JINBO Mi
hallo, maybe there are some problems while loading the needed lib and software.
1.do you have give the access right for the software to install with the folder
2.if there is a config file have not be writed, for the common sense, to start a installaition on the linux and unix, it is needed to change the config file
3.if you have removed all the files of the old edition of the software
