7.5092e-05  9.8883e-09  5.3412e-05  0:00:00    0
Flow time = 0.007000000000000003s, time step = 14
3986 more time steps
 done.
   268  1.3028e-03  7.1050e-05  7.0702e-05  7.5092e-05  9.8883e-09  5.3412e-05  0:00:23   20
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 28 cells
   269  2.7003e-03  2.8761e-03  2.7503e-03  1.9882e-02  3.9876e-04  2.5929e-02  0:00:25   19
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 25 cells
   270  2.7855e-03  7.4603e-04  7.0752e-04  4.5470e-03  8.6752e-05  6.4361e-03  0:00:23   18
   271  2.5387e-03  2.7814e-04  2.6299e-04  1.2059e-03  1.9477e-05  1.6039e-03  0:00:20   17
   272  2.3783e-03  1.7108e-04  1.6424e-04  3.7950e-04  4.6476e-06  4.6239e-04  0:00:19   16
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 23 cells
   273  2.2584e-03  1.4053e-04  1.3643e-04  1.7577e-04  1.2368e-06  1.7297e-04  0:00:17   15
   274  2.1569e-03  1.2413e-04  1.2118e-04  1.3421e-04  3.9821e-07  9.4667e-05  0:00:15   14
   275  2.0834e-03  1.1244e-04  1.1009e-04  1.2046e-04  1.6894e-07  6.9872e-05  0:00:14   13
   276  2.0324e-03  1.0348e-04  1.0156e-04  1.1057e-04  9.5092e-08  6.0745e-05  0:00:13   12
   277  1.9943e-03  9.6483e-05  9.4902e-05  1.0266e-04  6.3796e-08  5.5576e-05  0:00:12   11
   278  1.9646e-03  9.0899e-05  8.9547e-05  9.6278e-05  4.7831e-08  5.2906e-05  0:00:10   10
   279  1.9407e-03  8.6326e-05  8.5119e-05  9.1047e-05  3.8186e-08  5.0353e-05  0:00:09    9
   280  1.9208e-03  8.2525e-05  8.1408e-05  8.6691e-05  3.1553e-08  4.9015e-05  0:00:10    8
   281  1.9037e-03  7.9295e-05  7.8244e-05  8.3006e-05  2.6820e-08  4.7272e-05  0:00:08    7
   282  1.8886e-03  7.6514e-05  7.5523e-05  7.9840e-05  2.2822e-08  4.6450e-05  0:00:07    6
   283  1.8751e-03  7.4088e-05  7.3150e-05  7.7099e-05  1.9704e-08  4.5096e-05  0:00:06    5
   284  1.8629e-03  7.1932e-05  7.1059e-05  7.4685e-05  1.7126e-08  4.4630e-05  0:00:04    4
   285  1.8516e-03  6.9998e-05  6.9188e-05  7.2533e-05  1.5107e-08  4.3554e-05  0:00:03    3
   286  1.8410e-03  6.8253e-05  6.7508e-05  7.0614e-05  1.3349e-08  4.3277e-05  0:00:02    2
   287  1.8310e-03  6.6670e-05  6.5980e-05  6.8869e-05  1.1953e-08  4.2327e-05  0:00:01    1
   288  1.8216e-03  6.5232e-05  6.4580e-05  6.7275e-05  1.0687e-08  4.2130e-05  0:00:00    0
Flow time = 0.007500000000000003s, time step = 15
3985 more time steps
 done.
   288  1.8216e-03  6.5232e-05  6.4580e-05  6.7275e-05  1.0687e-08  4.2130e-05  0:00:21   20
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 20 cells
   289  3.4786e-03  2.1270e-03  2.0342e-03  1.1918e-02  3.9859e-04  2.4670e-02  0:00:23   19
   290  3.5243e-03  5.9757e-04  5.6515e-04  2.9055e-03  8.6796e-05  6.1017e-03  0:00:21   18
   291  3.1820e-03  2.3540e-04  2.2128e-04  8.0035e-04  1.9507e-05  1.5032e-03  0:00:20   17
   292  2.9613e-03  1.5062e-04  1.4350e-04  2.6647e-04  4.6566e-06  4.2561e-04  0:00:18   16
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 19 cells
   293  2.8031e-03  1.2541e-04  1.2051e-04  1.3924e-04  1.2378e-06  1.5504e-04  0:00:16   15
   294  2.6698e-03  1.1135e-04  1.0761e-04  1.1632e-04  3.9629e-07  8.2147e-05  0:00:15   14
   295  2.5688e-03  1.0118e-04  9.8087e-05  1.0557e-04  1.6617e-07  5.9901e-05  0:00:14   13
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 18 cells
   296  2.4955e-03  9.3385e-05  9.0737e-05  9.7220e-05  9.2202e-08  5.1422e-05  0:00:13   12
   297  2.4384e-03  8.7299e-05  8.4985e-05  9.0551e-05  6.0878e-08  4.7057e-05  0:00:11   11
   298  2.3919e-03  8.2463e-05  8.0403e-05  8.5214e-05  4.5006e-08  4.4134e-05  0:00:10   10
   299  2.3531e-03  7.8525e-05  7.6658e-05  8.0867e-05  3.5343e-08  4.1840e-05  0:00:09    9
   300  2.3199e-03  7.5245e-05  7.3529e-05  7.7281e-05  2.8706e-08  3.9900e-05  0:00:08    8
   301  2.2911e-03  7.2449e-05  7.0875e-05  7.4270e-05  2.3806e-08  3.8201e-05  0:00:07    7
   302  2.2654e-03  7.0031e-05  6.8587e-05  7.1707e-05  2.0026e-08  3.6678e-05  0:00:07    6
   303  2.2421e-03  6.7908e-05  6.6589e-05  6.9476e-05  1.7025e-08  3.5299e-05  0:00:06    5
   304  2.2209e-03  6.6032e-05  6.4824e-05  6.7510e-05  1.4596e-08  3.4044e-05  0:00:05    4
   305  2.2014e-03  6.4363e-05  6.3250e-05  6.5758e-05  1.2598e-08  3.2901e-05  0:00:03    3
   306  2.1833e-03  6.2864e-05  6.1826e-05  6.4188e-05  1.0935e-08  3.1861e-05  0:00:02    2
   307  2.1663e-03  6.1503e-05  6.0536e-05  6.2764e-05  9.5362e-09  3.0918e-05  0:00:01    1
   308  2.1504e-03  6.0262e-05  5.9360e-05  6.1472e-05  8.3487e-09  3.0064e-05  0:00:00    0
Flow time = 0.008000000000000004s, time step = 16
3984 more time steps
 done.
   Time = 0.16 seconds.
   Done.
   Cell count                              70622     70654     353168
   Partition boundary cell count           1719      3014      11169
   Partition boundary cell count ratio     2.4%      4.3%      3.2%
   Face count                              145673    147164    725554
   Mean face count deviation               -0.5%     0.6%
   Partition boundary face count           1918      3335      6203
   Partition boundary face count ratio     1.3%      2.3%      0.9%
   Partition neighbor count                2         4
Done.
done.
   308  2.1504e-03  6.0262e-05  5.9360e-05  6.1472e-05  8.3487e-09  3.0064e-05  0:00:21   20
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 15 cells
   309  3.9188e-03  1.2064e-03  1.1553e-03  4.9341e-03  3.9836e-04  2.3664e-02  0:00:20   19
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 14 cells
   310  3.7433e-03  3.8076e-04  3.6001e-04  1.2981e-03  8.6831e-05  5.8699e-03  0:00:19   18
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 13 cells
   311  3.3402e-03  1.7298e-04  1.6278e-04  3.8589e-04  1.9537e-05  1.4339e-03  0:00:17   17
   312  3.0788e-03  1.2267e-04  1.1675e-04  1.5249e-04  4.6684e-06  3.9749e-04  0:00:20   16
   313  2.8967e-03  1.0652e-04  1.0239e-04  1.1014e-04  1.2414e-06  1.3746e-04  0:00:18   15
   314  2.7488e-03  9.7165e-05  9.3946e-05  9.9722e-05  3.9691e-07  6.7615e-05  0:00:16   14
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 12 cells
   315  2.6368e-03  9.0245e-05  8.7578e-05  9.2786e-05  1.6574e-07  4.6431e-05  0:00:14   13
   316  2.5535e-03  8.4858e-05  8.2581e-05  8.7272e-05  9.1413e-08  3.8494e-05  0:00:13   12
   317  2.4882e-03  8.0593e-05  7.8591e-05  8.2856e-05  5.9938e-08  3.4560e-05  0:00:12   11
   318  2.4353e-03  7.7133e-05  7.5337e-05  7.9264e-05  4.3957e-08  3.2064e-05  0:00:11   10
   319  2.3912e-03  7.4265e-05  7.2630e-05  7.6283e-05  3.4246e-08  3.0209e-05  0:00:09    9
   320  2.3535e-03  7.1811e-05  7.0336e-05  7.3750e-05  2.7607e-08  2.8702e-05  0:00:08    8
   321  2.3207e-03  6.9671e-05  6.8342e-05  7.1546e-05  2.2734e-08  2.7410e-05  0:00:07    7
   322  2.2916e-03  6.7788e-05  6.6581e-05  6.9603e-05  1.8999e-08  2.6253e-05  0:00:06    6
   323  2.2656e-03  6.6118e-05  6.5009e-05  6.7871e-05  1.6052e-08  2.5193e-05  0:00:05    5
   324  2.2420e-03  6.4614e-05  6.3595e-05  6.6307e-05  1.3681e-08  2.4212e-05  0:00:04    4
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 11 cells
   325  2.2204e-03  6.3247e-05  6.2307e-05  6.4881e-05  1.1743e-08  2.3291e-05  0:00:03    3
   326  2.2004e-03  6.2004e-05  6.1125e-05  6.3571e-05  1.0140e-08  2.2416e-05  0:00:02    2
   327  2.1816e-03  6.0862e-05  6.0041e-05  6.2366e-05  8.8025e-09  2.1577e-05  0:00:01    1
   328  2.1640e-03  5.9812e-05  5.9043e-05  6.1245e-05  7.6742e-09  2.0771e-05  0:00:00    0
Flow time = 0.008500000000000004s, time step = 17
3983 more time steps
 done.
   328  2.1640e-03  5.9812e-05  5.9043e-05  6.1245e-05  7.6742e-09  2.0771e-05  0:00:20   20
   329  4.0142e-03  4.5963e-04  4.3376e-04  3.5314e-03  3.9808e-04  2.2721e-02  0:00:19   19
   330  3.6138e-03  2.0205e-04  1.8807e-04  9.8809e-04  8.6863e-05  5.6961e-03  0:00:18   18
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 9 cells
   331  3.1078e-03  1.2767e-04  1.1874e-04  3.0414e-04  1.9565e-05  1.3775e-03  0:00:17   17
   332  2.8255e-03  1.0381e-04  9.8258e-05  1.3333e-04  4.6784e-06  3.7468e-04  0:00:19   16
   333  2.6363e-03  9.2653e-05  8.8743e-05  9.9107e-05  1.2439e-06  1.2291e-04  0:00:17   15
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 8 cells
   334  2.4843e-03  8.5180e-05  8.2146e-05  8.8673e-05  3.9693e-07  5.5213e-05  0:00:16   14
   335  2.3695e-03  7.9451e-05  7.6947e-05  8.2298e-05  1.6522e-07  3.4707e-05  0:00:14   13
   336  2.2856e-03  7.4873e-05  7.2750e-05  7.7416e-05  9.0558e-08  2.7104e-05  0:00:13   12
   337  2.2210e-03  7.1146e-05  6.9306e-05  7.3460e-05  5.8877e-08  2.3416e-05  0:00:12   11
   338  2.1692e-03  6.8051e-05  6.6446e-05  7.0171e-05  4.2823e-08  2.1060e-05  0:00:11   10
   339  2.1268e-03  6.5437e-05  6.4029e-05  6.7387e-05  3.3090e-08  1.9493e-05  0:00:09    9
   340  2.0911e-03  6.3197e-05  6.1952e-05  6.4999e-05  2.6458e-08  1.8325e-05  0:00:08    8
   341  2.0606e-03  6.1248e-05  6.0144e-05  6.2924e-05  2.1611e-08  1.7413e-05  0:00:07    7
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 7 cells
   342  2.0340e-03  5.9543e-05  5.8557e-05  6.1106e-05  1.7914e-08  1.6668e-05  0:00:06    6
   343  2.0105e-03  5.8036e-05  5.7155e-05  5.9497e-05  1.5018e-08  1.6038e-05  0:00:05    5
   344  1.9894e-03  5.6695e-05  5.5899e-05  5.8060e-05  1.2707e-08  1.5487e-05  0:00:04    4
   345  1.9702e-03  5.5493e-05  5.4771e-05  5.6773e-05  1.0829e-08  1.4981e-05  0:00:03    3
   346  1.9526e-03  5.4410e-05  5.3750e-05  5.5615e-05  9.2885e-09  1.4494e-05  0:00:02    2
   347  1.9362e-03  5.3426e-05  5.2817e-05  5.4564e-05  8.0125e-09  1.4010e-05  0:00:01    1
   348  1.9209e-03  5.2529e-05  5.1968e-05  5.3613e-05  6.9455e-09  1.3517e-05  0:00:00    0
Flow time = 0.009000000000000005s, time step = 18
3982 more time steps
 done.
   348  1.9209e-03  5.2529e-05  5.1968e-05  5.3613e-05  6.9455e-09  1.3517e-05  0:00:20   20
   349  3.8802e-03  7.7460e-04  7.1732e-04  9.6757e-03  3.9776e-04  2.1947e-02  0:00:23   19
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 6 cells
   350  3.2232e-03  2.7983e-04  2.5817e-04  2.7136e-03  8.6889e-05  5.5172e-03  0:00:21   18
   351  2.6493e-03  1.4009e-04  1.3024e-04  7.5676e-04  1.9593e-05  1.3313e-03  0:00:19   17
   352  2.3490e-03  1.0418e-04  9.8804e-05  2.3849e-04  4.6884e-06  3.5746e-04  0:00:18   16
   353  2.1576e-03  8.9523e-05  8.5856e-05  1.1368e-04  1.2457e-06  1.1288e-04  0:00:16   15
   354  2.0066e-03  8.0272e-05  7.7362e-05  8.7926e-05  3.9616e-07  4.7284e-05  0:00:15   14
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 5 cells
   355  1.8954e-03  7.3574e-05  7.1107e-05  7.8419e-05  1.6358e-07  2.7586e-05  0:00:14   13
   356  1.8150e-03  6.8484e-05  6.6343e-05  7.2296e-05  8.9022e-08  2.0395e-05  0:00:13   12
(cx-use-window-id 5)
   357  1.7530e-03  6.4510e-05  6.2644e-05  6.7680e-05  5.7484e-08  1.6984e-05  0:00:11   11
   358  1.7033e-03  6.1331e-05  5.9705e-05  6.4055e-05  4.1536e-08  1.4931e-05  0:00:10   10
   359  1.6627e-03  5.8722e-05  5.7295e-05  6.1097e-05  3.1901e-08  1.3494e-05  0:00:09    9
   360  1.6288e-03  5.6547e-05  5.5276e-05  5.8630e-05  2.5363e-08  1.2399e-05  0:00:08    8
   361  1.5998e-03  5.4698e-05  5.3562e-05  5.6538e-05  2.0605e-08  1.1520e-05  0:00:07    7
   362  1.5746e-03  5.3100e-05  5.2091e-05  5.4740e-05  1.6992e-08  1.0788e-05  0:00:06    6
   363  1.5525e-03  5.1705e-05  5.0807e-05  5.3181e-05  1.4169e-08  1.0155e-05  0:00:05    5
   364  1.5327e-03  5.0472e-05  4.9671e-05  5.1819e-05  1.1919e-08  9.5979e-06  0:00:04    4
   365  1.5149e-03  4.9373e-05  4.8661e-05  5.0619e-05  1.0097e-08  9.1055e-06  0:00:03    3
   366  1.4988e-03  4.8382e-05  4.7757e-05  4.9548e-05  8.6030e-09  8.6724e-06  0:00:02    2
   367  1.4840e-03  4.7489e-05  4.6943e-05  4.8586e-05  7.3653e-09  8.2990e-06  0:00:01    1
   368  1.4704e-03  4.6680e-05  4.6204e-05  4.7720e-05  6.3313e-09  7.9789e-06  0:00:00    0
Flow time = 0.009500000000000005s, time step = 19
3981 more time steps
 done.
   368  1.4704e-03  4.6680e-05  4.6204e-05  4.7720e-05  6.3313e-09  7.9789e-06  0:00:20   20
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 4 cells
   369  3.5042e-03  1.2158e-03  1.1499e-03  1.6520e-02  3.9742e-04  2.1042e-02  0:00:23   19
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 3 cells
   370  2.7519e-03  4.1969e-04  3.9359e-04  4.8362e-03  8.6908e-05  5.3015e-03  0:00:21   18
   371  2.1320e-03  1.8118e-04  1.6932e-04  1.3371e-03  1.9617e-05  1.2689e-03  0:00:19   17
   372  1.8174e-03  1.2163e-04  1.1535e-04  3.9680e-04  4.6969e-06  3.3680e-04  0:00:18   16
   373  1.6167e-03  9.9857e-05  9.5638e-05  1.5826e-04  1.2472e-06  1.0361e-04  0:00:13   15
   374  1.4611e-03  8.6595e-05  8.3322e-05  1.0163e-04  3.9558e-07  4.1512e-05  0:00:13   14
   375  1.3479e-03  7.7129e-05  7.4388e-05  8.5128e-05  1.6245e-07  2.3105e-05  0:00:12   13
   376  1.2667e-03  7.0044e-05  6.7686e-05  7.6060e-05  8.7639e-08  1.6512e-05  0:00:11   12
   377  1.2052e-03  6.4600e-05  6.2565e-05  6.9468e-05  5.6130e-08  1.3430e-05  0:00:10   11
   378  1.1566e-03  6.0299e-05  5.8540e-05  6.4359e-05  4.0292e-08  1.1577e-05  0:00:10   10
   379  1.1170e-03  5.6808e-05  5.5303e-05  6.0276e-05  3.0767e-08  1.0267e-05  0:00:09    9
   380  1.0840e-03  5.3924e-05  5.2641e-05  5.6929e-05  2.4322e-08  9.2653e-06  0:00:08    8
   381  1.0560e-03  5.1488e-05  5.0400e-05  5.4122e-05  1.9643e-08  8.4713e-06  0:00:07    7
   382  1.0318e-03  4.9398e-05  4.8474e-05  5.1731e-05  1.6097e-08  7.8340e-06  0:00:06    6
   383  1.0108e-03  4.7587e-05  4.6800e-05  4.9671e-05  1.3335e-08  7.3161e-06  0:00:05    5
   384  9.9226e-04  4.5997e-05  4.5326e-05  4.7874e-05  1.1142e-08  6.8946e-06  0:00:04    4
!  384 solution is converged
Flow time = 0.01000000000000001s, time step = 20
3980 more time steps
 done.
