April 27, 2023 at 3:26 pm
I am using a constant density for species and then defining it as a “volume-weight mixing law” in the mixture. Can you please explain further about this "if you set the mixture level density but don't check the species for additional inputs"? However, I didn’t patch the species. Is it necessary to patch all species after the initialization? Whenever I try to setup up the selection of species in the mixture. It shows an error message (image attached below).
Thanks
Ali
