David Mercier
Hi, Once you have defined your RVE using MaterialDesigner or any other CAE software (you can have a look to Discovery as well, having great capibilities for archtiectured materials –> nanolattices…), you can parametrize your model using for example MAPDL, or the pyAnsys libraries available here: https://mapdl.docs.pyansys.com/version/stable/
Another solution is to set up parametric analysis using Workbench:
And if you want to have an optimisation of multiple parameters, Optislang is the solution: https://www.ansys.com/products/connect/ansys-optislang