   384  9.9226e-04  4.5997e-05  4.5326e-05  4.7874e-05  1.1142e-08  6.8946e-06  0:00:20   20
   385  3.4427e-03  1.4866e-03  1.4037e-03  2.3729e-02  3.9704e-04  2.0391e-02  0:00:23   19
   386  2.5305e-03  5.3633e-04  5.0228e-04  7.2714e-03  8.6919e-05  5.1510e-03  0:00:21   18
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 2 cells
   387  1.8373e-03  2.3240e-04  2.1608e-04  2.0263e-03  1.9638e-05  1.2331e-03  0:00:19   17
   388  1.4886e-03  1.5465e-04  1.4560e-04  5.9152e-04  4.7031e-06  3.2586e-04  0:00:18   16
   389  1.2653e-03  1.2604e-04  1.1998e-04  2.2293e-04  1.2479e-06  9.8553e-05  0:00:16   15
   390  1.0884e-03  1.0830e-04  1.0374e-04  1.3320e-04  3.9448e-07  3.8025e-05  0:00:12   14
   391  9.5983e-04  9.5650e-05  9.1941e-05  1.0842e-04  1.6092e-07  2.0166e-05  0:00:12   13
!  391 solution is converged
Flow time = 0.01050000000000001s, time step = 21
3979 more time steps
 done.
   Time = 0.146 seconds.
   Done.
   Cell count                              70910     70934     354592
   Partition boundary cell count           1620      3018      10910
   Partition boundary cell count ratio     2.3%      4.3%      3.1%
   Face count                              146153    147650    728402
   Mean face count deviation               -0.5%     0.5%
   Partition boundary face count           1781      3265      5933
   Partition boundary face count ratio     1.2%      2.2%      0.8%
Done.
done.
   391  9.5983e-04  9.5650e-05  9.1941e-05  1.0842e-04  1.6092e-07  2.0166e-05  0:00:18   20
   392  3.5282e-03  1.7329e-03  1.6238e-03  3.1225e-02  3.9661e-04  1.9808e-02  0:00:21   19
   393  2.7477e-03  5.7653e-04  5.3641e-04  8.5621e-03  8.6905e-05  5.0729e-03  0:00:20   18
   394  2.0698e-03  2.5289e-04  2.3518e-04  2.2232e-03  1.9647e-05  1.2092e-03  0:00:15   17
   395  1.6793e-03  1.7866e-04  1.6895e-04  6.4271e-04  4.7024e-06  3.2066e-04  0:00:14   16
   396  1.4290e-03  1.4938e-04  1.4245e-04  2.4416e-04  1.2426e-06  9.7470e-05  0:00:14   15
   397  1.2345e-03  1.3039e-04  1.2492e-04  1.5390e-04  3.8876e-07  3.7833e-05  0:00:13   14
   398  1.0934e-03  1.1657e-04  1.1204e-04  1.3106e-04  1.5587e-07  2.0238e-05  0:00:12   13
   399  9.9386e-04  1.0611e-04  1.0226e-04  1.1783e-04  8.1788e-08  1.4012e-05  0:00:11   12
!  399 solution is converged
Flow time = 0.01100000000000001s, time step = 22
3978 more time steps
 done.
   399  9.9386e-04  1.0611e-04  1.0226e-04  1.1783e-04  8.1788e-08  1.4012e-05  0:00:19   20
   400  3.6642e-03  1.5324e-03  1.4209e-03  3.1937e-02  3.9620e-04  1.9288e-02  0:00:18   19
   401  3.1618e-03  4.2595e-04  3.9354e-04  7.0294e-03  8.6904e-05  4.9502e-03  0:00:18   18
 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1 cells
   402  2.5091e-03  1.9522e-04  1.8161e-04  1.7891e-03  1.9666e-05  1.1839e-03  0:00:17   17
   403  2.1326e-03  1.4241e-04  1.3485e-04  5.1169e-04  4.7099e-06  3.1402e-04  0:00:16   16
   404  1.8837e-03  1.2135e-04  1.1589e-04  1.9075e-04  1.2445e-06  9.4230e-05  0:00:15   15
   405  1.6846e-03  1.0781e-04  1.0344e-04  1.2411e-04  3.8893e-07  3.5310e-05  0:00:14   14
   406  1.5403e-03  9.7983e-05  9.4308e-05  1.0847e-04  1.5559e-07  1.7940e-05  0:00:13   13
   407  1.4395e-03  9.0488e-05  8.7257e-05  9.9290e-05  8.1410e-08  1.1922e-05  0:00:12   12
   408  1.3653e-03  8.4567e-05  8.1678e-05  9.2034e-05  5.2274e-08  9.2930e-06  0:00:09   11
   409  1.3082e-03  7.9768e-05  7.7158e-05  8.6129e-05  3.6686e-08  7.8392e-06  0:00:08   10
   410  1.2624e-03  7.5762e-05  7.3429e-05  8.1227e-05  2.7452e-08  6.8924e-06  0:00:08    9
   411  1.2246e-03  7.2339e-05  7.0253e-05  7.7093e-05  2.1305e-08  6.2173e-06  0:00:07    8
   412  1.1925e-03  6.9368e-05  6.7489e-05  7.3547e-05  1.6913e-08  5.7110e-06  0:00:06    7
   413  1.1648e-03  6.6741e-05  6.5040e-05  7.0456e-05  1.3639e-08  5.3188e-06  0:00:06    6
   414  1.1404e-03  6.4386e-05  6.2837e-05  6.7731e-05  1.1128e-08  5.0120e-06  0:00:05    5
   415  1.1186e-03  6.2264e-05  6.0843e-05  6.5308e-05  9.1632e-09  4.7668e-06  0:00:04    4
   416  1.0989e-03  6.0342e-05  5.9027e-05  6.3132e-05  7.6030e-09  4.5674e-06  0:00:03    3
   417  1.0810e-03  5.8591e-05  5.7364e-05  6.1156e-05  6.3488e-09  4.4027e-06  0:00:02    2
   418  1.0644e-03  5.6983e-05  5.5828e-05  5.9346e-05  5.3306e-09  4.2642e-06  0:00:01    1
   419  1.0492e-03  5.5502e-05  5.4406e-05  5.7685e-05  4.4969e-09  4.1465e-06  0:00:00    0
Flow time = 0.01150000000000001s, time step = 23
3977 more time steps
 done.
   419  1.0492e-03  5.5502e-05  5.4406e-05  5.7685e-05  4.4969e-09  4.1465e-06  0:00:20   20
   420  3.9989e-03  1.1525e-03  1.0582e-03  2.2943e-02  3.9581e-04  1.8459e-02  0:00:19   19
   421  3.6649e-03  3.3694e-04  3.0809e-04  5.1351e-03  8.6912e-05  4.7955e-03  0:00:18   18
   422  2.9733e-03  1.5998e-04  1.4737e-04  1.3304e-03  1.9693e-05  1.1361e-03  0:00:17   17
   423  2.5584e-03  1.1534e-04  1.0851e-04  3.8688e-04  4.7232e-06  3.0067e-04  0:00:16   16
   424  2.2816e-03  9.7253e-05  9.2676e-05  1.4614e-04  1.2509e-06  9.0954e-05  0:00:15   15
   425  2.0609e-03  8.5701e-05  8.2237e-05  9.5524e-05  3.9261e-07  3.5011e-05  0:00:14   14
   426  1.8985e-03  7.7217e-05  7.4421e-05  8.3130e-05  1.5814e-07  1.8519e-05  0:00:13   13
   427  1.7825e-03  7.0703e-05  6.8376e-05  7.5680e-05  8.3338e-08  1.2701e-05  0:00:12   12
   428  1.6953e-03  6.5554e-05  6.3574e-05  6.9752e-05  5.3778e-08  1.0027e-05  0:00:11   11
   429  1.6267e-03  6.1394e-05  5.9692e-05  6.4916e-05  3.7825e-08  8.4236e-06  0:00:10   10
   430  1.5708e-03  5.7962e-05  5.6508e-05  6.0937e-05  2.8317e-08  7.2949e-06  0:00:09    9
   431  1.5242e-03  5.5093e-05  5.3844e-05  5.7640e-05  2.1960e-08  6.4363e-06  0:00:08    8
   432  1.4847e-03  5.2666e-05  5.1588e-05  5.4865e-05  1.7408e-08  5.7600e-06  0:00:07    7
   433  1.4506e-03  5.0583e-05  4.9657e-05  5.2505e-05  1.4010e-08  5.2194e-06  0:00:05    6
   434  1.4208e-03  4.8788e-05  4.7981e-05  5.0486e-05  1.1403e-08  4.7884e-06  0:00:04    5
   435  1.3944e-03  4.7230e-05  4.6520e-05  4.8738e-05  9.3637e-09  4.4379e-06  0:00:03    4
   436  1.3709e-03  4.5859e-05  4.5237e-05  4.7216e-05  7.7458e-09  4.1580e-06  0:00:03    3
   437  1.3498e-03  4.4652e-05  4.4102e-05  4.5880e-05  6.4471e-09  3.9330e-06  0:00:02    2
   438  1.3307e-03  4.3579e-05  4.3090e-05  4.4696e-05  5.3945e-09  3.7521e-06  0:00:01    1
   439  1.3133e-03  4.2621e-05  4.2181e-05  4.3648e-05  4.5346e-09  3.6060e-06  0:00:00    0
Flow time = 0.01200000000000001s, time step = 24
3976 more time steps
 done.
   439  1.3133e-03  4.2621e-05  4.2181e-05  4.3648e-05  4.5346e-09  3.6060e-06  0:00:19   20
   440  4.6688e-03  1.0487e-03  9.7967e-04  1.4980e-02  3.9540e-04  1.8125e-02  0:00:22   19
   441  4.0842e-03  3.1476e-04  2.9234e-04  3.5340e-03  8.6909e-05  4.7863e-03  0:00:20   18
   442  3.3074e-03  1.4469e-04  1.3425e-04  9.3510e-04  1.9711e-05  1.1344e-03  0:00:19   17
   443  2.8606e-03  1.0298e-04  9.7306e-05  2.7967e-04  4.7310e-06  3.0048e-04  0:00:17   16
   444  2.5632e-03  8.7347e-05  8.3708e-05  1.1385e-04  1.2531e-06  8.9432e-05  0:00:16   15
   445  2.3252e-03  7.7834e-05  7.5211e-05  8.3835e-05  3.9291e-07  3.2803e-05  0:00:15   14
   446  2.1505e-03  7.1032e-05  6.9007e-05  7.5542e-05  1.5788e-07  1.6175e-05  0:00:14   13
   447  2.0259e-03  6.5914e-05  6.4277e-05  6.9738e-05  8.2899e-08  1.0429e-05  0:00:12   12
   448  1.9325e-03  6.1953e-05  6.0613e-05  6.5105e-05  5.3270e-08  7.8966e-06  0:00:09   11
   449  1.8593e-03  5.8822e-05  5.7709e-05  6.1409e-05  3.7291e-08  6.4733e-06  0:00:09   10
   450  1.8002e-03  5.6285e-05  5.5345e-05  5.8423e-05  2.7780e-08  5.5404e-06  0:00:08    9
   451  1.7514e-03  5.4178e-05  5.3385e-05  5.5960e-05  2.1438e-08  4.8778e-06  0:00:07    8
   452  1.7102e-03  5.2386e-05  5.1729e-05  5.3895e-05  1.6910e-08  4.3987e-06  0:00:07    7
   453  1.6746e-03  5.0832e-05  5.0292e-05  5.2144e-05  1.3543e-08  4.0346e-06  0:00:06    6
   454  1.6435e-03  4.9465e-05  4.9029e-05  5.0630e-05  1.0970e-08  3.6351e-06  0:00:05    5
   455  1.6162e-03  4.8252e-05  4.7905e-05  4.9301e-05  8.9656e-09  3.3881e-06  0:00:04    4
   456  1.5917e-03  4.7167e-05  4.6898e-05  4.8129e-05  7.3818e-09  3.1921e-06  0:00:03    3
   457  1.5697e-03  4.6194e-05  4.5990e-05  4.7088e-05  6.1158e-09  3.0331e-06  0:00:02    2
   458  1.5499e-03  4.5318e-05  4.5167e-05  4.6156e-05  5.0939e-09  2.9010e-06  0:00:01    1
   459  1.5317e-03  4.4522e-05  4.4419e-05  4.5314e-05  4.2624e-09  2.7889e-06  0:00:00    0
Flow time = 0.01250000000000001s, time step = 25
3975 more time steps
 done.
   459  1.5317e-03  4.4522e-05  4.4419e-05  4.5314e-05  4.2624e-09  2.7889e-06  0:00:20   20
   460  4.9664e-03  8.5131e-04  7.9221e-04  8.4378e-03  3.9499e-04  1.7570e-02  0:00:19   19
   461  4.3547e-03  2.7208e-04  2.5147e-04  2.1002e-03  8.6903e-05  4.6033e-03  0:00:18   18
   462  3.5299e-03  1.3085e-04  1.2143e-04  5.7788e-04  1.9727e-05  1.0990e-03  0:00:17   17
   463  3.0627e-03  9.6082e-05  9.1065e-05  1.8645e-04  4.7367e-06  2.9111e-04  0:00:16   16
   464  2.7509e-03  8.2935e-05  7.9701e-05  9.3411e-05  1.2538e-06  8.6418e-05  0:00:15   15
   465  2.4989e-03  7.4850e-05  7.2464e-05  7.8303e-05  3.9213e-07  3.1561e-05  0:00:14   14
   466  2.3142e-03  6.8993e-05  6.7098e-05  7.1947e-05  1.5679e-07  1.5538e-05  0:00:13   13
   467  2.1824e-03  6.4541e-05  6.3007e-05  6.7077e-05  8.1798e-08  1.0065e-05  0:00:12   12
   468  2.0831e-03  6.1078e-05  5.9815e-05  6.3179e-05  5.2229e-08  7.7031e-06  0:00:11   11
   469  2.0050e-03  5.8331e-05  5.7269e-05  6.0081e-05  3.6336e-08  6.3677e-06  0:00:10   10
   470  1.9418e-03  5.6081e-05  5.5183e-05  5.7591e-05  2.6912e-08  5.4820e-06  0:00:09    9
   471  1.8895e-03  5.4196e-05  5.3426e-05  5.5529e-05  2.0652e-08  4.8448e-06  0:00:08    8
   472  1.8454e-03  5.2581e-05  5.1910e-05  5.3787e-05  1.6203e-08  4.3849e-06  0:00:07    7
   473  1.8076e-03  5.1177e-05  5.0590e-05  5.2290e-05  1.2908e-08  4.0339e-06  0:00:05    6
   474  1.7749e-03  4.9940e-05  4.9423e-05  5.0976e-05  1.0401e-08  3.7606e-06  0:00:04    5
   475  1.7464e-03  4.8835e-05  4.8382e-05  4.9807e-05  8.4577e-09  3.5435e-06  0:00:03    4
   476  1.7211e-03  4.7838e-05  4.7447e-05  4.8756e-05  6.9287e-09  3.3692e-06  0:00:03    3
   477  1.6984e-03  4.6936e-05  4.6599e-05  4.7807e-05  5.7119e-09  3.2285e-06  0:00:02    2
   478  1.6778e-03  4.6114e-05  4.5824e-05  4.6945e-05  4.7342e-09  3.1112e-06  0:00:01    1
   479  1.6590e-03  4.5359e-05  4.5110e-05  4.6157e-05  3.9421e-09  3.0125e-06  0:00:00    0
Flow time = 0.01300000000000001s, time step = 26
3974 more time steps
 done.
   Time = 0.145 seconds.
   Done.
   Cell count                              71431     71614     357560
   Mean cell count deviation               -0.1%     0.1%
   Partition boundary cell count           1666      2885      10820
   Partition boundary cell count ratio     2.3%      4.0%      3.0%
   Face count                              147304    149078    734338
   Partition boundary face count           1825      3109      5899
   Partition boundary face count ratio     1.2%      2.1%      0.8%
   Mean cell weight deviation              -0.1%     0.1%
Done.
   Smoothing partition boundaries...done.
