April 27, 2023 at 3:03 am
Hi Anna,
you should follow the following process
create a translational joint body to body(right-click on the joint in the connection tree then select translational in the ” type”) -> select the joint load in the transient -> select the velocity.
For more information, you can follow the attached link- 2.3. Connecting Multibody Components with Joint Elements (ansys.com)
All the best!
https://forum.ansys.com/forums/topic/how-to-access-the-ansys-online-help/
https://forum.ansys.com/forums/topic/guidelines-for-posting-on-ansys-learning-forum/#latest
