Diffusion is for species, so not sure it'll do much to particles unless the fluid mixing changes significantly?  If diffusivity is accessible as a parameter then you could do it that way. Note, DPM reporting and parameters aren't quite as simple due to the way we calculate the DPM tracks.
More details might help!