   479  1.6590e-03  4.5359e-05  4.5110e-05  4.6157e-05  3.9421e-09  3.0125e-06  0:00:19   20
   480  5.3406e-03  6.4482e-04  5.9071e-04  3.1603e-03  3.9459e-04  1.6985e-02  0:00:18   19
   481  4.5556e-03  2.3104e-04  2.1186e-04  8.5735e-04  8.6894e-05  4.4686e-03  0:00:17   18
   482  3.6972e-03  1.2263e-04  1.1388e-04  2.6952e-04  1.9742e-05  1.0606e-03  0:00:17   17
   483  3.1807e-03  9.2918e-05  8.8256e-05  1.1496e-04  4.7417e-06  2.7982e-04  0:00:16   16
   484  2.8410e-03  8.0583e-05  7.7615e-05  8.4264e-05  1.2541e-06  8.2444e-05  0:00:15   15
   485  2.5765e-03  7.2707e-05  7.0532e-05  7.5256e-05  3.9104e-07  2.9621e-05  0:00:14   14
   486  2.3831e-03  6.6835e-05  6.5137e-05  6.9206e-05  1.5546e-07  1.4205e-05  0:00:13   13
   487  2.2415e-03  6.2282e-05  6.0916e-05  6.4391e-05  8.0514e-08  8.9173e-06  0:00:12   12
   488  2.1325e-03  5.8678e-05  5.7577e-05  6.0495e-05  5.1046e-08  6.5879e-06  0:00:11   11
   489  2.0456e-03  5.5786e-05  5.4873e-05  5.7357e-05  3.5279e-08  5.2760e-06  0:00:10   10
   490  1.9747e-03  5.3402e-05  5.2630e-05  5.4789e-05  2.5971e-08  4.4074e-06  0:00:09    9
   491  1.9155e-03  5.1394e-05  5.0744e-05  5.2642e-05  1.9817e-08  3.7719e-06  0:00:06    8
   492  1.8653e-03  4.9688e-05  4.9137e-05  5.0827e-05  1.5464e-08  3.3055e-06  0:00:06    7
   493  1.8219e-03  4.8221e-05  4.7753e-05  4.9277e-05  1.2255e-08  2.9491e-06  0:00:05    6
   494  1.7839e-03  4.6947e-05  4.6542e-05  4.7929e-05  9.8250e-09  2.6668e-06  0:00:04    5
   495  1.7503e-03  4.5824e-05  4.5471e-05  4.6746e-05  7.9494e-09  2.4396e-06  0:00:04    4
   496  1.7204e-03  4.4829e-05  4.4524e-05  4.5701e-05  6.4807e-09  2.2543e-06  0:00:03    3
   497  1.6935e-03  4.3943e-05  4.3679e-05  4.4770e-05  5.3173e-09  2.1086e-06  0:00:02    2
   498  1.6692e-03  4.3151e-05  4.2923e-05  4.3938e-05  4.3866e-09  1.9864e-06  0:00:01    1
   499  1.6471e-03  4.2440e-05  4.2244e-05  4.3189e-05  3.6361e-09  1.8840e-06  0:00:00    0
Flow time = 0.01350000000000001s, time step = 27
3973 more time steps
 done.
   499  1.6471e-03  4.2440e-05  4.2244e-05  4.3189e-05  3.6361e-09  1.8840e-06  0:00:19   20
   500  5.7401e-03  4.8259e-04  4.3856e-04  2.6686e-03  3.9419e-04  1.6516e-02  0:00:18   19
   501  4.6858e-03  1.9828e-04  1.8133e-04  7.5732e-04  8.6883e-05  4.3962e-03  0:00:18   18
   502  3.6775e-03  1.1404e-04  1.0557e-04  2.4543e-04  1.9755e-05  1.0413e-03  0:00:17   17
   503  3.1257e-03  8.7561e-05  8.2730e-05  1.1396e-04  4.7461e-06  2.7474e-04  0:00:16   16
   504  2.7713e-03  7.5865e-05  7.2643e-05  8.2214e-05  1.2541e-06  8.0849e-05  0:00:15   15
   505  2.4870e-03  6.8429e-05  6.5986e-05  7.1861e-05  3.8983e-07  2.8964e-05  0:00:14   14
   506  2.2766e-03  6.3035e-05  6.1030e-05  6.5778e-05  1.5407e-07  1.3826e-05  0:00:13   13
   507  2.1235e-03  5.8910e-05  5.7222e-05  6.1232e-05  7.9204e-08  8.6684e-06  0:00:12   12
   508  2.0072e-03  5.5674e-05  5.4255e-05  5.7644e-05  4.9858e-08  6.4176e-06  0:00:11   11
   509  1.9154e-03  5.3071e-05  5.1886e-05  5.4783e-05  3.4231e-08  5.1291e-06  0:00:10   10
  iter  continuity  x-velocity  y-velocity  z-velocity           k       omega     time/iter
   510  1.8409e-03  5.0922e-05  4.9923e-05  5.2439e-05  2.5048e-08  4.2592e-06  0:00:09    9
   511  1.7792e-03  4.9104e-05  4.8267e-05  5.0476e-05  1.9006e-08  3.6479e-06  0:00:08    8
   512  1.7276e-03  4.7535e-05  4.6836e-05  4.8793e-05  1.4751e-08  3.2062e-06  0:00:07    7
   513  1.6836e-03  4.6162e-05  4.5583e-05  4.7327e-05  1.1629e-08  2.8598e-06  0:00:06    6
   514  1.6455e-03  4.4943e-05  4.4469e-05  4.6038e-05  9.2750e-09  2.5725e-06  0:00:05    5
   515  1.6120e-03  4.3853e-05  4.3466e-05  4.4888e-05  7.4667e-09  2.3537e-06  0:00:04    4
   516  1.5824e-03  4.2871e-05  4.2555e-05  4.3856e-05  6.0568e-09  2.2081e-06  0:00:02    3
   517  1.5561e-03  4.1979e-05  4.1722e-05  4.2918e-05  4.9449e-09  2.0845e-06  0:00:02    2
   518  1.5323e-03  4.1164e-05  4.0958e-05  4.2060e-05  4.0595e-09  1.9751e-06  0:00:01    1
   519  1.5107e-03  4.0414e-05  4.0251e-05  4.1277e-05  3.3485e-09  1.8776e-06  0:00:00    0
Flow time = 0.01400000000000001s, time step = 28
3972 more time steps
Updating solution at time levels N and N-1.
 done.
Updating mesh at time level N... done.
   519  1.5107e-03  4.0414e-05  4.0251e-05  4.1277e-05  3.3485e-09  1.8776e-06  0:00:18   20
   520  5.7172e-03  6.0355e-04  5.4622e-04  7.2305e-03  3.9380e-04  1.6064e-02  0:00:21   19
   521  4.5348e-03  2.3207e-04  2.1051e-04  1.9997e-03  8.6872e-05  4.2676e-03  0:00:20   18
   522  3.4323e-03  1.2408e-04  1.1398e-04  5.7242e-04  1.9767e-05  1.0118e-03  0:00:18   17
   523  2.8290e-03  9.2605e-05  8.7169e-05  1.9189e-04  4.7502e-06  2.6746e-04  0:00:17   16
   524  2.4433e-03  7.8525e-05  7.4942e-05  9.6251e-05  1.2540e-06  7.8744e-05  0:00:16   15
   525  2.1409e-03  6.9354e-05  6.6609e-05  7.5223e-05  3.8860e-07  2.8182e-05  0:00:15   14
   526  1.9202e-03  6.2580e-05  6.0323e-05  6.6501e-05  1.5269e-07  1.3428e-05  0:00:11   13
   527  1.7646e-03  5.7342e-05  5.5436e-05  6.0439e-05  7.7922e-08  8.3690e-06  0:00:10   12
   528  1.6492e-03  5.3194e-05  5.1573e-05  5.5710e-05  4.8706e-08  6.1607e-06  0:00:10   11
   529  1.5601e-03  4.9845e-05  4.8456e-05  5.1938e-05  3.3223e-08  4.9340e-06  0:00:09   10
   530  1.4893e-03  4.7065e-05  4.5876e-05  4.8848e-05  2.4169e-08  4.1335e-06  0:00:08    9
   531  1.4319e-03  4.4728e-05  4.3703e-05  4.6276e-05  1.8238e-08  3.5605e-06  0:00:08    8
   532  1.3844e-03  4.2743e-05  4.1849e-05  4.4104e-05  1.4081e-08  3.1241e-06  0:00:07    7
   533  1.3442e-03  4.1028e-05  4.0245e-05  4.2239e-05  1.1044e-08  2.7964e-06  0:00:06    6
   534  1.3099e-03  3.9532e-05  3.8845e-05  4.0623e-05  8.7654e-09  2.5428e-06  0:00:05    5
   535  1.2804e-03  3.8216e-05  3.7614e-05  3.9214e-05  7.0223e-09  2.3403e-06  0:00:04    4
   536  1.2546e-03  3.7046e-05  3.6526e-05  3.7974e-05  5.6694e-09  2.1789e-06  0:00:03    3
   537  1.2317e-03  3.6012e-05  3.5558e-05  3.6873e-05  4.6071e-09  2.0518e-06  0:00:02    2
   538  1.2115e-03  3.5092e-05  3.4695e-05  3.5896e-05  3.7648e-09  1.9462e-06  0:00:01    1
   539  1.1935e-03  3.4270e-05  3.3922e-05  3.5023e-05  3.0915e-09  1.8576e-06  0:00:00    0
Flow time = 0.01450000000000001s, time step = 29
3971 more time steps
 done.
   539  1.1935e-03  3.4270e-05  3.3922e-05  3.5023e-05  3.0915e-09  1.8576e-06  0:00:20   20
   540  5.5545e-03  7.9779e-04  7.2700e-04  1.1528e-02  3.9341e-04  1.5675e-02  0:00:23   19
   541  4.2910e-03  2.8741e-04  2.6174e-04  3.2348e-03  8.6859e-05  4.2217e-03  0:00:17   18
   542  3.1655e-03  1.3695e-04  1.2560e-04  9.0094e-04  1.9778e-05  9.9720e-04  0:00:16   17
   543  2.5555e-03  9.5376e-05  8.9303e-05  2.7785e-04  4.7539e-06  2.6464e-04  0:00:16   16
   544  2.1640e-03  7.7877e-05  7.3761e-05  1.1437e-04  1.2538e-06  7.8472e-05  0:00:15   15
   545  1.8586e-03  6.6737e-05  6.3580e-05  7.6307e-05  3.8737e-07  2.8241e-05  0:00:14   14
   546  1.6379e-03  5.8736e-05  5.6179e-05  6.4332e-05  1.5135e-07  1.3466e-05  0:00:13   13
   547  1.4826e-03  5.2756e-05  5.0640e-05  5.7059e-05  7.6687e-08  8.3924e-06  0:00:12   12
   548  1.3669e-03  4.8215e-05  4.6440e-05  5.1677e-05  4.7606e-08  6.1700e-06  0:00:11   11
   549  1.2777e-03  4.4705e-05  4.3187e-05  4.7555e-05  3.2269e-08  4.9010e-06  0:00:10   10
   550  1.2070e-03  4.1919e-05  4.0612e-05  4.4317e-05  2.3341e-08  4.0297e-06  0:00:09    9
   551  1.1499e-03  3.9667e-05  3.8532e-05  4.1705e-05  1.7520e-08  3.3980e-06  0:00:08    8
   552  1.1028e-03  3.7812e-05  3.6829e-05  3.9570e-05  1.3458e-08  2.9367e-06  0:00:07    7
   553  1.0633e-03  3.6262e-05  3.5407e-05  3.7796e-05  1.0504e-08  2.5962e-06  0:00:06    6
   554  1.0297e-03  3.4951e-05  3.4202e-05  3.6305e-05  8.2968e-09  2.3350e-06  0:00:05    5
   555  1.0007e-03  3.3819e-05  3.3161e-05  3.5038e-05  6.6159e-09  2.1355e-06  0:00:04    4
   556  9.7525e-04  3.2835e-05  3.2254e-05  3.3944e-05  5.3170e-09  1.9741e-06  0:00:03    3
!  556 solution is converged
Flow time = 0.01500000000000001s, time step = 30
3970 more time steps
 done.
   556  9.7525e-04  3.2835e-05  3.2254e-05  3.3944e-05  5.3170e-09  1.9741e-06  0:00:20   20
   557  5.6758e-03  9.5324e-04  8.6983e-04  1.5251e-02  3.9303e-04  1.5386e-02  0:00:23   19
   558  4.2305e-03  3.4562e-04  3.1565e-04  4.3790e-03  8.6846e-05  4.2115e-03  0:00:21   18
   559  2.9854e-03  1.6098e-04  1.4809e-04  1.2189e-03  1.9789e-05  9.9524e-04  0:00:19   17
   560  2.3266e-03  1.1059e-04  1.0359e-04  3.7119e-04  4.7569e-06  2.6525e-04  0:00:18   16
   561  1.9127e-03  8.9566e-05  8.4759e-05  1.4771e-04  1.2532e-06  7.8250e-05  0:00:16   15
   562  1.5868e-03  7.6032e-05  7.2276e-05  9.1430e-05  3.8590e-07  2.7603e-05  0:00:15   14
   563  1.3501e-03  6.6276e-05  6.3145e-05  7.4220e-05  1.4984e-07  1.2736e-05  0:00:14   13
   564  1.1826e-03  5.8910e-05  5.6253e-05  6.4846e-05  7.5330e-08  7.6672e-06  0:00:13   12
   565  1.0583e-03  5.3176e-05  5.0898e-05  5.7914e-05  4.6415e-08  5.4623e-06  0:00:11   11
   566  9.6284e-04  4.8595e-05  4.6619e-05  5.2473e-05  3.1252e-08  4.2320e-06  0:00:10   10
!  566 solution is converged
Flow time = 0.01550000000000001s, time step = 31
3969 more time steps
 done.
   Done.
   Cell count                              71706     72934     363362
   Mean cell count deviation               -1.3%     0.4%
   Partition boundary cell count           1847      2918      11490
   Partition boundary cell count ratio     2.6%      4.0%      3.2%
   Face count                              147967    151627    745942
   Mean face count deviation               -1.7%     0.8%
   Partition boundary face count           2067      3173      6331
   Partition boundary face count ratio     1.4%      2.1%      0.8%
   Mean cell weight deviation              -1.3%     0.4%
   Partition neighbor count                3         4
Done.
   566  9.6284e-04  4.8595e-05  4.6619e-05  5.2473e-05  3.1252e-08  4.2320e-06  0:00:21   20
   567  5.7253e-03  1.1674e-03  1.0674e-03  1.8367e-02  3.9266e-04  1.5036e-02  0:00:19   19
   568  4.1442e-03  4.1127e-04  3.7420e-04  5.1615e-03  8.6829e-05  4.1313e-03  0:00:18   18
   569  2.9325e-03  1.8778e-04  1.7137e-04  1.3929e-03  1.9795e-05  9.7147e-04  0:00:17   17
   570  2.2682e-03  1.2975e-04  1.2055e-04  4.2207e-04  4.7574e-06  2.5954e-04  0:00:16   16
   571  1.8483e-03  1.0642e-04  1.0000e-04  1.6993e-04  1.2509e-06  7.7456e-05  0:00:15   15
   572  1.5242e-03  9.1519e-05  8.6586e-05  1.0803e-04  3.8309e-07  2.8184e-05  0:00:14   14
   573  1.2952e-03  8.0741e-05  7.6776e-05  9.0438e-05  1.4731e-07  1.3755e-05  0:00:13   13
   574  1.1375e-03  7.2645e-05  6.9336e-05  8.0547e-05  7.3182e-08  8.8473e-06  0:00:12   12
   575  1.0215e-03  6.6368e-05  6.3544e-05  7.2948e-05  4.4606e-08  6.7533e-06  0:00:11   11
   576  9.3234e-04  6.1369e-05  5.8948e-05  6.6871e-05  2.9767e-08  5.6057e-06  0:00:10   10
!  576 solution is converged
Flow time = 0.01600000000000001s, time step = 32
3968 more time steps
 done.
   576  9.3234e-04  6.1369e-05  5.8948e-05  6.6871e-05  2.9767e-08  5.6057e-06  0:00:20   20
   577  5.8717e-03  1.3335e-03  1.2274e-03  1.9714e-02  3.9230e-04  1.4454e-02  0:00:23   19
   578  4.5413e-03  4.0240e-04  3.6781e-04  4.6964e-03  8.6816e-05  3.9682e-03  0:00:21   18
   579  3.2425e-03  1.8163e-04  1.6618e-04  1.2448e-03  1.9804e-05  9.4136e-04  0:00:19   17
   580  2.5346e-03  1.2615e-04  1.1756e-04  3.7988e-04  4.7600e-06  2.5278e-04  0:00:18   16
   581  2.0889e-03  1.0388e-04  9.8052e-05  1.5610e-04  1.2503e-06  7.6266e-05  0:00:16   15
   582  1.7408e-03  8.9591e-05  8.5251e-05  1.0268e-04  3.8184e-07  2.8369e-05  0:00:15   14
   583  1.4905e-03  7.9060e-05  7.5766e-05  8.7252e-05  1.4608e-07  1.4262e-05  0:00:14   13
   584  1.3175e-03  7.0990e-05  6.8441e-05  7.7732e-05  7.2114e-08  9.4325e-06  0:00:13   12
   585  1.1919e-03  6.4616e-05  6.2636e-05  7.0171e-05  4.3700e-08  7.3556e-06  0:00:11   11
   586  1.0958e-03  5.9491e-05  5.7922e-05  6.4060e-05  2.9015e-08  6.2162e-06  0:00:10   10
   587  1.0196e-03  5.5282e-05  5.4004e-05  5.9058e-05  2.0618e-08  5.4881e-06  0:00:09    9
   588  9.5736e-04  5.1752e-05  5.0694e-05  5.4894e-05  1.5232e-08  4.9801e-06  0:00:08    8
!  588 solution is converged
Flow time = 0.01650000000000001s, time step = 33
3967 more time steps
 done.
