Hi Dustin,
If you are interested then you can try simulating the single port circuit response with different touchstone files (with variations in the matching frequency and the level of matching) and see if you are getting the same result or different results. In this way, it may be possible to identify the cause of this issue.
Best regards,
Praneeth.
