Hi Dustin,
Thank you for reaching out to the Ansys Learning Forum and your patience is much appreciated.
As it is a long time since the time of your post, were you able to progress in your analysis, or still facing the same issue?
Did you try simulating different types of responses with the touchstone file? If so, were you able to get different results for different responses?
Best regards,
Praneeth.