   588  9.5736e-04  5.1752e-05  5.0694e-05  5.4894e-05  1.5232e-08  4.9801e-06  0:00:20   20
   589  6.1257e-03  1.1727e-03  1.0878e-03  1.6549e-02  3.9196e-04  1.4202e-02  0:00:23   19
   590  4.9233e-03  3.4748e-04  3.2138e-04  3.9196e-03  8.6807e-05  3.9299e-03  0:00:21   18
   591  3.6409e-03  1.5444e-04  1.4325e-04  1.0418e-03  1.9815e-05  9.2779e-04  0:00:19   17
   592  2.9204e-03  1.0578e-04  9.9695e-05  3.1582e-04  4.7641e-06  2.4865e-04  0:00:18   16
   593  2.4584e-03  8.7175e-05  8.3146e-05  1.2813e-04  1.2510e-06  7.4368e-05  0:00:16   15
   594  2.0941e-03  7.5761e-05  7.2746e-05  8.5657e-05  3.8156e-07  2.7071e-05  0:00:15   14
   595  1.8293e-03  6.7576e-05  6.5226e-05  7.3661e-05  1.4562e-07  1.3115e-05  0:00:11   13
   596  1.6426e-03  6.1423e-05  5.9557e-05  6.6348e-05  7.1672e-08  8.3170e-06  0:00:11   12
   597  1.5046e-03  5.6717e-05  5.5189e-05  6.0679e-05  4.3299e-08  6.2371e-06  0:00:10   11
   598  1.3988e-03  5.2969e-05  5.1720e-05  5.6152e-05  2.8662e-08  5.0899e-06  0:00:09   10
   599  1.3154e-03  4.9907e-05  4.8887e-05  5.2527e-05  2.0306e-08  4.3419e-06  0:00:08    9
   600  1.2480e-03  4.7346e-05  4.6522e-05  4.9549e-05  1.4959e-08  3.8137e-06  0:00:08    8
   601  1.1921e-03  4.5164e-05  4.4512e-05  4.7048e-05  1.1291e-08  3.4237e-06  0:00:07    7
   602  1.1456e-03  4.3278e-05  4.2760e-05  4.4914e-05  8.6666e-09  3.1297e-06  0:00:06    6
   603  1.1058e-03  4.1621e-05  4.1210e-05  4.3077e-05  6.7358e-09  2.9022e-06  0:00:05    5
   604  1.0714e-03  4.0144e-05  3.9825e-05  4.1452e-05  5.2876e-09  2.7196e-06  0:00:04    4
   605  1.0414e-03  3.8808e-05  3.8570e-05  4.0009e-05  4.1851e-09  2.5741e-06  0:00:03    3
   606  1.0149e-03  3.7603e-05  3.7428e-05  3.8720e-05  3.3356e-09  2.4555e-06  0:00:02    2
   607  9.9133e-04  3.6500e-05  3.6381e-05  3.7538e-05  2.6744e-09  2.3572e-06  0:00:01    1
!  607 solution is converged
Flow time = 0.01700000000000001s, time step = 34
3966 more time steps
 done.
   607  9.9133e-04  3.6500e-05  3.6381e-05  3.7538e-05  2.6744e-09  2.3572e-06  0:00:20   20
   608  6.5977e-03  9.2902e-04  8.6768e-04  1.2429e-02  3.9164e-04  1.3831e-02  0:00:23   19
   609  5.3372e-03  2.8833e-04  2.6680e-04  3.0251e-03  8.6800e-05  3.8219e-03  0:00:21   18
   610  3.9970e-03  1.3252e-04  1.2259e-04  8.1576e-04  1.9826e-05  9.0701e-04  0:00:19   17
   611  3.2478e-03  9.2811e-05  8.7361e-05  2.5175e-04  4.7685e-06  2.4422e-04  0:00:18   16
   612  2.7625e-03  7.7542e-05  7.4042e-05  1.0630e-04  1.2520e-06  7.4269e-05  0:00:16   15
   613  2.3811e-03  6.8154e-05  6.5584e-05  7.5014e-05  3.8153e-07  2.8118e-05  0:00:15   14
   614  2.1064e-03  6.1381e-05  5.9367e-05  6.5924e-05  1.4538e-07  1.4507e-05  0:00:14   13
   615  1.9144e-03  5.6269e-05  5.4649e-05  6.0055e-05  7.1396e-08  9.8026e-06  0:00:12   12
   616  1.7730e-03  5.2315e-05  5.0996e-05  5.5420e-05  4.3031e-08  7.7190e-06  0:00:11   11
   617  1.6645e-03  4.9197e-05  4.8097e-05  5.1756e-05  2.8412e-08  6.5604e-06  0:00:10   10
   618  1.5786e-03  4.6657e-05  4.5725e-05  4.8818e-05  2.0077e-08  5.8022e-06  0:00:09    9
   619  1.5092e-03  4.4547e-05  4.3734e-05  4.6411e-05  1.4749e-08  5.2678e-06  0:00:08    8
   620  1.4524e-03  4.2759e-05  4.2030e-05  4.4393e-05  1.1102e-08  4.8949e-06  0:00:08    7
   621  1.4046e-03  4.1217e-05  4.0564e-05  4.2677e-05  8.4976e-09  4.6161e-06  0:00:07    6
   622  1.3638e-03  3.9864e-05  3.9288e-05  4.1195e-05  6.5859e-09  4.4041e-06  0:00:06    5
   623  1.3286e-03  3.8660e-05  3.8151e-05  3.9885e-05  5.1551e-09  4.2258e-06  0:00:04    4
   624  1.2979e-03  3.7583e-05  3.7135e-05  3.8720e-05  4.0683e-09  4.0818e-06  0:00:03    3
   625  1.2706e-03  3.6614e-05  3.6222e-05  3.7678e-05  3.2328e-09  3.9642e-06  0:00:02    2
   626  1.2460e-03  3.5732e-05  3.5396e-05  3.6734e-05  2.5843e-09  3.8669e-06  0:00:01    1
   627  1.2238e-03  3.4934e-05  3.4644e-05  3.5873e-05  2.0764e-09  3.7860e-06  0:00:00    0
Flow time = 0.01750000000000001s, time step = 35
3965 more time steps
 done.
   627  1.2238e-03  3.4934e-05  3.4644e-05  3.5873e-05  2.0764e-09  3.7860e-06  0:00:21   20
   628  7.0294e-03  7.2056e-04  6.7065e-04  8.3058e-03  3.9132e-04  1.3584e-02  0:00:20   19
   629  5.7576e-03  2.4383e-04  2.2445e-04  2.0895e-03  8.6791e-05  3.7587e-03  0:00:19   18
   630  4.3093e-03  1.2170e-04  1.1223e-04  5.8222e-04  1.9835e-05  8.9368e-04  0:00:21   17
   631  3.5085e-03  8.9289e-05  8.3825e-05  1.9131e-04  4.7715e-06  2.4076e-04  0:00:19   16
   632  2.9994e-03  7.5338e-05  7.1638e-05  9.1277e-05  1.2519e-06  7.2129e-05  0:00:17   15
   633  2.6003e-03  6.6355e-05  6.3518e-05  7.1041e-05  3.8066e-07  2.6014e-05  0:00:16   14
   634  2.3091e-03  5.9827e-05  5.7463e-05  6.3428e-05  1.4445e-07  1.2314e-05  0:00:14   13
   635  2.1023e-03  5.4861e-05  5.2837e-05  5.7827e-05  7.0567e-08  7.5813e-06  0:00:13   12
   636  1.9503e-03  5.0969e-05  4.9235e-05  5.3341e-05  4.2310e-08  5.5081e-06  0:00:12   11
   637  1.8329e-03  4.7865e-05  4.6372e-05  4.9767e-05  2.7802e-08  4.3525e-06  0:00:10   10
   638  1.7394e-03  4.5345e-05  4.4043e-05  4.6886e-05  1.9559e-08  3.6002e-06  0:00:09    9
   639  1.6637e-03  4.3251e-05  4.2109e-05  4.4533e-05  1.4309e-08  3.0696e-06  0:00:08    8
   640  1.6008e-03  4.1477e-05  4.0475e-05  4.2571e-05  1.0728e-08  2.6766e-06  0:00:07    7
   641  1.5477e-03  3.9958e-05  3.9071e-05  4.0910e-05  8.1802e-09  2.3794e-06  0:00:07    6
   642  1.5019e-03  3.8635e-05  3.7842e-05  3.9479e-05  6.3165e-09  2.1474e-06  0:00:06    5
   643  1.4621e-03  3.7479e-05  3.6761e-05  3.8239e-05  4.9266e-09  1.9648e-06  0:00:05    4
   644  1.4272e-03  3.6455e-05  3.5798e-05  3.7147e-05  3.8746e-09  1.8189e-06  0:00:03    3
   645  1.3960e-03  3.5537e-05  3.4938e-05  3.6177e-05  3.0685e-09  1.7059e-06  0:00:02    2
   646  1.3680e-03  3.4706e-05  3.4161e-05  3.5311e-05  2.4450e-09  1.6133e-06  0:00:01    1
   647  1.3430e-03  3.3956e-05  3.3457e-05  3.4527e-05  1.9585e-09  1.5352e-06  0:00:00    0
Flow time = 0.01800000000000001s, time step = 36
3964 more time steps
 done.
   Time = 0.153 seconds.
   Done.
   Cell count                              73723     75058     373942
   Mean cell count deviation               -1.4%     0.4%
   Partition boundary cell count           1815      3106      12076
   Partition boundary cell count ratio     2.4%      4.1%      3.2%
   Face count                              152300    155973    767102
   Mean face count deviation               -1.6%     0.8%
   Partition boundary face count           1994      3430      6705
   Partition boundary face count ratio     1.3%      2.2%      0.9%
   Cell weights                            7e+05     8e+05     4e+06
   Mean cell weight deviation              -1.4%     0.4%
Done.
   647  1.3430e-03  3.3956e-05  3.3457e-05  3.4527e-05  1.9585e-09  1.5352e-06  0:00:21   20
   648  7.6214e-03  6.1513e-04  5.5250e-04  4.5107e-03  3.9102e-04  1.3131e-02  0:00:20   19
   649  5.9569e-03  2.1752e-04  1.9552e-04  1.1918e-03  8.6784e-05  3.6816e-03  0:00:19   18
   650  4.4940e-03  1.1376e-04  1.0356e-04  3.5655e-04  1.9844e-05  8.6555e-04  0:00:18   17
   651  3.6489e-03  8.4772e-05  7.8925e-05  1.3494e-04  4.7737e-06  2.3167e-04  0:00:16   16
   652  3.1061e-03  7.1977e-05  6.8009e-05  7.9793e-05  1.2513e-06  6.9255e-05  0:00:18   15
   653  2.6918e-03  6.3773e-05  6.0737e-05  6.7745e-05  3.7942e-07  2.5220e-05  0:00:16   14
   654  2.3937e-03  5.7899e-05  5.5443e-05  6.1293e-05  1.4324e-07  1.2181e-05  0:00:15   13
   655  2.1829e-03  5.3517e-05  5.1448e-05  5.6301e-05  6.9518e-08  7.6159e-06  0:00:13   12
   656  2.0265e-03  5.0117e-05  4.8344e-05  5.2330e-05  4.1414e-08  5.5731e-06  0:00:12   11
   657  1.9061e-03  4.7407e-05  4.5879e-05  4.9186e-05  2.7058e-08  4.4085e-06  0:00:11   10
   658  1.8110e-03  4.5192e-05  4.3841e-05  4.6666e-05  1.8939e-08  3.6414e-06  0:00:10    9
   659  1.7345e-03  4.3324e-05  4.2116e-05  4.4587e-05  1.3791e-08  3.0965e-06  0:00:08    8
   660  1.6719e-03  4.1716e-05  4.0639e-05  4.2828e-05  1.0294e-08  2.6910e-06  0:00:07    7
   661  1.6197e-03  4.0311e-05  3.9350e-05  4.1311e-05  7.8163e-09  2.3903e-06  0:00:06    6
   662  1.5753e-03  3.9077e-05  3.8205e-05  3.9989e-05  6.0106e-09  2.1502e-06  0:00:06    5
   663  1.5370e-03  3.7985e-05  3.7183e-05  3.8824e-05  4.6690e-09  1.9550e-06  0:00:05    4
   664  1.5036e-03  3.7013e-05  3.6266e-05  3.7788e-05  3.6573e-09  1.7981e-06  0:00:03    3
   665  1.4742e-03  3.6134e-05  3.5435e-05  3.6858e-05  2.8851e-09  1.6707e-06  0:00:02    2
   666  1.4480e-03  3.5332e-05  3.4685e-05  3.6014e-05  2.2899e-09  1.5660e-06  0:00:01    1
   667  1.4246e-03  3.4600e-05  3.4000e-05  3.5248e-05  1.8272e-09  1.4787e-06  0:00:00    0
Flow time = 0.01850000000000001s, time step = 37
3963 more time steps
 done.
   667  1.4246e-03  3.4600e-05  3.4000e-05  3.5248e-05  1.8272e-09  1.4787e-06  0:00:21   20
   668  7.9654e-03  5.3861e-04  4.9478e-04  2.1999e-03  3.9074e-04  1.2940e-02  0:00:24   19
   669  6.2791e-03  2.1136e-04  1.9402e-04  6.3980e-04  8.6777e-05  3.8560e-03  0:00:22   18
   670  4.6809e-03  1.1673e-04  1.0686e-04  2.2148e-04  1.9852e-05  9.1722e-04  0:00:20   17
   671  3.8071e-03  8.7950e-05  8.2134e-05  1.0819e-04  4.7757e-06  2.4521e-04  0:00:18   16
   672  3.2586e-03  7.4151e-05  7.0211e-05  7.9633e-05  1.2506e-06  7.2712e-05  0:00:17   15
   673  2.8323e-03  6.5074e-05  6.1966e-05  6.8643e-05  3.7816e-07  2.6206e-05  0:00:15   14
   674  2.5213e-03  5.8501e-05  5.5861e-05  6.1419e-05  1.4204e-07  1.2593e-05  0:00:14   13
   675  2.2968e-03  5.3548e-05  5.1294e-05  5.5857e-05  6.8488e-08  7.8782e-06  0:00:15   12
   676  2.1275e-03  4.9703e-05  4.7766e-05  5.1511e-05  4.0546e-08  5.9202e-06  0:00:13   11
   677  1.9950e-03  4.6635e-05  4.4953e-05  4.8069e-05  2.6344e-08  4.7328e-06  0:00:12   10
   678  1.8881e-03  4.4123e-05  4.2662e-05  4.5275e-05  1.8350e-08  3.9627e-06  0:00:10    9
   679  1.7997e-03  4.2040e-05  4.0755e-05  4.2992e-05  1.3304e-08  3.4090e-06  0:00:09    8
   680  1.7258e-03  4.0292e-05  3.9142e-05  4.1105e-05  9.8898e-09  3.0348e-06  0:00:08    7
   681  1.6633e-03  3.8799e-05  3.7766e-05  3.9526e-05  7.4802e-09  2.7074e-06  0:00:06    6
   682  1.6095e-03  3.7508e-05  3.6578e-05  3.8179e-05  5.7311e-09  2.4822e-06  0:00:05    5
   683  1.5628e-03  3.6384e-05  3.5541e-05  3.7012e-05  4.4364e-09  2.3181e-06  0:00:04    4
   684  1.5216e-03  3.5395e-05  3.4628e-05  3.5988e-05  3.4636e-09  2.1998e-06  0:00:03    3
   685  1.4851e-03  3.4519e-05  3.3813e-05  3.5081e-05  2.7238e-09  2.0340e-06  0:00:02    2
   686  1.4526e-03  3.3732e-05  3.3083e-05  3.4272e-05  2.1556e-09  1.9335e-06  0:00:01    1
   687  1.4235e-03  3.3025e-05  3.2428e-05  3.3547e-05  1.7153e-09  1.8339e-06  0:00:00    0
Flow time = 0.01900000000000001s, time step = 38
3962 more time steps
 done.
   687  1.4235e-03  3.3025e-05  3.2428e-05  3.3547e-05  1.7153e-09  1.8339e-06  0:00:24   20
   688  8.3116e-03  5.3236e-04  4.9937e-04  3.3020e-03  3.9047e-04  1.2700e-02  0:00:25   19
   689  6.4507e-03  2.2501e-04  2.1097e-04  9.4916e-04  8.6772e-05  3.5852e-03  0:00:23   18
   690  4.6725e-03  1.2626e-04  1.1697e-04  3.0865e-04  1.9860e-05  8.5006e-04  0:00:21   17
   691  3.7161e-03  9.4458e-05  8.8703e-05  1.3515e-04  4.7776e-06  2.2984e-04  0:00:19   16
   692  3.1279e-03  7.8059e-05  7.4474e-05  8.7811e-05  1.2498e-06  6.9082e-05  0:00:17   15
   693  2.6815e-03  6.6956e-05  6.4403e-05  7.1842e-05  3.7689e-07  2.4960e-05  0:00:16   14
   694  2.3601e-03  5.9188e-05  5.7064e-05  6.2818e-05  1.4086e-07  1.1833e-05  0:00:14   13
   695  2.1324e-03  5.3532e-05  5.1723e-05  5.6357e-05  6.7491e-08  7.2675e-06  0:00:15   12
   696  1.9624e-03  4.9302e-05  4.7714e-05  5.1478e-05  3.9717e-08  5.2544e-06  0:00:13   11
   697  1.8312e-03  4.5983e-05  4.4609e-05  4.7720e-05  2.5672e-08  4.1255e-06  0:00:12   10
   698  1.7275e-03  4.3334e-05  4.2145e-05  4.4783e-05  1.7802e-08  3.3862e-06  0:00:10    9
   699  1.6435e-03  4.1101e-05  4.0061e-05  4.2398e-05  1.2854e-08  2.8639e-06  0:00:09    8
   700  1.5740e-03  3.9160e-05  3.8337e-05  4.0336e-05  9.5198e-09  2.4796e-06  0:00:08    7
   701  1.5150e-03  3.7589e-05  3.6857e-05  3.8665e-05  7.1746e-09  2.1845e-06  0:00:08    6
   702  1.4647e-03  3.6188e-05  3.5557e-05  3.7214e-05  5.4782e-09  1.9525e-06  0:00:06    5
   703  1.4208e-03  3.4959e-05  3.4432e-05  3.5928e-05  4.2265e-09  1.7801e-06  0:00:05    4
   704  1.3823e-03  3.3882e-05  3.3412e-05  3.4805e-05  3.2890e-09  1.6400e-06  0:00:03    3
   705  1.3482e-03  3.2908e-05  3.2514e-05  3.3796e-05  2.5778e-09  1.5236e-06  0:00:02    2
   706  1.3178e-03  3.2001e-05  3.1694e-05  3.2832e-05  2.0336e-09  1.4267e-06  0:00:01    1
   707  1.2902e-03  3.1255e-05  3.0940e-05  3.2075e-05  1.6130e-09  1.3451e-06  0:00:00    0
Flow time = 0.01950000000000001s, time step = 39
3961 more time steps
 done.
