OK. The thin wall has a thickness which you defined in the wall bc panel. In 2d the domain is 1m thick unless you changed a reference value. If you changed a reference value, change it back. So, your 20W total is applied as W/m3 with the wall volume being length (from geometry) * thickness (BC panel) * 1m.