   707  1.2902e-03  3.1255e-05  3.0940e-05  3.2075e-05  1.6130e-09  1.3451e-06  0:00:21   20
   708  8.5655e-03  5.9899e-04  5.3648e-04  6.3115e-03  3.9020e-04  1.2942e-02  0:00:20   19
   709  6.4838e-03  2.4995e-04  2.2740e-04  1.7667e-03  8.6767e-05  5.0121e-02  0:00:22   18
   710  4.5591e-03  1.3354e-04  1.2300e-04  5.2621e-04  1.9868e-05  1.8696e-02  0:00:20   17
   711  3.5749e-03  9.8240e-05  9.3071e-05  1.9208e-04  4.7794e-06  6.5760e-03  0:00:19   16
   712  2.9669e-03  8.0743e-05  7.7413e-05  1.0075e-04  1.2491e-06  2.1587e-03  0:00:17   15
   713  2.4935e-03  6.8833e-05  6.6341e-05  7.6725e-05  3.7568e-07  6.4143e-04  0:00:15   14
   714  2.1538e-03  6.0358e-05  5.8274e-05  6.5823e-05  1.3975e-07  1.7369e-04  0:00:17   13
   715  1.9157e-03  5.4131e-05  5.2308e-05  5.8278e-05  6.6559e-08  5.0686e-05  0:00:15   12
   716  1.7403e-03  4.9410e-05  4.7769e-05  5.2551e-05  3.8946e-08  1.9570e-05  0:00:13   11
   717  1.6060e-03  4.5686e-05  4.4215e-05  4.8144e-05  2.5959e-08  1.4623e-05  0:00:11   10
   718  1.5007e-03  4.2650e-05  4.1336e-05  4.4617e-05  1.7934e-08  1.1433e-05  0:00:10    9
   719  1.4171e-03  4.0124e-05  3.8936e-05  4.1742e-05  1.2898e-08  9.9355e-06  0:00:09    8
   720  1.3483e-03  3.7987e-05  3.6900e-05  3.9364e-05  9.5136e-09  1.0464e-05  0:00:08    7
   721  1.2908e-03  3.6156e-05  3.5153e-05  3.7343e-05  7.1418e-09  1.0771e-05  0:00:08    6
   722  1.2420e-03  3.4569e-05  3.3648e-05  3.5604e-05  5.4324e-09  9.2889e-06  0:00:06    5
   723  1.1996e-03  3.3176e-05  3.2334e-05  3.4116e-05  4.1759e-09  8.9408e-06  0:00:05    4
   724  1.1624e-03  3.1942e-05  3.1173e-05  3.2811e-05  3.2382e-09  9.0028e-06  0:00:03    3
   725  1.1300e-03  3.0851e-05  3.0142e-05  3.1653e-05  2.5298e-09  8.9198e-06  0:00:02    2
   726  1.1012e-03  2.9873e-05  2.9221e-05  3.0615e-05  1.9891e-09  8.6405e-06  0:00:01    1
   727  1.0754e-03  2.8992e-05  2.8391e-05  2.9683e-05  1.5729e-09  8.3074e-06  0:00:00    0
Flow time = 0.02000000000000001s, time step = 40
3960 more time steps
 done.
   727  1.0754e-03  2.8992e-05  2.8391e-05  2.9683e-05  1.5729e-09  8.3074e-06  0:00:25   20
   728  8.5697e-03  8.1286e-04  7.4310e-04  9.0916e-03  3.8996e-04  1.2178e-02  0:00:23   19
   729  6.4193e-03  3.0346e-04  2.7801e-04  2.5267e-03  8.6764e-05  3.4809e-03  0:00:21   18
   730  4.4774e-03  1.4983e-04  1.3706e-04  7.2741e-04  1.9875e-05  8.2157e-04  0:00:23   17
   731  3.4614e-03  1.0468e-04  9.7499e-05  2.4576e-04  4.7810e-06  2.2341e-04  0:00:20   16
   732  2.8387e-03  8.4490e-05  7.9594e-05  1.1497e-04  1.2484e-06  6.8249e-05  0:00:18   15
   733  2.3529e-03  7.1081e-05  6.7479e-05  8.0308e-05  3.7448e-07  2.5555e-05  0:00:16   14
   734  1.9995e-03  6.1532e-05  5.8582e-05  6.7136e-05  1.3864e-07  1.2720e-05  0:00:15   13
   735  1.7501e-03  5.4314e-05  5.1896e-05  5.8568e-05  6.5634e-08  8.1986e-06  0:00:16   12
   736  1.5634e-03  4.8730e-05  4.6690e-05  5.2023e-05  3.8182e-08  6.1712e-06  0:00:14   11
   737  1.4186e-03  4.4356e-05  4.2590e-05  4.6978e-05  2.5324e-08  5.0227e-06  0:00:12   10
   738  1.3029e-03  4.0801e-05  3.9285e-05  4.2973e-05  1.7419e-08  4.2493e-06  0:00:10    9
   739  1.2090e-03  3.7853e-05  3.6552e-05  3.9687e-05  1.2479e-08  3.6887e-06  0:00:09    8
   740  1.1315e-03  3.5382e-05  3.4253e-05  3.6959e-05  9.1709e-09  3.2890e-06  0:00:08    7
   741  1.0662e-03  3.3268e-05  3.2301e-05  3.4651e-05  6.8610e-09  2.9881e-06  0:00:08    6
   742  1.0109e-03  3.1453e-05  3.0615e-05  3.2670e-05  5.2019e-09  2.7453e-06  0:00:06    5
   743  9.6336e-04  2.9878e-05  2.9137e-05  3.0952e-05  3.9864e-09  2.5451e-06  0:00:05    4
!  743 solution is converged
Flow time = 0.02050000000000001s, time step = 41
3959 more time steps
(cx-use-window-id 1)
 done.
>> Dividing domain into 5 partitions using Metis.
   Time = 0.163 seconds.
   Done.
>> 5 Stored Partitions:
   Collective Partition Statistics:        Minimum   Maximum   Total
   Cell count                              77405     78681     392069
   Mean cell count deviation               -1.3%     0.3%
   Partition boundary cell count           1863      3169      12574
   Partition boundary cell count ratio     2.4%      4.0%      3.2%
   Face count                              159670    163193    803356
   Mean face count deviation               -1.5%     0.7%
   Partition boundary face count           2022      3493      6899
   Partition boundary face count ratio     1.2%      2.1%      0.9%
   Cell weights                            8e+05     8e+05     4e+06
   Mean cell weight deviation              -1.3%     0.3%
   Partition Method                        Metis
   Stored Partition Count                  5
Done.
   743  9.6336e-04  2.9878e-05  2.9137e-05  3.0952e-05  3.9864e-09  2.5451e-06  0:00:24   20
   744  8.1001e-03  9.3353e-04  8.8151e-04  1.1130e-02  3.8973e-04  1.1819e-02  0:00:22   19
   745  5.9270e-03  3.3014e-04  3.0737e-04  3.0952e-03  8.6761e-05  3.4577e-03  0:00:20   18
   746  4.1336e-03  1.5455e-04  1.4327e-04  8.7633e-04  1.9882e-05  8.0900e-04  0:00:22   17
   747  3.1008e-03  1.0453e-04  9.8362e-05  2.8348e-04  4.7823e-06  2.1853e-04  0:00:20   16
   748  2.4613e-03  8.3017e-05  7.8714e-05  1.2433e-04  1.2473e-06  6.6142e-05  0:00:18   15
   749  1.9836e-03  6.8855e-05  6.5346e-05  8.0483e-05  3.7309e-07  2.4403e-05  0:00:16   14
   750  1.6370e-03  5.8512e-05  5.5518e-05  6.4692e-05  1.3741e-07  1.1913e-05  0:00:15   13
   751  1.3898e-03  5.0753e-05  4.8173e-05  5.5200e-05  6.4618e-08  7.4993e-06  0:00:13   12
   752  1.2048e-03  4.4807e-05  4.2553e-05  4.8119e-05  3.7349e-08  5.5104e-06  0:00:12   11
   753  1.0609e-03  4.0129e-05  3.8138e-05  4.2639e-05  2.4637e-08  4.3767e-06  0:00:13   10
   754  9.4737e-04  3.6371e-05  3.4606e-05  3.8320e-05  1.6865e-08  3.6276e-06  0:00:11    9
!  754 solution is converged
Flow time = 0.02100000000000002s, time step = 42
3958 more time steps
 done.
   754  9.4737e-04  3.6371e-05  3.4606e-05  3.8320e-05  1.6865e-08  3.6276e-06  0:00:24   20
   755  7.9482e-03  9.6096e-04  9.0552e-04  1.2531e-02  3.8951e-04  1.1733e-02  0:00:22   19
   756  5.7897e-03  3.3016e-04  3.0677e-04  3.3999e-03  8.6759e-05  3.4441e-03  0:00:24   18
   757  3.9894e-03  1.5018e-04  1.3753e-04  9.3395e-04  1.9888e-05  8.0842e-04  0:00:22   17
   758  3.0128e-03  1.0142e-04  9.3534e-05  2.9557e-04  4.7825e-06  2.2238e-04  0:00:19   16
   759  2.4010e-03  8.1498e-05  7.5883e-05  1.2602e-04  1.2456e-06  6.9192e-05  0:00:18   15
   760  1.9219e-03  6.8727e-05  6.4434e-05  8.0755e-05  3.7121e-07  2.6741e-05  0:00:16   14
   761  1.5757e-03  5.9428e-05  5.6007e-05  6.5917e-05  1.3580e-07  1.4033e-05  0:00:14   13
   762  1.3359e-03  5.2418e-05  4.9629e-05  5.7380e-05  6.3320e-08  9.6126e-06  0:00:13   12
   763  1.1623e-03  4.6979e-05  4.4680e-05  5.0935e-05  3.6303e-08  7.7180e-06  0:00:14   11
   764  1.0309e-03  4.2670e-05  4.0739e-05  4.5901e-05  2.3788e-08  6.7461e-06  0:00:12   10
   765  9.2788e-04  3.9178e-05  3.7547e-05  4.1880e-05  1.6192e-08  6.1458e-06  0:00:11    9
!  765 solution is converged
Flow time = 0.02150000000000002s, time step = 43
3957 more time steps
 done.
   765  9.2788e-04  3.9178e-05  3.7547e-05  4.1880e-05  1.6192e-08  6.1458e-06  0:00:23   20
   766  8.5159e-03  9.1145e-04  8.3352e-04  1.2632e-02  3.8930e-04  1.1469e-02  0:00:22   19
   767  6.3976e-03  2.9949e-04  2.7346e-04  3.1078e-03  8.6759e-05  4.3590e-03  0:00:24   18
   768  4.4550e-03  1.4483e-04  1.3182e-04  8.5492e-04  1.9895e-05  1.1617e-03  0:00:21   17
   769  3.4180e-03  1.0205e-04  9.4361e-05  2.7574e-04  4.7838e-06  3.2154e-04  0:00:19   16
   770  2.7785e-03  8.3121e-05  7.7719e-05  1.2118e-04  1.2447e-06  9.2469e-05  0:00:17   15
   771  2.2764e-03  7.0774e-05  6.6636e-05  8.0940e-05  3.6998e-07  3.0809e-05  0:00:16   14
   772  1.9113e-03  6.1945e-05  5.8567e-05  6.8190e-05  1.3474e-07  1.3780e-05  0:00:14   13
   773  1.6552e-03  5.5322e-05  5.2513e-05  6.0282e-05  6.2462e-08  8.4627e-06  0:00:15   12
   774  1.4670e-03  5.0190e-05  4.7804e-05  5.4169e-05  3.5619e-08  6.2480e-06  0:00:13   11
   775  1.3219e-03  4.6092e-05  4.4019e-05  4.9301e-05  2.3238e-08  5.1109e-06  0:00:12   10
   776  1.2070e-03  4.2731e-05  4.0921e-05  4.5374e-05  1.5760e-08  4.2187e-06  0:00:10    9
   777  1.1140e-03  3.9898e-05  3.8333e-05  4.2114e-05  1.1152e-08  3.7215e-06  0:00:09    8
   778  1.0368e-03  3.7463e-05  3.6117e-05  3.9370e-05  8.1053e-09  3.2798e-06  0:00:08    7
   779  9.7170e-04  3.5330e-05  3.4190e-05  3.7020e-05  6.0018e-09  2.9237e-06  0:00:08    6
!  779 solution is converged
Flow time = 0.02200000000000002s, time step = 44
3956 more time steps
 done.
   779  9.7170e-04  3.5330e-05  3.4190e-05  3.7020e-05  6.0018e-09  2.9237e-06  0:00:25   20
   780  8.9407e-03  7.9588e-04  7.2605e-04  1.0668e-02  3.8911e-04  1.1268e-02  0:00:27   19
   781  6.8196e-03  2.7394e-04  2.4979e-04  2.6535e-03  8.6763e-05  3.3117e-03  0:00:24   18
   782  4.8254e-03  1.3609e-04  1.2530e-04  7.3707e-04  1.9904e-05  7.8333e-04  0:00:22   17
   783  3.7620e-03  9.7054e-05  9.1279e-05  2.4273e-04  4.7861e-06  2.1599e-04  0:00:19   16
   784  3.1033e-03  7.9253e-05  7.5593e-05  1.0979e-04  1.2447e-06  6.6714e-05  0:00:18   15
   785  2.5898e-03  6.7714e-05  6.4841e-05  7.6399e-05  3.6947e-07  2.4919e-05  0:00:19   14
   786  2.2213e-03  5.9552e-05  5.7043e-05  6.5282e-05  1.3423e-07  1.2239e-05  0:00:17   13
   787  1.9644e-03  5.3507e-05  5.1306e-05  5.8020e-05  6.2050e-08  7.7680e-06  0:00:15   12
   788  1.7752e-03  4.8900e-05  4.6967e-05  5.2432e-05  3.5287e-08  5.7809e-06  0:00:13   11
   789  1.6287e-03  4.5254e-05  4.3554e-05  4.8055e-05  2.2968e-08  4.6828e-06  0:00:11   10
   790  1.5125e-03  4.2272e-05  4.0771e-05  4.4558e-05  1.5543e-08  3.9644e-06  0:00:12    9
   791  1.4180e-03  3.9787e-05  3.8448e-05  4.1678e-05  1.0976e-08  3.4602e-06  0:00:10    8
   792  1.3398e-03  3.7678e-05  3.6456e-05  3.9268e-05  7.9627e-09  3.0884e-06  0:00:08    7
   793  1.2736e-03  3.5845e-05  3.4733e-05  3.7210e-05  5.8859e-09  2.8022e-06  0:00:07    6
   794  1.2170e-03  3.4239e-05  3.3228e-05  3.5434e-05  4.4145e-09  2.5709e-06  0:00:06    5
   795  1.1679e-03  3.2926e-05  3.1893e-05  3.3877e-05  3.3481e-09  2.3845e-06  0:00:05    4
   796  1.1251e-03  3.1694e-05  3.0723e-05  3.2544e-05  2.5620e-09  2.2298e-06  0:00:04    3
   797  1.0866e-03  3.0437e-05  2.9628e-05  3.1249e-05  1.9776e-09  2.1008e-06  0:00:02    2
   798  1.0527e-03  2.9372e-05  2.8617e-05  3.0099e-05  1.5376e-09  1.9911e-06  0:00:01    1
   799  1.0220e-03  2.8404e-05  2.7698e-05  2.9069e-05  1.2033e-09  1.8975e-06  0:00:00    0
Flow time = 0.02250000000000002s, time step = 45
3955 more time steps
 done.
   799  1.0220e-03  2.8404e-05  2.7698e-05  2.9069e-05  1.2033e-09  1.8975e-06  0:00:22   20
   800  9.5739e-03  8.9385e-04  7.9158e-04  7.9848e-03  3.8894e-04  1.1114e-02  0:00:25   19
   801  7.3593e-03  2.9586e-04  2.6550e-04  2.0290e-03  8.6768e-05  5.1584e-03  0:00:22   18
   802  5.2876e-03  1.3927e-04  1.2558e-04  5.7939e-04  1.9912e-05  1.3623e-03  0:00:20   17
   803  4.1842e-03  9.6331e-05  8.8804e-05  2.0014e-04  4.7881e-06  3.7958e-04  0:00:18   16
   804  3.4959e-03  7.8455e-05  7.3456e-05  9.8013e-05  1.2444e-06  1.0774e-04  0:00:17   15
   805  2.9576e-03  6.7199e-05  6.3376e-05  7.3121e-05  3.6877e-07  3.2392e-05  0:00:18   14
   806  2.5643e-03  5.9230e-05  5.6154e-05  6.3709e-05  1.3358e-07  1.7420e-05  0:00:16   13
   807  2.2861e-03  5.3369e-05  5.0796e-05  5.7161e-05  6.1519e-08  1.3874e-05  0:00:14   12
   808  2.0809e-03  4.8890e-05  4.6710e-05  5.2030e-05  3.4859e-08  1.2698e-05  0:00:13   11
   809  1.9189e-03  4.5377e-05  4.3507e-05  4.8086e-05  2.2619e-08  1.1937e-05  0:00:13   10
   810  1.7924e-03  4.2561e-05  4.0944e-05  4.4953e-05  1.5265e-08  1.1890e-05  0:00:11    9
   811  1.6874e-03  4.0231e-05  3.8806e-05  4.2364e-05  1.0753e-08  1.1467e-05  0:00:10    8
   812  1.5999e-03  3.8282e-05  3.7003e-05  4.0222e-05  7.7828e-09  1.0874e-05  0:00:08    7
   813  1.5291e-03  3.6610e-05  3.5446e-05  3.8448e-05  5.7411e-09  1.0465e-05  0:00:07    6
   814  1.4632e-03  3.5179e-05  3.4091e-05  3.6814e-05  4.2958e-09  1.0193e-05  0:00:07    5
   815  1.4093e-03  3.3892e-05  3.2891e-05  3.5536e-05  3.2517e-09  1.0486e-05  0:00:05    4
   816  1.3644e-03  3.2769e-05  3.1840e-05  3.4270e-05  2.4855e-09  1.0934e-05  0:00:04    3
   817  1.3172e-03  3.1736e-05  3.0867e-05  3.3179e-05  1.9160e-09  1.0247e-05  0:00:02    2
   818  1.2791e-03  3.0806e-05  3.0000e-05  3.2205e-05  1.4879e-09  1.0008e-05  0:00:01    1
   819  1.2484e-03  2.9943e-05  2.9194e-05  3.1329e-05  1.1633e-09  9.9112e-06  0:00:00    0
Flow time = 0.02300000000000002s, time step = 46
3954 more time steps
 done.
Updating mesh at time level N... (cx-use-window-id 1)
done.
   819  1.2484e-03  2.9943e-05  2.9194e-05  3.1329e-05  1.1633e-09  9.9112e-06  0:00:26   20
   820  9.5145e-03  7.0040e-04  6.2854e-04  5.1968e-03  3.8878e-04  1.0790e-02  0:00:27   19
   821  7.4785e-03  2.4420e-04  2.2035e-04  1.3661e-03  8.6774e-05  3.2062e-03  0:00:24   18
   822  5.4313e-03  1.2161e-04  1.1129e-04  4.0886e-04  1.9919e-05  7.5540e-04  0:00:22   17
   823  4.3034e-03  8.7826e-05  8.2111e-05  1.5352e-04  4.7894e-06  2.0892e-04  0:00:20   16
   824  3.5918e-03  7.3502e-05  6.9679e-05  8.4883e-05  1.2436e-06  6.4822e-05  0:00:18   15
   825  3.0410e-03  6.4165e-05  6.1204e-05  6.8844e-05  3.6767e-07  2.4474e-05  0:00:16   14
   826  2.6436e-03  5.7336e-05  5.4898e-05  6.1157e-05  1.3263e-07  1.2202e-05  0:00:14   13
   827  2.3623e-03  5.2121e-05  5.0094e-05  5.5237e-05  6.0745e-08  7.8170e-06  0:00:16   12
   828  2.1538e-03  4.8024e-05  4.6338e-05  5.0508e-05  3.4235e-08  5.8354e-06  0:00:14   11
   829  1.9913e-03  4.4741e-05  4.3331e-05  4.6739e-05  2.2111e-08  4.7137e-06  0:00:12   10
   830  1.8608e-03  4.2050e-05  4.0878e-05  4.3691e-05  1.4862e-08  3.9683e-06  0:00:10    9
   831  1.7551e-03  3.9800e-05  3.8815e-05  4.1173e-05  1.0431e-08  3.4343e-06  0:00:09    8
   832  1.6670e-03  3.7895e-05  3.7058e-05  3.9049e-05  7.5250e-09  3.0326e-06  0:00:09    7
   833  1.5927e-03  3.6257e-05  3.5531e-05  3.7252e-05  5.5342e-09  2.7232e-06  0:00:07    6
   834  1.5290e-03  3.4837e-05  3.4190e-05  3.5714e-05  4.1294e-09  2.4805e-06  0:00:06    5
   835  1.4738e-03  3.3593e-05  3.3010e-05  3.4373e-05  3.1178e-09  2.2872e-06  0:00:05    4
   836  1.4255e-03  3.2498e-05  3.1971e-05  3.3196e-05  2.3776e-09  2.1297e-06  0:00:04    3
   837  1.3831e-03  3.1528e-05  3.1044e-05  3.2163e-05  1.8291e-09  2.0009e-06  0:00:02    2
   838  1.3453e-03  3.0660e-05  3.0211e-05  3.1243e-05  1.4180e-09  1.8941e-06  0:00:01    1
   839  1.3115e-03  2.9879e-05  2.9454e-05  3.0416e-05  1.1071e-09  1.8039e-06  0:00:00    0
Flow time = 0.02350000000000002s, time step = 47
3953 more time steps
 done.
   Time = 0.168 seconds.
   Done.
   Cell count                              80414     80450     402142
   Mean cell count deviation               -0.0%     0.0%
   Partition boundary cell count           1843      3289      12131
   Partition boundary cell count ratio     2.3%      4.1%      3.0%
   Face count                              165381    166622    823502
   Mean face count deviation               -0.4%     0.4%
   Partition boundary face count           1981      3643      6666
   Mean cell weight deviation              -0.0%     0.0%
Done.
   839  1.3115e-03  2.9879e-05  2.9454e-05  3.0416e-05  1.1071e-09  1.8039e-06  0:00:23   20
   840  9.8515e-03  6.2315e-04  5.6164e-04  2.8030e-03  3.8863e-04  1.0581e-02  0:00:25   19
   841  7.5484e-03  2.2068e-04  1.9841e-04  7.7817e-04  8.6781e-05  3.1429e-03  0:00:23   18
   842  5.5375e-03  1.1238e-04  1.0212e-04  2.5739e-04  1.9927e-05  7.3973e-04  0:00:20   17
   843  4.3717e-03  8.1400e-05  7.5599e-05  1.1348e-04  4.7906e-06  2.0326e-04  0:00:22   16
   844  3.6489e-03  6.7962e-05  6.4053e-05  7.4783e-05  1.2428e-06  6.2489e-05  0:00:19   15
   845  3.1045e-03  5.9349e-05  5.6386e-05  6.3459e-05  3.6653e-07  2.3262e-05  0:00:17   14
   846  2.7082e-03  5.3079e-05  5.0684e-05  5.6439e-05  1.3163e-07  1.1346e-05  0:00:15   13
   847  2.4251e-03  4.8334e-05  4.6322e-05  5.0982e-05  5.9939e-08  7.0512e-06  0:00:14   12
   848  2.2127e-03  4.4688e-05  4.2943e-05  4.6689e-05  3.3585e-08  5.0837e-06  0:00:12   11
   849  2.0466e-03  4.1809e-05  4.0279e-05  4.3341e-05  2.1582e-08  3.9656e-06  0:00:13   10
   850  1.9137e-03  3.9465e-05  3.8127e-05  4.0700e-05  1.4442e-08  3.2218e-06  0:00:11    9
   851  1.8055e-03  3.7524e-05  3.6345e-05  3.8556e-05  1.0095e-08  2.6923e-06  0:00:10    8
   852  1.7154e-03  3.5885e-05  3.4845e-05  3.6781e-05  7.2555e-09  2.2956e-06  0:00:08    7
   853  1.6393e-03  3.4476e-05  3.3560e-05  3.5275e-05  5.3170e-09  1.9916e-06  0:00:07    6
   854  1.5740e-03  3.3249e-05  3.2440e-05  3.3979e-05  3.9544e-09  1.7545e-06  0:00:05    5
   855  1.5174e-03  3.2163e-05  3.1449e-05  3.2842e-05  2.9765e-09  1.5644e-06  0:00:05    4
   856  1.4678e-03  3.1195e-05  3.0565e-05  3.1829e-05  2.2636e-09  1.4108e-06  0:00:04    3
   857  1.4244e-03  3.0331e-05  2.9770e-05  3.0919e-05  1.7369e-09  1.2813e-06  0:00:02    2
   858  1.3860e-03  2.9552e-05  2.9050e-05  3.0100e-05  1.3435e-09  1.1733e-06  0:00:01    1
   859  1.3516e-03  2.8850e-05  2.8390e-05  2.9362e-05  1.0469e-09  1.0831e-06  0:00:00    0
Flow time = 0.02400000000000002s, time step = 48
3952 more time steps
 done.
   859  1.3516e-03  2.8850e-05  2.8390e-05  2.9362e-05  1.0469e-09  1.0831e-06  0:00:22   20
   860  1.0507e-02  6.3528e-04  5.6332e-04  1.5922e-03  3.8850e-04  1.0457e-02  0:00:25   19
   861  7.8188e-03  2.4142e-04  2.1877e-04  4.9968e-04  8.6790e-05  3.1580e-03  0:00:22   18
   862  5.6178e-03  1.2760e-04  1.1638e-04  1.9835e-04  1.9934e-05  7.4355e-04  0:00:20   17
   863  4.4291e-03  9.2689e-05  8.6049e-05  1.1080e-04  4.7916e-06  2.0509e-04  0:00:22   16
   864  3.6893e-03  7.6740e-05  7.2112e-05  8.3488e-05  1.2418e-06  6.3186e-05  0:00:19   15
   865  3.1165e-03  6.6603e-05  6.2964e-05  7.1385e-05  3.6531e-07  2.3405e-05  0:00:17   14
   866  2.6992e-03  5.9446e-05  5.6355e-05  6.3175e-05  1.3059e-07  1.1338e-05  0:00:15   13
   867  2.4044e-03  5.4099e-05  5.1392e-05  5.6916e-05  5.9120e-08  7.0452e-06  0:00:14   12
   868  2.1847e-03  4.9887e-05  4.7565e-05  5.1992e-05  3.2942e-08  5.1201e-06  0:00:12   11
   869  2.0145e-03  4.6461e-05  4.4539e-05  4.8100e-05  2.1074e-08  4.0180e-06  0:00:13   10
   870  1.8790e-03  4.3605e-05  4.2011e-05  4.4962e-05  1.4051e-08  3.2840e-06  0:00:11    9
   871  1.7687e-03  4.1183e-05  3.9871e-05  4.2357e-05  9.7936e-09  2.7603e-06  0:00:09    8
   872  1.6761e-03  3.9119e-05  3.8018e-05  4.0170e-05  7.0217e-09  2.3694e-06  0:00:08    7
   873  1.5974e-03  3.7328e-05  3.6392e-05  3.8288e-05  5.1353e-09  2.0696e-06  0:00:07    6
   874  1.5297e-03  3.5767e-05  3.4950e-05  3.6653e-05  3.8130e-09  1.8343e-06  0:00:06    5
   875  1.4709e-03  3.4385e-05  3.3666e-05  3.5220e-05  2.8663e-09  1.6460e-06  0:00:05    4
   876  1.4190e-03  3.3156e-05  3.2505e-05  3.3938e-05  2.1775e-09  1.4921e-06  0:00:04    3
   877  1.3728e-03  3.2039e-05  3.1446e-05  3.2779e-05  1.6696e-09  1.3641e-06  0:00:02    2
   878  1.3314e-03  3.1014e-05  3.0477e-05  3.1718e-05  1.2909e-09  1.2573e-06  0:00:01    1
   879  1.2942e-03  3.0084e-05  2.9593e-05  3.0746e-05  1.0056e-09  1.1665e-06  0:00:00    0
Flow time = 0.02450000000000002s, time step = 49
3951 more time steps
 done.
   879  1.2942e-03  3.0084e-05  2.9593e-05  3.0746e-05  1.0056e-09  1.1665e-06  0:00:26   20
   880  1.0363e-02  5.5498e-04  4.9287e-04  2.9771e-03  3.8837e-04  1.0214e-02  0:00:24   19
   881  7.8689e-03  2.1548e-04  1.9487e-04  8.5541e-04  8.6799e-05  3.1007e-03  0:00:25   18
   882  5.5935e-03  1.1703e-04  1.0655e-04  2.8395e-04  1.9941e-05  7.2065e-04  0:00:22   17
   883  4.3821e-03  8.6575e-05  8.0633e-05  1.2559e-04  4.7926e-06  1.9993e-04  0:00:20   16
   884  3.6196e-03  7.1991e-05  6.8023e-05  8.1617e-05  1.2409e-06  6.2624e-05  0:00:18   15
   885  3.0210e-03  6.2300e-05  5.9279e-05  6.7136e-05  3.6423e-07  2.4066e-05  0:00:16   14
   886  2.5870e-03  5.5211e-05  5.2833e-05  5.8868e-05  1.2969e-07  1.2256e-05  0:00:17   13
   887  2.2766e-03  4.9876e-05  4.7906e-05  5.2738e-05  5.8409e-08  7.9804e-06  0:00:15   12
   888  2.0448e-03  4.5728e-05  4.4075e-05  4.7993e-05  3.2382e-08  6.0321e-06  0:00:13   11
   889  1.8639e-03  4.2435e-05  4.1021e-05  4.4268e-05  2.0628e-08  4.9107e-06  0:00:12   10
   890  1.7198e-03  3.9752e-05  3.8527e-05  4.1282e-05  1.3703e-08  4.1601e-06  0:00:10    9
   891  1.6027e-03  3.7504e-05  3.6426e-05  3.8821e-05  9.5201e-09  3.6286e-06  0:00:10    8
   892  1.5060e-03  3.5595e-05  3.4624e-05  3.6743e-05  6.8054e-09  3.2415e-06  0:00:09    7
   893  1.4249e-03  3.3947e-05  3.3066e-05  3.4969e-05  4.9636e-09  2.9417e-06  0:00:07    6
   894  1.3559e-03  3.2502e-05  3.1699e-05  3.3424e-05  3.6761e-09  2.7002e-06  0:00:06    5
   895  1.2967e-03  3.1217e-05  3.0487e-05  3.2066e-05  2.7568e-09  2.5110e-06  0:00:05    4
   896  1.2453e-03  3.0066e-05  2.9417e-05  3.0860e-05  2.0897e-09  2.3552e-06  0:00:04    3
   897  1.2002e-03  2.9027e-05  2.8454e-05  2.9784e-05  1.5990e-09  2.2240e-06  0:00:02    2
   898  1.1603e-03  2.8075e-05  2.7585e-05  2.8800e-05  1.2339e-09  2.1131e-06  0:00:01    1
   899  1.1247e-03  2.7202e-05  2.6790e-05  2.7909e-05  9.5964e-10  2.0196e-06  0:00:00    0
(update-animation-object "animation-3")
Creating animation sequence file: C:\\Users\\Alberto\\Desktop\\falling_seed\\seed_one_files\\dp0\\FFF\\Fluent\\\\.\\\\animation-3.cxa
(update-animation-object "animation-2")
Creating animation sequence file: C:\\Users\\Alberto\\Desktop\\falling_seed\\seed_one_files\\dp0\\FFF\\Fluent\\\\.\\\\animation-2.cxa
(update-animation-object "animation-1")
Creating animation sequence file: C:\\Users\\Alberto\\Desktop\\falling_seed\\seed_one_files\\dp0\\FFF\\Fluent\\\\.\\\\animation-1.cxa
Flow time = 0.02500000000000002s, time step = 50
3950 more time steps
 done.
   899  1.1247e-03  2.7202e-05  2.6790e-05  2.7909e-05  9.5964e-10  2.0196e-06  0:00:23   20
   900  1.0683e-02  6.3609e-04  5.6429e-04  5.0837e-03  3.8826e-04  1.0046e-02  0:00:25   19
   901  7.9097e-03  2.4297e-04  2.1703e-04  1.4170e-03  8.6810e-05  3.0236e-03  0:00:26   18
   902  5.5127e-03  1.2500e-04  1.1338e-04  4.3256e-04  1.9948e-05  7.1298e-04  0:00:23   17
   903  4.2027e-03  9.0219e-05  8.3843e-05  1.6445e-04  4.7935e-06  1.9824e-04  0:00:21   16
   904  3.3874e-03  7.4054e-05  6.9651e-05  8.9673e-05  1.2399e-06  6.2148e-05  0:00:18   15
   905  2.7653e-03  6.3139e-05  5.9599e-05  6.8568e-05  3.6306e-07  2.3957e-05  0:00:17   14
   906  2.3143e-03  5.5053e-05  5.2103e-05  5.8674e-05  1.2871e-07  1.2294e-05  0:00:15   13
   907  1.9947e-03  4.8851e-05  4.6390e-05  5.1609e-05  5.7634e-08  8.0727e-06  0:00:16   12
   908  1.7584e-03  4.3988e-05  4.1955e-05  4.6115e-05  3.1774e-08  6.1307e-06  0:00:14   11
   909  1.5765e-03  4.0133e-05  3.8426e-05  4.1815e-05  2.0146e-08  5.0386e-06  0:00:12   10
   910  1.4339e-03  3.7012e-05  3.5552e-05  3.8406e-05  1.3331e-08  4.2984e-06  0:00:10    9
   911  1.3201e-03  3.4428e-05  3.3166e-05  3.5613e-05  9.2307e-09  3.7582e-06  0:00:09    8
   912  1.2274e-03  3.2245e-05  3.1158e-05  3.3281e-05  6.5795e-09  3.3504e-06  0:00:08    7
   913  1.1511e-03  3.0387e-05  2.9444e-05  3.1306e-05  4.7869e-09  3.0395e-06  0:00:06    6
   914  1.0878e-03  2.8789e-05  2.7976e-05  2.9616e-05  3.5378e-09  2.7947e-06  0:00:06    5
   915  1.0345e-03  2.7402e-05  2.6703e-05  2.8161e-05  2.6485e-09  2.6006e-06  0:00:05    4
   916  9.8931e-04  2.6187e-05  2.5588e-05  2.6896e-05  2.0050e-09  2.4516e-06  0:00:04    3
!  916 solution is converged
Flow time = 0.02550000000000002s, time step = 51
3949 more time steps
(cx-set-camera-relative '(0.0242794 -0.0108583 -0.0440158) '(0 0 0) '(0.170573 -0.0395451 0.103049) 0 0)
(cx-set-camera-relative '(0.0188594 0.00197589 -0.0519243) '(0 0 0) '(0.178125 -0.0379114 0.0632562) 0 0)
 done.
   916  9.8931e-04  2.6187e-05  2.5588e-05  2.6896e-05  2.0050e-09  2.4516e-06  0:00:23   20
   917  1.0686e-02  7.1218e-04  6.3453e-04  6.5392e-03  3.8816e-04  9.8942e-03  0:00:25   19
   918  7.7671e-03  2.5961e-04  2.3352e-04  1.8118e-03  8.6822e-05  3.0608e-03  0:00:23   18
   919  5.3280e-03  1.2821e-04  1.1516e-04  5.3601e-04  1.9955e-05  7.1594e-04  0:00:21   17
   920  4.0357e-03  8.9447e-05  8.1392e-05  1.9142e-04  4.7940e-06  1.9955e-04  0:00:19   16
   921  3.2399e-03  7.1852e-05  6.6154e-05  9.5016e-05  1.2386e-06  6.2865e-05  0:00:20   15
   922  2.6163e-03  6.0311e-05  5.5970e-05  6.7594e-05  3.6170e-07  2.4362e-05  0:00:18   14
   923  2.1627e-03  5.1985e-05  4.8604e-05  5.6523e-05  1.2761e-07  1.2559e-05  0:00:16   13
   924  1.8423e-03  4.5800e-05  4.3059e-05  4.9166e-05  5.6786e-08  8.3005e-06  0:00:14   12
   925  1.6064e-03  4.1077e-05  3.8769e-05  4.3558e-05  3.1119e-08  6.3462e-06  0:00:13   11
   926  1.4242e-03  3.7360e-05  3.5373e-05  3.9196e-05  1.9634e-08  5.2341e-06  0:00:13   10
   927  1.2794e-03  3.4317e-05  3.2596e-05  3.5743e-05  1.2940e-08  4.4875e-06  0:00:11    9
   928  1.1628e-03  3.1775e-05  3.0273e-05  3.2910e-05  8.9300e-09  3.9285e-06  0:00:10    8
   929  1.0674e-03  2.9609e-05  2.8295e-05  3.0537e-05  6.3467e-09  3.5249e-06  0:00:08    7
   930  9.8789e-04  2.7741e-05  2.6575e-05  2.8528e-05  4.6056e-09  3.2148e-06  0:00:07    6
!  930 solution is converged
Flow time = 0.02600000000000002s, time step = 52
3948 more time steps
 done.
   Time = 0.174 seconds.
   Done.
   Cell count                              83535     84082     419567
   Mean cell count deviation               -0.5%     0.2%
   Partition boundary cell count           1956      3219      12737
   Partition boundary cell count ratio     2.3%      3.8%      3.0%
   Face count                              172612    173720    858352
   Mean face count deviation               -0.3%     0.4%
   Partition boundary face count           2101      3548      7003
   Partition boundary face count ratio     1.2%      2.0%      0.8%
   Mean cell weight deviation              -0.5%     0.2%
   Partition neighbor count                2         4
Done.
   930  9.8789e-04  2.7741e-05  2.6575e-05  2.8528e-05  4.6056e-09  3.2148e-06  0:00:23   20
   931  1.1299e-02  8.5819e-04  7.3641e-04  7.4730e-03  3.8808e-04  9.6860e-03  0:00:25   19
   932  7.8026e-03  3.1187e-04  2.6675e-04  2.0783e-03  8.6837e-05  2.9233e-03  0:00:22   18
   933  5.2409e-03  1.5498e-04  1.3248e-04  6.2026e-04  1.9963e-05  6.8673e-04  0:00:20   17
   934  3.8460e-03  1.0601e-04  9.2542e-05  2.2470e-04  4.7949e-06  1.9118e-04  0:00:18   16
   935  3.0034e-03  8.3502e-05  7.4408e-05  1.1297e-04  1.2377e-06  6.0010e-05  0:00:17   15
   936  2.3696e-03  6.8992e-05  6.2345e-05  7.8653e-05  3.6057e-07  2.3053e-05  0:00:18   14
   937  1.9154e-03  5.8710e-05  5.3558e-05  6.4195e-05  1.2666e-07  1.1669e-05  0:00:16   13
   938  1.5964e-03  5.1133e-05  4.6949e-05  5.5118e-05  5.6051e-08  7.5035e-06  0:00:14   12
   939  1.3624e-03  4.5369e-05  4.1806e-05  4.8335e-05  3.0547e-08  5.5799e-06  0:00:13   11
   940  1.1828e-03  4.0743e-05  3.7631e-05  4.3011e-05  1.9186e-08  4.4691e-06  0:00:13   10
   941  1.0423e-03  3.6925e-05  3.4208e-05  3.8728e-05  1.2598e-08  3.7272e-06  0:00:13    9
   942  9.3025e-04  3.3736e-05  3.1328e-05  3.5205e-05  8.6676e-09  3.1996e-06  0:00:11    8
!  942 solution is converged
Flow time = 0.02650000000000002s, time step = 53
3947 more time steps
 done.
   942  9.3025e-04  3.3736e-05  3.1328e-05  3.5205e-05  8.6676e-09  3.1996e-06  0:00:27   20
   943  1.0115e-02  7.8214e-04  7.0580e-04  7.9391e-03  3.8800e-04  9.4361e-03  0:00:28   19
   944  7.4833e-03  2.8040e-04  2.5161e-04  2.1427e-03  8.6850e-05  2.9116e-03  0:00:25   18
   945  5.1084e-03  1.3653e-04  1.2275e-04  6.1809e-04  1.9969e-05  6.7724e-04  0:00:22   17
   946  3.8113e-03  9.5135e-05  8.6948e-05  2.1779e-04  4.7954e-06  1.8815e-04  0:00:20   16
   947  3.0051e-03  7.7016e-05  7.1241e-05  1.0725e-04  1.2366e-06  5.9180e-05  0:00:18   15
   948  2.3867e-03  6.5084e-05  6.0574e-05  7.5115e-05  3.5938e-07  2.2907e-05  0:00:16   14
   949  1.9427e-03  5.6312e-05  5.2649e-05  6.2788e-05  1.2572e-07  1.1771e-05  0:00:17   13
   950  1.6347e-03  4.9558e-05  4.6514e-05  5.4692e-05  5.5343e-08  7.6876e-06  0:00:15   12
   951  1.4130e-03  4.4203e-05  4.1638e-05  4.8279e-05  3.0014e-08  5.8139e-06  0:00:13   11
   952  1.2454e-03  3.9896e-05  3.7696e-05  4.3162e-05  1.8780e-08  4.7261e-06  0:00:12   10
   953  1.1149e-03  3.6370e-05  3.4454e-05  3.9024e-05  1.2298e-08  3.9947e-06  0:00:10    9
   954  1.0109e-03  3.3430e-05  3.1743e-05  3.5601e-05  8.4445e-09  3.4745e-06  0:00:10    8
   955  9.2630e-04  3.0927e-05  2.9447e-05  3.2742e-05  5.9781e-09  3.0938e-06  0:00:09    7
!  955 solution is converged
Flow time = 0.02700000000000002s, time step = 54
3946 more time steps
 done.
   955  9.2630e-04  3.0927e-05  2.9447e-05  3.2742e-05  5.9781e-09  3.0938e-06  0:00:25   20
   956  1.1087e-02  8.8298e-04  7.7854e-04  7.8135e-03  3.8794e-04  9.4176e-03  0:00:27   19
   957  8.0617e-03  3.1319e-04  2.7910e-04  2.0388e-03  8.6868e-05  2.9863e-03  0:00:24   18
   958  5.4778e-03  1.5290e-04  1.3667e-04  6.0166e-04  1.9977e-05  6.9341e-04  0:00:21   17
   959  4.1299e-03  1.0448e-04  9.5634e-05  2.2163e-04  4.7961e-06  1.9437e-04  0:00:22   16
   960  3.3119e-03  8.2787e-05  7.6924e-05  1.1313e-04  1.2355e-06  6.1783e-05  0:00:20   15
   961  2.6785e-03  6.8772e-05  6.4478e-05  8.0253e-05  3.5826e-07  2.4200e-05  0:00:18   14
   962  2.2248e-03  5.9075e-05  5.5528e-05  6.6871e-05  1.2485e-07  1.2587e-05  0:00:16   13
   963  1.9071e-03  5.1959e-05  4.9022e-05  5.7870e-05  5.4697e-08  8.3411e-06  0:00:16   12
   964  1.6755e-03  4.6543e-05  4.4089e-05  5.1066e-05  2.9539e-08  6.3733e-06  0:00:14   11
   965  1.4999e-03  4.2348e-05  4.0263e-05  4.5884e-05  1.8427e-08  5.2354e-06  0:00:12   10
   966  1.3623e-03  3.8999e-05  3.7209e-05  4.1819e-05  1.2043e-08  4.4781e-06  0:00:11    9
   967  1.2519e-03  3.6247e-05  3.4697e-05  3.8538e-05  8.2597e-09  3.9339e-06  0:00:11    8
   968  1.1614e-03  3.3920e-05  3.2551e-05  3.5867e-05  5.8433e-09  3.5305e-06  0:00:09    7
   969  1.0852e-03  3.1929e-05  3.0683e-05  3.3586e-05  4.2265e-09  3.2207e-06  0:00:07    6
   970  1.0200e-03  3.0184e-05  2.9046e-05  3.1608e-05  3.1102e-09  2.9787e-06  0:00:07    5
   971  9.6367e-04  2.8651e-05  2.7599e-05  2.9922e-05  2.3217e-09  2.7852e-06  0:00:05    4
!  971 solution is converged
Flow time = 0.02750000000000002s, time step = 55
3945 more time steps
 done.
   971  9.6367e-04  2.8651e-05  2.7599e-05  2.9922e-05  2.3217e-09  2.7852e-06  0:00:26   20
   972  1.1301e-02  7.8754e-04  7.2176e-04  6.7360e-03  3.8788e-04  9.3209e-03  0:00:27   19
   973  8.4481e-03  2.6773e-04  2.4383e-04  1.7516e-03  8.6886e-05  2.9141e-03  0:00:24   18
   974  5.8483e-03  1.2897e-04  1.1644e-04  5.1170e-04  1.9985e-05  6.8297e-04  0:00:22   17
   975  4.4695e-03  8.9767e-05  8.2003e-05  1.8398e-04  4.7976e-06  1.9261e-04  0:00:20   16
   976  3.6187e-03  7.3111e-05  6.7513e-05  9.3244e-05  1.2352e-06  6.1635e-05  0:00:21   15
   977  2.9623e-03  6.2325e-05  5.7983e-05  6.8917e-05  3.5766e-07  2.4452e-05  0:00:18   14
   978  2.4901e-03  5.4579e-05  5.1011e-05  5.9224e-05  1.2435e-07  1.2967e-05  0:00:16   13
   979  2.1582e-03  4.8733e-05  4.5718e-05  5.2392e-05  5.4328e-08  8.7511e-06  0:00:17   12
   980  1.9132e-03  4.4229e-05  4.1619e-05  4.7032e-05  2.9263e-08  6.7963e-06  0:00:14   11
   981  1.7237e-03  4.0622e-05  3.8373e-05  4.2839e-05  1.8217e-08  5.6555e-06  0:00:13   10
   982  1.5734e-03  3.7652e-05  3.5725e-05  3.9477e-05  1.1887e-08  4.9052e-06  0:00:11    9
   983  1.4515e-03  3.5171e-05  3.3503e-05  3.6722e-05  8.1429e-09  4.3533e-06  0:00:11    8
   984  1.3502e-03  3.3059e-05  3.1599e-05  3.4419e-05  5.7556e-09  4.6863e-06  0:00:09    7
   985  1.2651e-03  3.1235e-05  2.9948e-05  3.2463e-05  4.1609e-09  3.8683e-06  0:00:07    6
   986  1.1927e-03  2.9639e-05  2.8497e-05  3.0770e-05  3.0613e-09  3.4264e-06  0:00:07    5
   987  1.1303e-03  2.8231e-05  2.7204e-05  2.9271e-05  2.2855e-09  3.1644e-06  0:00:05    4
   988  1.0762e-03  2.6974e-05  2.6040e-05  2.7936e-05  1.7285e-09  2.9813e-06  0:00:04    3
   989  1.0289e-03  2.5849e-05  2.4994e-05  2.6735e-05  1.3224e-09  2.8400e-06  0:00:03    2
   990  9.8740e-04  2.4811e-05  2.4043e-05  2.5645e-05  1.0228e-09  2.7251e-06  0:00:01    1
!  990 solution is converged
Flow time = 0.02800000000000002s, time step = 56
3944 more time steps
 done.
   990  9.8740e-04  2.4811e-05  2.4043e-05  2.5645e-05  1.0228e-09  2.7251e-06  0:00:26   20
   991  1.1901e-02  8.2961e-04  7.3337e-04  5.4804e-03  3.8784e-04  9.0612e-03  0:00:27   19
   992  8.8631e-03  2.8609e-04  2.5452e-04  1.4538e-03  8.6906e-05  2.8296e-03  0:00:24   18
   993  6.2159e-03  1.3682e-04  1.2162e-04  4.3921e-04  1.9993e-05  6.6172e-04  0:00:25   17
   994  4.7889e-03  9.3739e-05  8.5114e-05  1.6738e-04  4.7986e-06  1.8575e-04  0:00:22   16
   995  3.9173e-03  7.5520e-05  6.9858e-05  9.0799e-05  1.2344e-06  5.8899e-05  0:00:20   15
   996  3.2451e-03  6.4251e-05  5.9849e-05  6.9690e-05  3.5674e-07  2.2836e-05  0:00:20   14
   997  2.7564e-03  5.6222e-05  5.2615e-05  6.0137e-05  1.2362e-07  1.1638e-05  0:00:18   13
   998  2.4102e-03  5.0167e-05  4.7144e-05  5.3148e-05  5.3776e-08  7.4941e-06  0:00:15   12
   999  2.1534e-03  4.5445e-05  4.2891e-05  4.7693e-05  2.8849e-08  5.5553e-06  0:00:16   11
  1000  1.9530e-03  4.1661e-05  3.9511e-05  4.3403e-05  1.7902e-08  4.4224e-06  0:00:13   10
  1001  1.7929e-03  3.8574e-05  3.6730e-05  3.9966e-05  1.2106e-08  3.6544e-06  0:00:11    9
  1002  1.6631e-03  3.6020e-05  3.4415e-05  3.7187e-05  8.2792e-09  3.0990e-06  0:00:13    8
  1003  1.5553e-03  3.3871e-05  3.2457e-05  3.4879e-05  5.8425e-09  2.6850e-06  0:00:10    7
  1004  1.4643e-03  3.2029e-05  3.0779e-05  3.2906e-05  4.2177e-09  2.3681e-06  0:00:08    6
  1005  1.3863e-03  3.0431e-05  2.9317e-05  3.1203e-05  3.0996e-09  2.1153e-06  0:00:08    5
  1006  1.3192e-03  2.9034e-05  2.8038e-05  2.9724e-05  2.3126e-09  1.9105e-06  0:00:06    4
  1007  1.2606e-03  2.7801e-05  2.6911e-05  2.8437e-05  1.7485e-09  1.7403e-06  0:00:04    3
  1008  1.2089e-03  2.6705e-05  2.5912e-05  2.7309e-05  1.3380e-09  1.5969e-06  0:00:03    2
  1009  1.1629e-03  2.5725e-05  2.5014e-05  2.6317e-05  1.0354e-09  1.4806e-06  0:00:01    1
  1010  1.1216e-03  2.4830e-05  2.4187e-05  2.5422e-05  8.0960e-10  1.3857e-06  0:00:00    0
Flow time = 0.02850000000000002s, time step = 57
3943 more time steps
 done.
   Time = 0.177 seconds.
   Done.
   Cell count                              85945     86176     430402
   Mean cell count deviation               -0.2%     0.1%
   Partition boundary cell count           2076      3209      13616
   Partition boundary cell count ratio     2.4%      3.7%      3.2%
   Face count                              176814    178009    880022
   Mean face count deviation               -0.4%     0.3%
   Partition boundary face count           2224      3524      7484
   Partition boundary face count ratio     1.3%      2.0%      0.9%
   Cell weights                            9e+05     9e+05     4e+06
   Mean cell weight deviation              -0.2%     0.1%
Done.
  1010  1.1216e-03  2.4830e-05  2.4187e-05  2.5422e-05  8.0960e-10  1.3857e-06  0:00:26   20
  1011  1.2357e-02  6.1944e-04  5.7173e-04  3.8533e-03  3.8781e-04  8.9220e-03  0:00:27   19
  1012  9.0693e-03  2.1804e-04  1.9980e-04  1.0427e-03  8.6927e-05  2.8045e-03  0:00:28   18
  1013  6.4031e-03  1.1041e-04  1.0077e-04  3.2774e-04  2.0001e-05  6.5584e-04  0:00:24   17
  1014  4.9423e-03  7.9098e-05  7.3375e-05  1.3134e-04  4.7995e-06  1.8342e-04  0:00:22   16
  1015  4.0497e-03  6.5249e-05  6.1421e-05  7.6290e-05  1.2336e-06  5.8128e-05  0:00:19   15
  1016  3.3631e-03  5.6357e-05  5.3482e-05  6.1594e-05  3.5581e-07  2.2807e-05  0:00:20   14
  1017  2.8643e-03  4.9969e-05  4.7665e-05  5.4107e-05  1.2287e-07  1.1923e-05  0:00:17   13
  1018  2.5106e-03  4.5238e-05  4.3295e-05  4.8461e-05  5.3204e-08  7.8923e-06  0:00:15   12
  1019  2.2486e-03  4.1608e-05  3.9970e-05  4.4103e-05  2.8411e-08  5.9917e-06  0:00:16   11
  1020  2.0447e-03  3.8749e-05  3.7373e-05  4.0750e-05  1.7561e-08  4.8601e-06  0:00:13   10
  1021  1.8816e-03  3.6443e-05  3.5244e-05  3.8094e-05  1.1835e-08  4.1015e-06  0:00:11    9
  1022  1.7485e-03  3.4534e-05  3.3444e-05  3.5915e-05  8.0691e-09  3.5551e-06  0:00:11    8
  1023  1.6379e-03  3.2896e-05  3.1902e-05  3.4085e-05  5.6777e-09  3.1453e-06  0:00:09    7
  1024  1.5443e-03  3.1474e-05  3.0562e-05  3.2523e-05  4.0875e-09  2.8277e-06  0:00:08    6
  1025  1.4641e-03  3.0216e-05  2.9368e-05  3.1147e-05  2.9961e-09  2.5755e-06  0:00:06    5
  1026  1.3947e-03  2.9083e-05  2.8300e-05  2.9922e-05  2.2297e-09  2.3717e-06  0:00:05    4
  1027  1.3343e-03  2.8058e-05  2.7337e-05  2.8822e-05  1.6818e-09  2.2027e-06  0:00:04    3
  1028  1.2810e-03  2.7115e-05  2.6456e-05  2.7830e-05  1.2842e-09  2.0730e-06  0:00:02    2
  1029  1.2338e-03  2.6254e-05  2.5647e-05  2.6930e-05  9.9161e-10  1.9752e-06  0:00:01    1
  1030  1.1916e-03  2.5458e-05  2.4896e-05  2.6103e-05  7.7385e-10  1.8764e-06  0:00:00    0
Flow time = 0.02900000000000002s, time step = 58
3942 more time steps
 done.
  1030  1.1916e-03  2.5458e-05  2.4896e-05  2.6103e-05  7.7385e-10  1.8764e-06  0:00:26   20
  1031  1.2419e-02  5.6654e-04  4.9459e-04  2.1468e-03  3.8779e-04  8.8851e-03  0:00:28   19
  1032  9.1017e-03  2.1306e-04  1.8616e-04  6.2731e-04  8.6949e-05  2.8646e-03  0:00:24   18
  1033  6.3289e-03  1.1389e-04  1.0060e-04  2.2567e-04  2.0008e-05  6.6097e-04  0:00:25   17
  1034  4.8549e-03  8.3866e-05  7.5945e-05  1.0948e-04  4.8003e-06  1.8591e-04  0:00:22   16
  1035  3.9608e-03  6.9451e-05  6.3853e-05  7.5128e-05  1.2326e-06  5.9030e-05  0:00:20   15
  1036  3.2768e-03  5.9790e-05  5.5449e-05  6.3423e-05  3.5475e-07  2.2801e-05  0:00:20   14
  1037  2.7884e-03  5.2821e-05  4.9300e-05  5.5819e-05  1.2201e-07  1.1504e-05  0:00:18   13
  1038  2.4443e-03  4.7511e-05  4.4609e-05  4.9937e-05  5.2553e-08  7.3458e-06  0:00:15   12
  1039  2.1914e-03  4.3355e-05  4.0943e-05  4.5276e-05  2.7911e-08  5.4132e-06  0:00:16   11
  1040  1.9969e-03  4.0028e-05  3.8029e-05  4.1580e-05  1.7171e-08  4.2975e-06  0:00:13   10
  1041  1.8433e-03  3.7313e-05  3.5612e-05  3.8596e-05  1.1528e-08  3.5409e-06  0:00:11    9
  1042  1.7192e-03  3.5062e-05  3.3589e-05  3.6153e-05  7.8328e-09  2.9973e-06  0:00:11    8
  1043  1.6167e-03  3.3163e-05  3.1859e-05  3.4111e-05  5.4944e-09  2.5912e-06  0:00:09    7
  1044  1.5305e-03  3.1534e-05  3.0370e-05  3.2388e-05  3.9445e-09  2.2892e-06  0:00:08    6
  1045  1.4574e-03  3.0127e-05  2.9071e-05  3.0903e-05  2.8838e-09  2.0325e-06  0:00:07    5
  1046  1.3948e-03  2.8890e-05  2.7919e-05  2.9605e-05  2.1411e-09  1.8293e-06  0:00:05    4
  1047  1.3407e-03  2.7786e-05  2.6891e-05  2.8448e-05  1.6117e-09  1.6626e-06  0:00:04    3
  1048  1.2936e-03  2.6800e-05  2.5971e-05  2.7435e-05  1.2281e-09  1.5233e-06  0:00:03    2
  1049  1.2524e-03  2.5899e-05  2.5136e-05  2.6484e-05  9.4654e-10  1.4055e-06  0:00:01    1
  1050  1.2159e-03  2.5081e-05  2.4373e-05  2.5639e-05  7.3752e-10  1.3056e-06  0:00:00    0
Flow time = 0.02950000000000002s, time step = 59
3941 more time steps
 done.
  1050  1.2159e-03  2.5081e-05  2.4373e-05  2.5639e-05  7.3752e-10  1.3056e-06  0:00:25   20
  1051  1.2985e-02  7.1272e-04  6.2200e-04  1.3446e-03  3.8778e-04  8.6923e-03  0:00:23   19
  1052  9.3822e-03  2.6161e-04  2.3056e-04  4.3989e-04  8.6973e-05  2.7313e-03  0:00:25   18
  1053  6.4780e-03  1.3391e-04  1.1920e-04  1.8948e-04  2.0016e-05  6.4263e-04  0:00:22   17
  1054  4.9547e-03  9.4753e-05  8.6111e-05  1.1152e-04  4.8009e-06  1.8225e-04  0:00:20   16
  1055  4.0330e-03  7.7124e-05  7.1056e-05  8.4302e-05  1.2316e-06  5.8464e-05  0:00:21   15
  1056  3.3280e-03  6.5709e-05  6.1041e-05  7.1037e-05  3.5366e-07  2.2994e-05  0:00:18   14
  1057  2.8213e-03  5.7569e-05  5.3737e-05  6.1925e-05  1.2115e-07  1.1915e-05  0:00:16   13
  1058  2.4656e-03  5.1458e-05  4.8145e-05  5.4896e-05  5.1905e-08  7.8293e-06  0:00:17   12
  1059  2.2036e-03  4.6662e-05  4.3788e-05  4.9356e-05  2.7425e-08  5.9059e-06  0:00:15   11
  1060  2.0014e-03  4.2778e-05  4.0322e-05  4.4950e-05  1.6802e-08  4.7782e-06  0:00:13   10
  1061  1.8408e-03  3.9560e-05  3.7482e-05  4.1407e-05  1.1245e-08  4.0190e-06  0:00:13    9
  1062  1.7116e-03  3.6858e-05  3.5117e-05  3.8499e-05  7.6232e-09  3.4658e-06  0:00:11    8
  1063  1.6050e-03  3.4562e-05  3.3096e-05  3.6076e-05  5.3388e-09  3.0623e-06  0:00:09    7
  1064  1.5153e-03  3.2603e-05  3.1360e-05  3.4018e-05  3.8290e-09  2.7479e-06  0:00:08    6
  1065  1.4388e-03  3.0914e-05  2.9832e-05  3.2249e-05  2.7983e-09  2.4991e-06  0:00:07    5
  1066  1.3729e-03  2.9448e-05  2.8482e-05  3.0695e-05  2.0781e-09  2.2984e-06  0:00:05    4
  1067  1.3157e-03  2.8156e-05  2.7293e-05  2.9331e-05  1.5655e-09  2.1340e-06  0:00:04    3
  1068  1.2656e-03  2.7010e-05  2.6255e-05  2.8125e-05  1.1949e-09  1.9986e-06  0:00:03    2
  1069  1.2213e-03  2.5977e-05  2.5315e-05  2.7025e-05  9.2316e-10  1.8859e-06  0:00:01    1
  1070  1.1819e-03  2.5041e-05  2.4454e-05  2.6020e-05  7.2146e-10  1.7899e-06  0:00:00    0
Flow time = 0.03000000000000002s, time step = 60
3940 more time steps
 done.
  1070  1.1819e-03  2.5041e-05  2.4454e-05  2.6020e-05  7.2146e-10  1.7899e-06  0:00:24   20
  1071  1.2641e-02  6.2321e-04  5.5314e-04  2.1275e-03  3.8778e-04  8.5995e-03  0:00:26   19
  1072  9.3712e-03  2.3202e-04  2.0716e-04  6.3496e-04  8.6996e-05  2.7724e-03  0:00:23   18
  1073  6.5288e-03  1.1867e-04  1.0664e-04  2.3035e-04  2.0024e-05  6.4801e-04  0:00:24   17
  1074  5.0201e-03  8.3739e-05  7.6600e-05  1.1286e-04  4.8016e-06  1.8373e-04  0:00:22   16
  1075  4.1048e-03  6.8126e-05  6.3208e-05  7.7018e-05  1.2307e-06  5.8981e-05  0:00:19   15
  1076  3.4006e-03  5.8048e-05  5.4291e-05  6.3407e-05  3.5268e-07  2.3259e-05  0:00:20   14
  1077  2.8894e-03  5.0776e-05  4.7721e-05  5.4982e-05  1.2039e-07  1.2112e-05  0:00:17   13
  1078  2.5267e-03  4.5313e-05  4.2742e-05  4.8548e-05  5.1347e-08  7.9951e-06  0:00:15   12
  1079  2.2548e-03  4.1096e-05  3.8893e-05  4.3563e-05  2.7010e-08  6.0742e-06  0:00:13   11
  1080  2.0413e-03  3.7740e-05  3.5836e-05  3.9696e-05  1.6488e-08  4.9574e-06  0:00:14   10
  1081  1.8698e-03  3.5009e-05  3.3361e-05  3.6632e-05  1.1005e-08  4.2055e-06  0:00:12    9
  1082  1.7288e-03  3.2750e-05  3.1330e-05  3.4137e-05  7.4437e-09  3.6587e-06  0:00:12    8
  1083  1.6108e-03  3.0844e-05  2.9614e-05  3.2064e-05  5.2038e-09  3.2539e-06  0:00:09    7
  1084  1.5107e-03  2.9200e-05  2.8136e-05  3.0304e-05  3.7268e-09  2.9315e-06  0:00:08    6
  1085  1.4246e-03  2.7783e-05  2.6839e-05  2.8787e-05  2.7208e-09  2.6735e-06  0:00:07    5
  1086  1.3497e-03  2.6544e-05  2.5693e-05  2.7452e-05  2.0193e-09  2.4712e-06  0:00:05    4
  1087  1.2844e-03  2.5443e-05  2.4677e-05  2.6275e-05  1.5209e-09  2.3047e-06  0:00:04    3
  1088  1.2264e-03  2.4459e-05  2.3760e-05  2.5222e-05  1.1610e-09  2.1632e-06  0:00:03    2
  1089  1.1748e-03  2.3570e-05  2.2930e-05  2.4270e-05  8.9761e-10  2.0335e-06  0:00:01    1
  1090  1.1286e-03  2.2760e-05  2.2172e-05  2.3405e-05  7.0227e-10  1.9226e-06  0:00:00    0
Flow time = 0.03050000000000002s, time step = 61
3939 more time steps
 done.
  1090  1.1286e-03  2.2760e-05  2.2172e-05  2.3405e-05  7.0227e-10  1.9226e-06  0:00:25   20
  1091  1.3139e-02  5.6394e-04  4.7837e-04  3.5168e-03  3.8779e-04  8.5083e-03  0:00:27   19
  1092  9.4228e-03  2.2374e-04  1.9473e-04  1.0079e-03  8.7022e-05  2.8052e-03  0:00:24   18
  1093  6.4358e-03  1.2209e-04  1.0810e-04  3.3384e-04  2.0032e-05  6.4433e-04  0:00:22   17
  1094  4.8679e-03  8.8025e-05  8.0109e-05  1.4307e-04  4.8022e-06  1.8263e-04  0:00:23   16
  1095  3.9202e-03  7.1076e-05  6.5683e-05  8.5857e-05  1.2296e-06  5.8906e-05  0:00:20   15
  1096  3.1989e-03  6.0097e-05  5.5831e-05  6.7412e-05  3.5157e-07  2.3374e-05  0:00:18   14
  1097  2.6805e-03  5.2244e-05  4.8760e-05  5.7527e-05  1.1952e-07  1.2164e-05  0:00:18   13
  1098  2.3146e-03  4.6364e-05  4.3470e-05  5.0340e-05  5.0692e-08  7.9459e-06  0:00:16   12
  1099  2.0442e-03  4.1831e-05  3.9357e-05  4.4826e-05  2.6516e-08  5.9470e-06  0:00:14   11
  1100  1.8359e-03  3.8197e-05  3.6034e-05  4.0555e-05  1.6111e-08  4.7322e-06  0:00:12   10
  1101  1.6702e-03  3.5203e-05  3.3303e-05  3.7118e-05  1.0712e-08  3.9450e-06  0:00:12    9
  1102  1.5357e-03  3.2701e-05  3.0989e-05  3.4283e-05  7.2240e-09  3.3824e-06  0:00:10    8
  1103  1.4252e-03  3.0583e-05  2.9026e-05  3.1898e-05  5.0373e-09  2.9728e-06  0:00:09    7
  1104  1.3329e-03  2.8756e-05  2.7329e-05  2.9872e-05  3.5994e-09  2.6418e-06  0:00:08    6
  1105  1.2548e-03  2.7179e-05  2.5850e-05  2.8142e-05  2.6225e-09  2.3755e-06  0:00:07    5
  1106  1.1879e-03  2.5795e-05  2.4556e-05  2.6642e-05  1.9427e-09  2.1624e-06  0:00:05    4
  1107  1.1306e-03  2.4562e-05  2.3408e-05  2.5322e-05  1.4608e-09  2.0095e-06  0:00:04    3
  1108  1.0810e-03  2.3465e-05  2.2377e-05  2.4158e-05  1.1131e-09  1.8522e-06  0:00:03    2
  1109  1.0378e-03  2.2465e-05  2.1457e-05  2.3106e-05  8.5880e-10  1.7227e-06  0:00:01    1
  1110  9.9923e-04  2.1559e-05  2.0632e-05  2.2157e-05  6.7031e-10  1.7746e-06  0:00:00    0
! 1110 solution is converged
Flow time = 0.03100000000000002s, time step = 62
3938 more time steps
 done.
  1110  9.9923e-04  2.1559e-05  2.0632e-05  2.2157e-05  6.7031e-10  1.7746e-06  0:00:28   20
  1111  1.2520e-02  6.2365e-04  5.6163e-04  4.4502e-03  3.8780e-04  8.3229e-03  0:00:29   19
  1112  9.1933e-03  2.3217e-04  2.0835e-04  1.2462e-03  8.7047e-05  2.6947e-03  0:00:26   18
  1113  6.2247e-03  1.1761e-04  1.0587e-04  3.8864e-04  2.0039e-05  6.3060e-04  0:00:23   17
  1114  4.6585e-03  8.2690e-05  7.5752e-05  1.5234e-04  4.8024e-06  1.8013e-04  0:00:23   16
  1115  3.7206e-03  6.6751e-05  6.1895e-05  8.3832e-05  1.2285e-06  5.8778e-05  0:00:21   15
  1116  2.9925e-03  5.6262e-05  5.2502e-05  6.3218e-05  3.5051e-07  2.3894e-05  0:00:18   14
  1117  2.4662e-03  4.8584e-05  4.5508e-05  5.3496e-05  1.1874e-07  1.2966e-05  0:00:19   13
  1118  2.0959e-03  4.2710e-05  4.0132e-05  4.6412e-05  5.0135e-08  8.9235e-06  0:00:16   12
  1119  1.8208e-03  3.8095e-05  3.5916e-05  4.0874e-05  2.6114e-08  7.0244e-06  0:00:14   11
  1120  1.6077e-03  3.4398e-05  3.2528e-05  3.6518e-05  1.5815e-08  5.9494e-06  0:00:12   10
  1121  1.4381e-03  3.1360e-05  2.9732e-05  3.3015e-05  1.0491e-08  5.1594e-06  0:00:12    9
  1122  1.3004e-03  2.8820e-05  2.7393e-05  3.0147e-05  7.0614e-09  4.5955e-06  0:00:10    8
  1123  1.1868e-03  2.6665e-05  2.5400e-05  2.7757e-05  4.9166e-09  4.2141e-06  0:00:09    7
  1124  1.0914e-03  2.4807e-05  2.3682e-05  2.5741e-05  3.5092e-09  3.9041e-06  0:00:08    6
  1125  1.0103e-03  2.3189e-05  2.2177e-05  2.4008e-05  2.5550e-09  3.6435e-06  0:00:07    5
  1126  9.4107e-04  2.1778e-05  2.0850e-05  2.2501e-05  1.8922e-09  3.4543e-06  0:00:05    4
! 1126 solution is converged
Flow time = 0.03150000000000002s, time step = 63
3937 more time steps
 done.
   Time = 0.189 seconds.
   Done.
   Cell count                              85736     85765     428741
   Partition boundary cell count           2127      2996      13206
   Partition boundary cell count ratio     2.5%      3.5%      3.1%
   Face count                              176239    177370    876700
   Mean face count deviation               -0.3%     0.3%
   Partition boundary face count           2312      3310      7232
   Partition boundary face count ratio     1.3%      1.9%      0.8%
Done.
   Smoothing partition boundaries...done.
WARNING: 1 cells with non-positive volume detected.
Error at host: Update-Dynamic-Mesh failed. Negative cell volume detected.
===============Message from the Cortex Process================================
Compute processes interrupted. Processing can be resumed.
Error: Update-Dynamic-Mesh failed. Negative cell volume detected.
Error Object: #f
Registering ReportDefFiles, ("C:\Users\Alberto\Desktop\falling_seed\seed_one_files\dp0\FFF\Fluent\.\\drag-rfile.out")
Calculation complete.
(cx-gui-do cx-activate-item "Error*OK")
(cx-gui-do cx-activate-item "Information*OK")
